Menu
Forums
Today's Posts
New posts
Search
Marketplace
Private Party
Auctions
Database
Quick Review
Quick Owner-Page
Register
Log in
Join
What's new
Search
Search
Everywhere
Threads
This forum
Search titles only
Today's Posts
New posts
Search
Filters
Keywords:
Started by:
Last updated:
Any time
7 days
14 days
30 days
2 months
3 months
6 months
1 year
Hidden from guests
Sort by:
Sort order
Last message
First message
Title
Replies
Views
First message reaction score
Sort direction
Descending
Ascending
Menu
Log in
Join
Main
General Tractor Topics
You should upgrade or use an
alternative browser
Hydraulics
Discuss all issues relating to hydraulics in this forum.
Prev
1
Go to page
Go
38
39
40
41
42
Go to page
Go
274
Next
First
Prev
40 of 274
Go to page
Go
Next
Last
Filters
Show only:
Loading…
Filters
Kubota 1640A loader connections
matoyan
Mar 6, 2022
Replies
1
Views
6K
Mar 6, 2022
matoyan
3rd Function hoses dragging - looking for a good solution
Root Cause
Mar 3, 2022
Replies
18
Views
6K
Mar 6, 2022
Midniteoyl
H
Kubota LA853 Hydraulic Hoses
hazamat
Mar 5, 2022
Replies
5
Views
3K
Mar 6, 2022
Smokeydog
S
P
Hyd oil question
panamaguy
Mar 4, 2022
Replies
3
Views
1K
Mar 5, 2022
Billrog
B
C
3 point
cheesehead22
Mar 5, 2022
Replies
4
Views
664
Mar 5, 2022
LD1
T
New hydraulic top link won't clear the lift arms on my B-series
tallguy104
Feb 28, 2022
2
Replies
39
Views
9K
Mar 4, 2022
Outinstickssnafu
O
B
Hydraulic questions
Bayou man
Mar 4, 2022
Replies
0
Views
568
Mar 4, 2022
Bayou man
B
Adding budget rear remote
Skramps
Mar 3, 2022
Replies
2
Views
2K
Mar 3, 2022
Skramps
C
Switching FEL valve body to another.
Chainsaw.
Feb 27, 2022
Replies
18
Views
3K
Mar 3, 2022
LD1
M
b3030 lifting capacity
marky22
Mar 2, 2022
Replies
5
Views
2K
Mar 3, 2022
LD1
E
Best way to shorten cylinder rod?
etpm
Feb 19, 2022
2
3
Replies
40
Views
8K
Mar 2, 2022
etpm
E
F
Hydraulics
Fornshell
Mar 1, 2022
Replies
5
Views
950
Mar 2, 2022
Fornshell
F
Corect type and size hose to run to the front from rear remotes.
powerscol
Dec 3, 2014
2
Replies
20
Views
33K
Mar 1, 2022
Oldtoad
O
A
Adding additional hydraulic circuit to JD 410 backhoe
acadie1
Feb 28, 2022
Replies
1
Views
4K
Feb 28, 2022
Tx Jim
Kubota load sensing pump system
Hersheyfarm
Feb 25, 2022
Replies
4
Views
3K
Feb 26, 2022
oldnslo
O
P
Kubota M59 Hard Steering when cold
Pushrodder
Feb 22, 2022
Replies
14
Views
6K
Feb 25, 2022
Smokeydog
S
D
kubota bx24 2009
dennynep
Jan 26, 2022
Replies
3
Views
1K
Feb 23, 2022
dennynep
D
Hydraulic Side Tilt For 3PH--Single or Double Acting?
npalen
Feb 19, 2022
2
Replies
33
Views
7K
Feb 23, 2022
npalen
H
Kioti KB2375 Backhoe Valve block rebuild
Han Solo
Feb 23, 2022
Replies
0
Views
2K
Feb 23, 2022
Han Solo
H
D
What is this part called
Dandolore
Feb 23, 2022
Replies
7
Views
2K
Feb 23, 2022
npalen
K
no loader down force
Kep1a
Feb 16, 2020
Replies
10
Views
12K
Feb 23, 2022
Range rider
R
F
Jhn deere 4105 rockshaft
flem70
Feb 20, 2022
Replies
10
Views
6K
Feb 22, 2022
NWOutlawMX
B
l245dt loader valve
bky
Feb 20, 2022
Replies
4
Views
892
Feb 21, 2022
oldnslo
O
Kubota B3200 adding remotes and 3rd function
Tjaltz
Feb 19, 2022
Replies
13
Views
11K
Feb 20, 2022
K5lwq
I
Iskei tu2100
Iseki58
Jan 25, 2022
Replies
8
Views
2K
Feb 20, 2022
Iseki58
I
Adding Rear Spool Valve to PB port with 3rd Function Downstream.
