2 cyl diesels???????
/ 2 cyl diesels??????? #1
BLUEBONNET2
harrison county, tx (NE TEXAS)
nortrac 25 xt JD zeroturn 54", briggs mtr.
good morning,
tried to find a thread on this subject, however, seems to be none. /forums/images/graemlins/confused.gif
anyone using this type engine.....looked at a yanmar yesterday, runs pretty smooth /forums/images/graemlins/shocked.gif
let me know, any feedback. etc.
thanks to all...............
good luck,
bluebonnet2
/ 2 cyl diesels??????? #2
My John Deere 650 was a 2 cylinder Yanmar diesel. Ran great with no problems, did not notice any excess vibration. Some of the Kubotas (BX1500) use a large counterweight to offset some of the vibration in this small engine. I think the difference is the Yanmar was a much heavier built motor.
Ken /forums/images/graemlins/smile.gif
/ 2 cyl diesels??????? #3
I have a Yanmar 1500D with a 2 cyl diesel. Runs great and really rugged. Go to the Yanma Board this site. Many of the Yanmar greys are 2 cyl diesels
Larry
/ 2 cyl diesels??????? #4
Yanmar makes a one-cyl diesel as well. Smooth? Not as smooth as a two, which is not as smooth as a 3, etc. Doubt there would be a market if they were 'not smooth'. /forums/images/graemlins/wink.gif
/ 2 cyl diesels??????? #5
My experience has been that its only evident at lower RPM's, and I don't know too many people who use their tractors at idle.
/ 2 cyl diesels??????? #6
There are lots of two cyl. diesels out there. The larger two wheel tractors (14 hp) use them. Other brand names include Deutz, Hatz, Lombardi, etc.
/ 2 cyl diesels??????? #7
I have read on many occasions that a two cylinder actually develops more torque than a 3. They tend to be a little louder than 3 and 4 cylinder engines, but not a problem.
You will find that many twos are older tractors, such as the YM2000 or any other YMXX00 model. 00, 01,02,10,20 and FXX are older to newer.
Don't be too concerned about the "hammering" sound in the Yanmar two cylinder, it's normal. You need to read as much as possible in the Yanmar forum if you're considering Yanmar. There are some gray market Yanmars that are easier to find parts for than others, and you need to know which they are. John
/ 2 cyl diesels??????? #8
My old Ford 1700 is a two cylinder diesel made by Shiabura.
Its been a pretty solid unit for me...
/ 2 cyl diesels??????? #9
Yanmar comes to mind... though there are others. Yanmars with the 2cyl exhibit the 'yammer hammer' sound.. which is kinda close to the pop-pop of a big old JD 2cyl gas job.
Soundguy
/ 2 cyl diesels??????? #10
A couple years ago, I had some crushed granite delivered to topcoat my circle drive, between loads, I was on my Ford spreading the stuff.
Once the last load was dumped, I idled down and got off to pay for the material... the truck driver was an older guy who smiled at the sound of my old Ford at low idle... he too said it brought to mind the old "Poppin' Johnnies" of his youth... but I bet mine is easier to start! /forums/images/graemlins/grin.gif
/ 2 cyl diesels??????? #11
</font><font color="blue" class="small">( anyone using this type engine.....looked at a yanmar yesterday, runs pretty smooth ... let me know, any feedback. etc. )</font>
I love my 2 cylinder Yanmar. Yes, its a thumper.
I think that's what a tractor *should* sound like. Its harvest season now and I hear the old tractors in the area brought out to work, chugging around in the orchards. This thing sounds like all that old American iron, not like a forklift or something.
There's something aesthetically correct in a machine that runs flawlessly and is as simple as can be made.
If you're asking are there any problems inherent in this configuration - I don't think so.
