6284 starting hard, any ideas?
/ 6284 starting hard, any ideas? #1
gjb
We have a Cub Cadet 6284D with the Cat diesel.
In cooler temps, it's very hard to start. It turns out the glow plug controller is a simple 5-second timer; below freezing that's not enough. You have to play with the key switch and get the glow plugs to cycle 2-3 times before it'll start.
Is there an automatic (temp-sensitive) glow plug controller available for this machine? Or would we be better off replacing the timer with a manual switch (like old IH farm tractors)? We previously had a 5234D that started way easier.
Thanks for any suggestions.
/ 6284 starting hard, any ideas? #2
I have a 6284 also but haven't had it long enough to offer much help. Although I did start it several times when below freezing with little or no trouble.
I did have the heater ( hose type) plugged in for about .5 hours before starting.
My previous Cub ( Daihatsu diesel) started pretty well below freezing but it had a heater also. I usually cycled the glow plugs several times prior to starting.
I should know more real soon how the 6284 will do....
GrayBeard
/ 6284 starting hard, any ideas? #3
Trying to find out from Graybeard---what he thinks of his 6284d after having it awhile.......please respond to nhel13@
hotmail.com thank you.
/ 6284 starting hard, any ideas? #4
60in. Work Bench (A65640)
60in. Work Bench...
2021 BOBCAT E50 EXCAVATOR (A63276)
2021 BOBCAT E50...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
9008SFL (A64556)
9008SFL (A64556)
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
2021 BOBCAT T62 R-SERIES SKID STEER (A65053)
2021 BOBCAT T62...
