360* Rotating Back Blade Project
/ 360* Rotating Back Blade Project
Now a special reply for Rob -
Aw shucks Rob - You are very welcome. Just a small token of my appreciation for all the machining you did for me.
You can stash your tractor electrical kit away in the case up at your Three Rivers Camp (soon to be home). One day when the dust settles and your Barn / Shop is complete, you can install, at your leisure, some of the additional upgrades you want for your tractor. Esther and I would love to travel out in our RV to visit you and Loretta, and to check out your Log cabin home when it's complete. I could help you install all the goodies on your tractor, that is, if you have not already got to it by then. Did you open the "Packing List" envelope taped to the outside of the box? To me, that is more important than everything that was inside. See you in a couple of months.
Larry
/ 360* Rotating Back Blade Project #162
Larry,
Did you open the "Packing List" envelope taped to the outside of the box? To me, that is more important than what was inside.
Larry
No I didn't, but I'm going to do it now as I type. It's a good thing I didn't throw the box away ... LOL ... that's what I did with the packing envelope the Jeep license plates came in. And apparently, taped to the outside of the packing envelope was the DMV registration and sticker! ??? :mad:
OK I got it cut off and am reading it now....
It is a personal letter from Larry thanking me (again) with all his heart for what I did. It is truly a moving letter Larry, written with sincerity and deep emotions.
I'm so glad you posted this because the box was ready to be thrown out and I would have never gotten this letter from you. I will keep it inside my new electrical tool kit you gave me to remind me forever what a tremendous experience we had doing these projects together, and also to remind me what wonderful friends we have become.
Thank you so much,
/ 360* Rotating Back Blade Project #163
Boy I just spent an hour and a half going through this entire post. I was enthralled. Great piece of work from both of you. Seriously, I spent 28 years in the AF working on weapons of all sorts and the machine work was just as good as anything I ever saw out of Sandia labs. WOW
EdC - Boy I just spent an hour and a half going through this entire post. I was enthralled
Wow, I had no idea it takes that long to read the entire post from start to finish? I sure am glad you took the time to check it out and take the time to reply --------
EdC - ....."and the machine work was just as good as anything I ever saw out of Sandia labs"
Sandia Labs as in Albuquerque, NM ? and the Air Force Weapons Lab as in Kirtland AFB ? I worked for the AFWL from 1977 to ~ 1982 on the A.L.L. project. Where you there then? We may have either worked together or passed one another going in & out the security gates. I still do work at Sandia Labs when I'm needed every now and then.
Larry
/ 360* Rotating Back Blade Project #165
Larry
No, I never worked at the Labs. I was active duty Air Force and was a maintainer. Took bombs and reentry vehicles apart, swapped out parts, put 'em back together for 28 years. I was TDY (short trips of about a week or so) down to Sandia quite a few times in the early and mid eighties but never stationed there. I always admired the engineering and thought that went into the things made there.
/ 360* Rotating Back Blade Project #166
My son is retired Air Force and now works at Sandia in New Mexico. Won't tell me what he does. Said he would have to kill me if he did.
/ 360* Rotating Back Blade Project #167
3RRL said:
Larry,
Larry
Thank you so much,
Was the "letter" written on "bank" stationery?:D
Blue Safety Checks - Checks In The Mail
/ 360* Rotating Back Blade Project #168
Great project, great documentation and you made a great friendship out of it. This web site is one of my favorites for theese reasons. Its amazing to me that people "get to know" each other enough on an internet site to fly 100s of miles to help each other out with a project. The deversity of our backgrounds, different levels of experience and education all add up to make a great site.
3RRL said:
Larry,
Larry
Rob,
That reminds me of when I was young, getting a present along with a card, I would open the box first to get to the present....then throw away the card that had the cash in it :rolleyes:. I'm pleased you found the personal note from me.
Larry
/ 360* Rotating Back Blade Project #170
GuglioLS said:
When (if it ever) dries up, I'll get some action shots of it cutting into some decent dry dirt.
That all for now -
Larry
Some of us are still waiting on the updated report :) Or do we have to wait for Rob to show up later this month to get the full blown tutorial?
Doh!!
I bet you thought I broke it and now it's a pile of scrap metal :rolleyes: NOT!
Sorry for not updating this thread, been busy with my bull dozer, grapple making, road building, wood cutting, etc..... you know, the ususal excuses.
So anyway ZJ's reply 113 on page 12:.....
Next suspition: that shear pin on rotating axle seems the weakest point on your construction. Look at ratio between force on one end of blade and on shear pin.