/ 2 cyl diesels??????? #12
My Mitsubishi has a pretty good ring to it when it's cold, but quiets down when it warms up. There is some vibration, but not as much as on a Harley Davidson. /forums/images/graemlins/grin.gif
/ 2 cyl diesels??????? #13
</font><font color="blue" class="small">( My Mitsubishi has a pretty good ring to it when it's cold, but quiets down when it warms up. There is some vibration, but not as much as on a Harley Davidson.)</font>
That's funny! I was staring at the 2cyl diesel in my Kubota BX1500 yesterday thinking it would make a darn good engine for a motorcycle - especially if you took that large counterweight off the top. It is small (599cc) and makes an OK amount of power for an around-town-only motorcyle, like an Enfield.
/ 2 cyl diesels??????? #14
IMO, no way is it close to the 'big old' diesels. The size of the pistons in those two-cyl diesels and the yanmar, along with the rpm isn't 'close' (again, IMO). The two-cyl yanmar has the higher rpm of the two-cyl small upright engines that Deere put in the M's, 40's, and 420's series. Each to their own recollection though. /forums/images/graemlins/wink.gif
Maybe a tiny ball pien hammer compared to a 6 lb sledge? /forums/images/graemlins/grin.gif
Just kiddin with ya.
/ 2 cyl diesels??????? #15
I wasn't compairing engine specs.. or anything 'technical' in nature.. only the similar sound pattern. The JD makes a distinct throaty pop-pop The yanmar.. though higher in pitch.. still exhibits pattern of two back to back sounds.. kinda like a chug-chug...
Soundguy
/ 2 cyl diesels??????? #16
The Yanmar chug-chug sound:
On an inline twin cylinder designed for one piston down while the other is up, they fire 180 degrees apart then nothing for another 540 degrees of crankshaft rotation.
This 'trademark' sound is immediately noticeable, and different from most other engines which can be arranged to fire at even intervals.
The first time I noticed this was when the first Honda motorcycles arrived, 250 and 305 cc side by side twins. They sounded completely different from how everyone thought a motorcycle 'should' sound.
/ 2 cyl diesels??????? #17
</font><font color="blue" class="small">( Once the last load was dumped, I idled down and got off to pay for the material... the truck driver was an older guy who smiled at the sound of my old Ford at low idle... he too said it brought to mind the old "Poppin' Johnnies" of his youth... but I bet mine is easier to start! /forums/images/graemlins/grin.gif )</font>
If your talking about an old JD diesel two-cylinder, then you are correct. An old JD gas two-cylinder with electric start would be easier to start - it only has to hit on one cylinder! My gas model 70 is by far the easiest starting tractor/piece of machinery I've ever had or encountered. Turn ignition on, bump throttle forward a hair, step on the starter switch and it's a poppin'. It really does sound neat to hear a 379.5 cubic inch two-cylinder motor under load... /forums/images/graemlins/laugh.gif
Though, my dads Kubota wins in the luxury/smoothines/ease of use category. /forums/images/graemlins/wink.gif
/ 2 cyl diesels??????? #18
If you took off the counter weight it'd probably shake enough to bust all the welds in an Enfield's frame. /forums/images/graemlins/tongue.gif
/ 2 cyl diesels??????? #19
The only tractor my oncle had for many years for his dairy farm was a 1969 Renault 2 cyl. 30HP (I don't know the model). It's sound was unique in the village (tuck-tuck-tuck-tuck...)
/ 2 cyl diesels??????? #20
</font><font color="blue" class="small">( </font><font color="blueclass=small">( Once the last load was dumped, I idled down and got off to pay for the material... the truck driver was an older guy who smiled at the sound of my old Ford at low idle... he too said it brought to mind the old "Poppin' Johnnies" of his youth... but I bet mine is easier to start! /forums/images/graemlins/grin.gif )</font>
Though, my dads Kubota wins in the luxury/smoothines/ease of use category. /forums/images/graemlins/wink.gif )</font>
Never head an old 2 cylinder JD 70 run, but it is anything like my 60, ........ How about the old diesel "R" model..... that was said to have some HP back then....for a 2 cylinder. /forums/images/graemlins/shocked.gif
WHEEL LOADER FORK ATTACHMENT (A67714)
WHEEL LOADER FORK...
2014 BOBCAT T870 SKID STEER (A65056)
2014 BOBCAT T870...
2023 Landmaster L5W (A64912)
2023 Landmaster...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2016 Ford F-150...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
