4044m NIGHTMARE!
/ 4044m NIGHTMARE!
What makes me mad is my dealership said the axle seal was under powertrain warranty before they picked it up. Now that they have the tractor in the shop its a different story.
/ 4044m NIGHTMARE! #72
Hope it works out for ya.
/ 4044m NIGHTMARE!
Well dealer just called and said both rear axle shafts needs to be replaced because there is grooving in the axle shaft
/ 4044m NIGHTMARE!
Do you think this could be an over torqueing issue when it was at the factory?
/ 4044m NIGHTMARE! #75
No.
Seems to be a compatibility issue between axle material and seal material. No way the proper seal could wear a groove in a steel axle in 400 hours.
/ 4044m NIGHTMARE! #76
Those axles would have been butter soft and not able to support the weight of the tractor. If it had constant contact with some very abrasive material, maybe. But that probaably would have destroyed the seal long before the shaft.
Is it possible for the plastic of the seal to desintegrate and only the sping (in some oil seals) to be contacting the shaft? That might create a very slight grove. As it was leaking, that would even lessen any possible damage though.
/ 4044m NIGHTMARE!
I think next tractor will be a yanmar yt359c. They have a 10yr 3000hr powertrain warranty, that's saying something about there product!
/ 4044m NIGHTMARE! #78
YANMAR is number one in my books. But you can have all the warranty in the world and it's worthless unless it's honoured and applied effectively.
/ 4044m NIGHTMARE!
Like this tool they been looking for they are blaming it on the pandemic. Its not like the 4 series is a brand new model tractor, its been around since 2014. No reason not to have all the tools and parts to make a repair!
/ 4044m NIGHTMARE! #80
Most soaps are very alkaline and when used with a pressure washer, they can be forced into the seals. That can lead to corrosion in the seal/bearing area. If this repair is not warranty, the old parts are yours. I'm sure we all would be interested to see pictures of the "worn" parts.
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2015 Komatsu HM400-3 (A60352)
2015 Komatsu...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