Locking pin, used before your modification, was on significally bigger radius, maybe 8" towards 1" now, and was about 1"dia, and your shear pin is maybe 1/2"
ZJ was right, I sheared the shear pin under not to heavy of a load so That was that - I knew I had to fix it or it would not perform the tasks I intended.
I decided to make a major change in the way the gear box was coupled to the blade. I purchased a PTO slip clutch. I had to build up the outside thickness of steel at one end of the slip clutch about 1/2" so that I could bore the ID to 2" (it came with a 1-3/8" ID). Then I was able to slip it over the blade pivot shaft. I then installed a grade 8 bolt instead of a shear bolt.
Larry
I then re-installed the gear box, the slip clutch just fits between the top of the blade boom & the bottom of the gear box. In the picture, the springs & bolts look very close. There is 1/4" of clearance between the the bolts and gear box, so it's OK.
I was able to try it out, under moderate pressure at the edge of the blade, the clutch slips so it is protecting the coupler, & gears in the gear box.
Now that I know for certain the slip clutch fits and protects the blade pivot shaft and gearbox. Next is to figure out a way to have a remote controlled locking pin installed where the OEM pin was....
So I fabricated a solenoid. -
For one end of the solenoid spool, I found a massive chunk of solid 4"x6"x36" nylon in salvage for 1$ a pound, it weighed 32 #'s
I sliced off a chunk to make some non ferrous (non magnetic) spool ends.
I made a stop for the radial arm saw so as to get four pieces exactly the same. I figured I better make the parts for 4 solenoids and maybe one would come out good?
Larry
Here are the 4 slices of non conductive material for one end of the solenoid:
I drilled a hole in the center, then chucked them all into the lathe to make them round:
Larry
This stuff is fun to machine it makes white "snow" all over the place. and the finish is as smooth as glass:
Larry
OK, so now things are starting to take shape, they are nice and round now. Next was to turn the surface to make that part smooth & flat:
Then it was time to counter bore the center to receive the center part of the spool to wind the copper wire onto:
Larry
Now you can see what I am trying to make. A spool to wind magnet wire onto. The center of the spool is 1" copper (non magnetic) the bottom of the spool is the nylon - (cheap & easy to machine) the top of the spool is a 1" ID x 2.5" OD steel washer.
The "C" frame (outside of the solenoid) is 2.5" ID x 1/4 wall steel pipe. In the picture below you can see the 3/4" steel hitch pin that is the Armature of the Solenoid.
Larry
OK so now we have the basic parts to make a solenoid. A steel pin in the center of a non ferrous guide tube surrounded by a few thousand turns of enamel coated 16 gage copper magnet wire encased in a steel pipe:
There are about a thousand details I left out to protect my "secrets" ;) . but mostly not to bore you any further.
Larry
Here is one completed solenoid. It has a 2" stroke and about 100 lbs of pull. I made enough parts to make four, but I only need one assembled and working solenoid. So I have plenty of spare parts for future projects.
Here it is in action:
Larry
This video will give you an idea of the tremendous magnetic pulling power at the tip of the hitch pin:
Somehow I have a bad feeling about all that strong magnetic force along the length of that hitch pin. I think it's going to "stick" to the steel on the sides of the holes that it's supposed to move in & out of.
I set the solenoid in place to test my bad feeling from above - guess what - I was right, It does NOT work :mad:. The magnetic force causes the pin to hold tight to the sides of the holes it goes through, so it does not pull the pin as expected. What a Waist of time all that was :rolleyes: - Back to the drawing board. Next is to look at some 12 volt linear actuators to push / pull the locking pin. They use them linear actuators in monster garage, so that's got to work.
Larry
The following idea (IMHO) is far superior to a solenoid and will "Index" into a pin hole as it rotates under the pin. It's a wedge operated by a Linear actuator that has 110 pounds of push / pull force. It should even be able to pull the pin with some pressure on it. I whipped this up in one hours VS a Month farting around making solenoids.
Here is the concept:
The beauty of this is, I do not have to modify the hitch pin. As it wears out / breaks - whatever. I can simply replace it with a new one with no modifications:
Larry
2025 78in Bucket Skid Steer Attachment (A61572)
2025 78in Bucket...
2016 Ford F250 Crew Cab Service Truck (A64194)
2016 Ford F250...
NEW HOLLAND TC35A TRACTOR (A64280)
NEW HOLLAND TC35A...
UNUSED SDLANCH 14' BI-PARTING IRON GATE (A64281)
UNUSED SDLANCH 14'...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A61572)
2016 New Holland...
Caterpillar 928F Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 928F...
