4300 Hour Meter blank
/ 4300 Hour Meter blank #21
Great thread with detailed information. Thank you all. Another source for the meter - .ebay.com/itm/ENM-COMPONENT-T1101AB-HOUR-METER-PANEL-LCD-6-DIGIT-5MM-DIGIT-8-28VDC/173501434800?epid=1467963463&hash=item28657dcbb0:g:JVYAAOSwVAZbheYu
/ 4300 Hour Meter blank #22
I have a 2001 JD 4300 that I bought about 3 yrs ago. The hour meter stopped working about 2 yrs ago. I’ve tried the $250 non-OEM clusters but couldn’t get the glass seal to work without using my OEM glass and seal but then the glass would hit the gauge arms. I wasn’t going to pay $600+ for an OEM cluster just for the hour meter. I removed the cluster and opened it up. On the hour meter there was a white sticker with T1101AB2 229/01. I separated the circuit boards and had a closer look at the hour meter. I identified via the internet that it is an hour meter manufactured by ENM - T1101AB2. I found a replacement unit at Allied Electronics for $20 with $6 shipping. The meter has 4 solid wires labeled P, N, I, and R. Best I have determined P=positive, N=negative, I=input, and R=reset. I hooked up some jumper wires and 12-volt power source to the new unit and made it work (positive to P and I and negative to N and nothing on R). So, I tried the jumper wires to my old meter (the wires are exposed at the top of the white plastic spacer) and it didn’t work. So, I un-soldered my old unit and used the original white plastic spacer and soldered the new unit in. It has been working for 20 hours without any problems. I think it is fixed for $26. Hopefully it will last for a few yrs. You can run up the hours on the meter to match the hours on your tractor by just leaving the unit hooked up to a 12v batter prior to installing. Mine would have taken over 2 months so I just matched the hours since my last oil change (only 10 hrs).
Thanks for the post. I got an hour meter from RS sales, same part number and installed like you said. It all works now, thanks again.
/ 4300 Hour Meter blank #23
That is what I did as well. My 4600 had it’s hour meter go bad 2 years ago. I replaced it with a new one from JD and all is fine… I just need to add the hours from the prior clock when I do my calculations for service (I keep a digital log of everything).
-Bob
Claas Lexion 500 Series Manuals (A63117)
Claas Lexion 500...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2018 Dodge Charger (A61574)
2018 Dodge Charger...
HOBAR 4 5212 BAND SAW (A64281)
HOBAR 4 5212 BAND...
2007 Chevrolet Express 2500 Cargo Van (A61573)
2007 Chevrolet...
