Snow Equipment Buying/Pricing 30ish hp cab tractor for mowing and snow clearing
   / 30ish hp cab tractor for mowing and snow clearing
Thanks guys. I have told her about the Kubota and will tell her about the JD 3320 and hopefully will be able to go look at them sometime. I do like how John Deere has made attaching front, mid and rear implements almost automated. She really would have no need for the quick change features though as either the mower or snow blower will be on this tractor but I will show her and she can try both machines out and decide what she wants.
   / 30ish hp cab tractor for mowing and snow clearing #22
Oh the thought of 20 tractors....Does she have a sister?
   / 30ish hp cab tractor for mowing and snow clearing #23
I'll confess I haven't read every word of every post, so this may have already been discussed. If she looks at the B3030, she may want to consider the wheel-spacer kit. It adds 3" in total to the tractor's stance, which it desperately needs. Mr. Ductape was nice enough to steer me in that direction and I'm very happy with the improvement.
If she's mostly on flat ground, it wouldn't be worth the additional $300. In Georgia, a big snow for us is 2", so I don't have any notion of what a snow blower does to the center of gravity. My B3030 has a FEL which does make the tractor less stable.
It's amazing how well the A/C works, even in 95 and 100 degree temps. The few times I've used the heat, it worked equally well.
Good luck on her search and decision.
If she goes with the B3030 I will advise her to get the spacer kit anyway as it won't hurt nothing and I would rather her not feel nervous if she does take it on a slope.
   / 30ish hp cab tractor for mowing and snow clearing #26
Robert I will add another vote for the Kubota. I think as you look around for a factory cabbed tractor you will find that the B3030 is about the only thing out there in that frame size. If you jump up in size then your choices are many but heavier and less maneuverable for finish mowing.
MarkV
   / 30ish hp cab tractor for mowing and snow clearing #27
Kubota B3030 hsdc is the way to go, i owned this set up myself a few years ago. I sold it to a member here & he loves the set up!
   / 30ish hp cab tractor for mowing and snow clearing #29
I'm also considering the 3030 and would greatly appreciate advice for a slightly different set of requirements.
I'm looking for a cab tractor for:
1. Removing snow from a 1/2 mile long, gently sloping dirt driveway
2. Grading the driveway (and applying dust control)
3. Mowing about 8 acres of fields (I have a John Deere Z225 ZTR mower for our lawn that I love, so no need to use the tractor for that).
4. a bucket would be nice for yard work
I'm in southern NH, close to a Kubota/New Holland dealer and a John Deere dealer. I have no preference for any of these brands (I bought the mower based on Consumer Reports' recommendation).
I'm leaning toward Kubota because numerous friends/neighbors have recommended them (some who have owned several of them).
A trip to the Kubota dealer resulted in a quote for:
- L3240 HST cab ($30,900)
- 7' snowwolf plow (didn't specify model) $3900
- 5' rotary cutter ($1600)
- 72" Land Pride grader ($1300)
Questions:
- would the 3030 be sufficient for my needs?
- any recommendation on front mount snowblower vs. plow? (dealer said that rocks would chew up the snowblower on a dirt driveway)
- transmission? (I've never owned an automatic transmission car and enjoy shifting)
- price: I've never paid more than 30k for a car (and I've had some nice used cars), so the thought of paying close to 40k for my first tractor was shocking to me. I'm happy to buy used if it makes sense, but I also want a tractor that will last a long time (I keep my cars to 200k+ miles) and want to spend my free time with my family, not repairing a tractor.
What's a reasonable ballpark to pay for a setup suitable for the needs listed above?
Thanks!
   / 30ish hp cab tractor for mowing and snow clearing #30
Unless that includes a lot of options & good FEL $30,900 sounds high. check this link for a comparable JD 3320 Cab / HST Even adding a 300CX FEL and the prices is less than $29,200. Even the JD 3520 Cab / HST is way less than $30,900.
2305
and this is only an Internet posted price - not a final deal.
   / 30ish hp cab tractor for mowing and snow clearing #31
That rotary cutter price seems a little steepe as well?
It may be but we can't say for sure until we know what brand and model he was priced. It is not out of line for a good medium duty mower to cost that much and more.
   / 30ish hp cab tractor for mowing and snow clearing #33
Good point robert.
   / 30ish hp cab tractor for mowing and snow clearing #34
Questions:
Thanks!
Granite welcome to the forum. I think the B3030 would do what you list. It is a smaller frame tractor so you need to sit in one and see if it meets your comfort standards. As far as the quote you received, look around some more. At least in my area those prices seem high.
MarkV
   / 30ish hp cab tractor for mowing and snow clearing #35
Questions:
Granite, if you'd like to farmiliarize yourself with the 3030 you are welcome to come over and check one out in a 'non-salesman-like' setting. My blower is packed away, but you could get yourself acquainted with controls, how the loader goes on/off, installing the front quick hitch for the blower, mounting rear attachments, etc.
   / 30ish hp cab tractor for mowing and snow clearing #36
I prefer blades on dirt and a blower on the rear tilted back to miss the stones. If the drive freezes over quickly the front blower would work.
The tractor must be set up for the blade to have hydraulic angle, anything else?
   / 30ish hp cab tractor for mowing and snow clearing #37
I don't mow with my B3030 HSDC, but I do everything else that you mention and it is more than adequate. Regarding the gravel driveway, the snowblower works fine if you start out right at the beginning of the season and use your head. I haven't broken a sheer pin in many years on my driveway. Below is a picture of my gravel driveway 2/3 of the way through the snow season:
   / 30ish hp cab tractor for mowing and snow clearing #38
2305
That's a relief, glad to hear I'm not the only one who thought the price was high!
   / 30ish hp cab tractor for mowing and snow clearing #39
The dealer didn't give me the brand/model on the cutter, but I'll ask for it...
   / 30ish hp cab tractor for mowing and snow clearing #40
MarkV
Thanks Mark, I'm thrilled I found the forum - the responses have been terrific.
I'm fairly small, so I don't anticipate any comfort issues; glad to hear the smaller tractor should do what I need. I'll definitely keep looking based on the responses I've been getting.
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
2001 JOHN DEERE 310SG BACKHOE (A60429)
2001 JOHN DEERE...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