Woodstock Walt
Feb 16, 2022
Replies
16
Views
7K
Feb 17, 2022
npalen
S
2005 Branson 2910i hydraulic leak
Superflea
Feb 17, 2022
Replies
0
Views
625
Feb 17, 2022
Superflea
S
J
Yanmar 2210
JoeT.87
Feb 5, 2022
Replies
18
Views
4K
Feb 17, 2022
JoeT.87
J
I need Hydraulic Help Again with my Ford 1920.
Atvjoe
Feb 16, 2022
Replies
0
Views
790
Feb 16, 2022
Atvjoe
Converting 3PH Inching Control To Position Control?
npalen
Feb 16, 2022
Replies
1
Views
661
Feb 16, 2022
swreeder
C
rear hydraulic connectors leaking
Critt
Feb 16, 2022
Replies
0
Views
511
Feb 16, 2022
Critt
C
J
Need help locating hydraulic cynlinder.
Jegart12
Feb 15, 2022
Replies
8
Views
1K
Feb 16, 2022
Jegart12
J
H
Trouble hooking up Bobcat backhoe, pressure wont release
Halfcoyote
Feb 13, 2022
Replies
17
Views
4K
Feb 16, 2022
Fxfymn413
F
S
Kubota B26 Backhoe lines - a PITA
stso9d
Feb 14, 2022
Replies
2
Views
929
Feb 15, 2022
stso9d
S
C
What is the definitive sighn symptom and diagnostic for cylinder piston seal wear and failure?
CalG
Feb 11, 2022
Replies
3
Views
1K
Feb 13, 2022
Vigo327
V
L
No down power on loader
liberty2701
Feb 11, 2022
Replies
9
Views
2K
Feb 13, 2022
PineRidge
A
MF 5455 warning light on
Apoel
May 7, 2016
Replies
2
Views
34K
Feb 10, 2022
Paul f maguire
P
R
2705 cub hydraulics filters
russellayers
Feb 9, 2022
Replies
1
Views
391
Feb 10, 2022
Tx Jim
L
Replacing Hydraulic Fuild Advice Needed
LSU-Mike
Feb 9, 2022
Replies
5
Views
1K
Feb 9, 2022
jyoutz
L
Advice on using existing connections
lacasmi117
Feb 6, 2022
Replies
5
Views
1K
Feb 9, 2022
Dave M7040
D
R
PTO Not Engaging / weak
riderpriderking
Nov 22, 2018
Replies
11
Views
33K
Feb 8, 2022
nateashfield
N
B
Using a power beyond steering valve without the PB function?
BadDecisions
Feb 2, 2022
Replies
13
Views
7K
Feb 8, 2022
BadDecisions
B
W
steering rack dynahoe
WreckItSmith
Apr 24, 2015
Replies
1
Views
783
Feb 7, 2022
Timmy1957
T
S
log splitter help
SCWOOD
Feb 7, 2022
Replies
8
Views
1K
Feb 7, 2022
LittleBill21
W
kioti dk35 hydraulic lift keeps going down on fluid
weldonjr
Feb 4, 2022
Replies
8
Views
2K
Feb 7, 2022
LD1
S
Genie TZ-34/20 Towable Boom Lift - Hydraulic Motor Issue
SSNJOHN
Feb 5, 2022
Replies
3
Views
8K
Feb 7, 2022
BeezFun
B
J
Massey 165 MK2 Hydraulic lift not lifting
Johan Venter
Feb 6, 2022
Replies
4
Views
4K
Feb 6, 2022
Johan Venter
J
W
Kioti dk35 Ps does anyone have a diagram of this pump
weldonjr
Feb 5, 2022
Replies
0
Views
822
Feb 5, 2022
weldonjr
W
R
Kubota 2380 Hydrostatic question
rockarosa
Feb 4, 2022
Replies
4
Views
1K
Feb 4, 2022
rockarosa
R
J
How do I determine if hydraulic pump need to be rebuild?
JennWho
Feb 2, 2022
Replies
6
Views
5K
Feb 4, 2022
rScotty
Prev
1
Go to page
Go
38
39
40
41
42
Go to page
Go
274
Next
First
Prev
40 of 274
Go to page
Go
Next
Last
You must log in or register to post here.
Main
