3 Phase For Shop?
/ 3 Phase For Shop? #31
I put VFDs on a friends lathe and mill. He just loves them. Lathe is 230 and Mill is 600, using a transformer to first make 600 from 230 and then to the VFD.
Beware of VFDs that have been sitting unused for a while. Two we had, blew up, because the capacitors had to be reformed! Who knew?
/ 3 Phase For Shop? #32
Check at Gov Planet to see if they have any MEP-803A surplus generators near you. They are switchable from single to 3 phase. It could double as house current during an outage. Be aware the MEP-804 and up are 3 phase only. The 803 delivers 10KW constant and surges above that in single phase.
/ 3 Phase For Shop? #33
No motor is 100% efficient, but it would run at least a 8.5 hp load and pull a little over 30 amps single phase. At a guess, I could build the whole thing for $500. The video was great, but the wiring looks pretty puny. I would upsize the power lines to 8 gauge copper, but the capacitor connections would be fine with smaller wire.
Just a note, if you're only pulling 30 amps you only need 10 gauge wire. Overkill is never a bad thing, but if you are only putting a 30 amp breaker in, you don't need wire any larger than 10 gauge.
Aaron Z
/ 3 Phase For Shop?
Aaron Z
The motor nameplate says 34 amps. That would be the max 1 phase current. Naturally, as soon as you get 3 phase it would drop to around 20 amps. I figure to put it on a 50 amp breaker in the service panel. Maybe 40 amps, which is good for 32 amps continuous, but a 50 amp circuit would be better.
/ 3 Phase For Shop? #36
ALSO, you need to derate VFDs when running on single phase and some won't even run without three phase.
/ 3 Phase For Shop? #37
. Careful you don’t confuse our American Cousins with the superior 600V over their puny 480V.
/ 3 Phase For Shop? #38
480 is for children with bobby pins!
MASSAGE CHAIR (A58214)
Engine (A59228)
Engine (A59228)
2020 DRAGON ESP...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
KBH Tender (A61307)
KBH Tender (A61307)
KJ K1119 11'x19' Carport (A60463)
KJ K1119 11'x19'...
