1st Box Blade work
/ 1st Box Blade work #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
Here are some pictures of my first attempt at a box blade. There is a drainage ditch down one side of the property and a low swampy spot on the other. I used a box blade to make a swale to drain the water from the swamp to the ditch. The first picture is standing in the swamp area after a good rain. You can see some puddles. Now I know where the high spots are. Since I did not have very much slope from one side to the other I dragged all the extra dirt into the swampy area to raise it up. Once I ripped off the vegitation with the BB things went pretty well. What I would do for a hydralic top and tilt. /forums/images/graemlins/blush.gif
Eric
From the ditch
/ 1st Box Blade work #2
Good job! As you said, now you know where the high spots are... mark them and try to work them out when it dries. I've done the same thing here to try and drain areas where water stands and had excellent results.
2020 VOLVO EC140EL EXCAVATOR (A65053)
2020 VOLVO EC140EL...
Bear Statue (A64557)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
