5' Blecavator (Stone Burier) - right application?
/ 5' Blecavator (Stone Burier) - right application? #1
eCRX
Ayr
2004 Massey Ferguson GC2300, 2015 Cub Cadet XT2
Anyone have experience with a Blecavator?
My buddy is building a home on a large lot and we're looking into options for dealing with the existing rocky topsoil.
The topsoil has a decent amount of rocks the size of potato's and the odd watermelon-sized boulder.
What size rocks can a Blecavator handle?
Any general advice about appropriate applications for a Blecavator would be appropriated.
Thanks
/ 5' Blecavator (Stone Burier) - right application? #2
I’ve had my Blecaviator 130 for about 15 years. Thats just over 5’, so probably the same as yours. While the desert soil tends to be mostly sandy, there are areas where the ancient volcanos near me deposit many small rocks. My experience is that it will handle rocks up to about baseball size ‘mostly ok’.
It will also bury most weeds, twigs etc.
Larger rocks will bounce around and finally be spit out on the surface.
Its biggest drawback is that you really need 35 to 40 hp or it will be really slow going. The reverse rotation really puts a load on the tractor.
It also weighs about 900 lbs not including any water ballast you put in the compaction roller.
/ 5' Blecavator (Stone Burier) - right application? #3
I visited the web site. It showed the 155 model. The 155 is one really heavy piece of equipment. 1665 pounds - as I recall.
Just a couple questions. Does this "thing" really do that good a job. How does it compare to simply - gathering and removal.
/ 5' Blecavator (Stone Burier) - right application? #4
Thanks
I would spend the money on renting a row crop tractor and a hydraulic drive rock picker like the Degelmen or Schulte rock pickers for a few days.
/ 5' Blecavator (Stone Burier) - right application? #5
/ 5' Blecavator (Stone Burier) - right application? #6
Actually, it does. I don’t use it primarily for stone burying, but it is the best maintainer of my fire breaks. I have 40’ to 50’ wide firebreaks around the perimeter of my 26 acres. This is desert and while there are no trees to speak of, the brush grows every spring after the rainey season.
The Blec will grind up any brush & weeds up to about 3’ high and bury it almost completely. After a pass all you see is bare dirt and a few larger cut up branch which will not burn on the ground.
And if it does encounter rocks, it burries them too.
/ 5' Blecavator (Stone Burier) - right application? #7
Thanks orezok. Firebreaks are one of my major concerns this time of year. I really need to cut about half a mile of firebreak in my NW pasture.
These gosh darn wildfires are getting worse every year around here.
/ 5' Blecavator (Stone Burier) - right application? #8
I thought for sure this was a made-up word and you were messing with us. Like the Deframulator or Turbo Encabulator (look up that video if you haven't). But no, it is actually real. Learn something new every day...
/ 5' Blecavator (Stone Burier) - right application? #10
Mowing a couple of acres around your buildings will prevent surface fires from spreading and thinning a like area of trees will force crown fires to the ground. Firebreaks are only effective if crews are available to burn out and hold the fire line.
/ 5' Blecavator (Stone Burier) - right application? #11
The stone burrier smashes the rocks down and essentially
lifts the dirt and pushes the dirt it up at the same time.
www.triginer.com
The Triginer rock pickers like both the Lenco and Nortec rock pickers
are sub terrainian rock pickers meaning they can dig deep with their
digging scoops to remove every rock it can reach.
The method Triginer employs is a rotating digging head that lifts all
the rocks it can lift up on to the conveyor chain and at the same time
the dirt and very small stones fall through the conveyor chain to the
ground.
I do not know how to post a youtube video from Triginer here so all I can do
is provide the link for anyone to use as they have plenty of videos of their
machines clearing stone.
The Triginer video "Rock Picker TRIGINER working deep" is an
excellent video showing how well it works leaving only very small
stones and a thick fine dirt seed bed.
Another excellent example of a stone picker is the Lenco stone picker
which uses a potato digger scoop method to pull stones up with the
digging edge and onto the conveyor chain where very small stones,
dirt and roots drop to the ground and then rocks are carried into the
hopper by the conveyor.
www.lenco-harvesters.com
Both rock picker types lend themselves to using ridge tillage for a deep seed
bed that will allow row crops to germinate quickly and grow quickly and
create a thick canopy choking off weeds.
/ 5' Blecavator (Stone Burier) - right application? #13
Post #9. I would not have believed it if I had not seen it. Incredabla.
Talk about turning a pig's ear into a silk purse........
2000 Kenworth Tri-Axle Dump Truck (A59230)
2000 Kenworth...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A61306)
2022 Greenworks...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
207269 (A52708)
207269 (A52708)
2012 International Prostar (A61306)
2012 International...
