2-cycle oil ratios?
/ 2-cycle oil ratios? #41
Ethanol Free is something I need to import...
Greetings from one Oakland resident to another... Oakland California to Oakland Oregon.
Always wanted to check out Oakland Oregon... one of these days...
Around here "Marine Gas" is ethanol free, and I don't know anywhere there aren't boats
When I go to websites for ethanol free nothing shows up in an area of 9 million people in my part of California...
California Ethanol Free Gas Stations
Friends that live in Oregon say they have no problems finding it.
Going the option to buy in quarts at home depot works out to be about $25 a gallon.
Just confirmed that ethanol free fuel is not available at here... the fuel docks only sell ethanol fuel with an additive pack and currently a gallon with set you back $4.25.
The only place I have been able to find it outside of quart cans is from a racing fuel blender in 55 gallon drums...
/ 2-cycle oil ratios? #44
Maybe you can stock up when you are at your place in Washington?
Olympia CFN 89 92 Acme/Fast Fuel 360-943-1133 303 Thurston Ave Ne 2014-03-25
Olympia UNBRANDED Boston Harbor Marina 312 73rd Ave Ne 2013-01-25
Olympia CFN 92 Fast Fuel / Acme Fuel 505 Lilly Rd Se 2014-06-08
Olympia UNBRANDED 87 Steamboat Trading Post 360-866-8009 6610 Sexton Dr Nw 2015-02-17
/ 2-cycle oil ratios? #45
I've run 50:1 in all my Stihl saws and 2 Echo weed eaters, and 1 Jonsered brush cutter/weed eater for at least a few years. Recently I found a local NON-E-10 gas supplier, and now only use NON-E-10 gas. I don't store any gas in vented containers anymore. ALL the gas I use in my 2 strokes is available ONLY as high test; there is no low octane gas available as NON-E-10. One reason this is the case in VT, from my understanding, is that snowmobilers are a big contributor to our economy. So, between boating in spring and summer, (this year spring will occur around early June, and summer will end around mid-August; I STILL have snow on the ground!):eek: and snowmobiling from July 30th 'till heII freezes over... There is plenty of demand for E-10 free gas.
As to vintage cars, like T's and A's, they aren't 2 stroke engines; their engines were made of real steel, iron, etc. They ran on leaded gas, which coated the valves, etc.
Can't say whether detergent oils would hurt them or not, nor what to run for gasoline to get them the octane they need from what's available today. But, I seriously doubt their tolerances are that tight even after a rebuild- they didn't need to be back then, but I could be wrong, so if so, please feel free to correct my thinking.
With the last 20+ years of two stroke weed eaters/chain saws, etc. the metal used and tolerances are closer when new that ever before. Synthetic oil is a great improvement over everything prior, and allows for a lot of good outcomes that just weren't previously available. Synthetic oils have allowed manufacturers to guarantee saws for longer periods, when used exclusively with their specific brand of oil mix.
Engines run better in conjunction with synthetic oils and NON-E-10 gas. Everyone of my friends in the chain saw/weed eater, brush cutter, 2 stroke business, selling these tools, recommends 50:1 mix. I had a hard time at first thinking things specked to different ratios would stand up. They all have without exception. YMMV.
I keep forgetting California might as well be a different country with how there are 49 State regs and California regs... needed to buy a toilet for rental... the same as always and learned there is a ultra-low flow 1.28 and it is the only model that can be sold... just like buying paint to refinish my old cars... so it only follows that fuel and power equipment has to be different too.
Boston Harbor Marina in very close by...
/ 2-cycle oil ratios? #49
It's about a 7 hour drive. Same name, that's about it! Lot's of property for still for sale.
Looks like a nice part of the country where a person can still buy acreage.
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61573)
2005 Stertil Koni...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
2018 Infiniti Q60 AWD Coupe (A61574)
2018 Infiniti Q60...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
2001 CHAPPARAL B/STOCK TRAILER (A64280)
2001 CHAPPARAL...
