Add Oil ?
/ Add Oil ? #1
Dog Gone It
TN.
L2501 (4wd)
Just bought a used JD F932. Im going though it the best I can. I have checked all oil levels and added. I have one that I dont know what to add and cant find any info on line. I really need a manual bad !
Anyway there is an Oil Cap just like the engine oil cap located at the front of the motor block just behind the cooling fan. Do I add reg motor oil or heavy weight and how far do I fill it to ?
Thanks
/ Add Oil ? #2
You'll want a technical manual. TM1487
Is the cap you're posting about on a square plastic tank? If so that's the transmission fluid overflow tank. Add transmission fluid there.
/ Add Oil ?
No the cap is exactly the same as the oil cap on the valve cover and its located on a metal housing that looks similar to a large water pump housing and this housing is attached directly to the front of the engine block. Im beginning to think that its nothing more than another access to pour oil into the engine but Im not sure why.
Thanks
2014 F-150 STX (A56438)
2014 F-150 STX...
2015 New Holland TS6.110 Tractor with Alamo Boom Mower (A64047)
2015 New Holland...
2019 ISUZU NRR 4X2 S/A 6 COMPARMENT  BEVERAGE TRUCK (A59910)
2019 ISUZU NRR 4X2...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 PETERBILT 579...
