6284 starting hard, any ideas?
/ 6284 starting hard, any ideas? #1
gjb
We have a Cub Cadet 6284D with the Cat diesel.
In cooler temps, it's very hard to start. It turns out the glow plug controller is a simple 5-second timer; below freezing that's not enough. You have to play with the key switch and get the glow plugs to cycle 2-3 times before it'll start.
Is there an automatic (temp-sensitive) glow plug controller available for this machine? Or would we be better off replacing the timer with a manual switch (like old IH farm tractors)? We previously had a 5234D that started way easier.
Thanks for any suggestions.
/ 6284 starting hard, any ideas? #2
I have a 6284 also but haven't had it long enough to offer much help. Although I did start it several times when below freezing with little or no trouble.
I did have the heater ( hose type) plugged in for about .5 hours before starting.
My previous Cub ( Daihatsu diesel) started pretty well below freezing but it had a heater also. I usually cycled the glow plugs several times prior to starting.
I should know more real soon how the 6284 will do....
GrayBeard
/ 6284 starting hard, any ideas? #3
Trying to find out from Graybeard---what he thinks of his 6284d after having it awhile.......please respond to nhel13@
hotmail.com thank you.
/ 6284 starting hard, any ideas? #4
2006 PETERBILT 379 (INOPERABLE) (A67714)
2006 PETERBILT 379...
2022 SWARTZ 100" X 40' GOOSENECK TRAILER (A64276)
2022 SWARTZ 100" X...
2014 (INOPERABLE) FREIGHTLINER CASCADIA (A67714)
2014 (INOPERABLE)...
BRADLEY MACHINE  MINI VAC TRAILER (A67714)
BRADLEY MACHINE...
2011 CATERPILLAR CB434D DOUBLE DRUM ROLLER (A65056)
2011 CATERPILLAR...
2016 MAGNUM  MLT6S (A68842)
2016 MAGNUM MLT6S...
