ETD66SS
It sounds like they need to spend more time designing a better space toilet...You should go ahead and send the specs and your proposal to NASA. I think they're just now finalizing design for the Moon station laundry room.
Looks good, I have to wonder if 3-4 inches of spray foam wouldn't have a better effective insulation value.
Many of the contractors I have talked to gave spray foam a thumbs down, especially in a metal sided/roofed building.Looks good, I have to wonder if 3-4 inches of spray foam wouldn't have a better effective insulation value.
The closed cell does transmit sound, I have it in my ceiling and even on the asphalt shingle roof with an air gap between the foam and interior sheathing then the tongue and groove pine rain fall can be heard.Many of the contractors I have talked to gave spray foam a thumbs down, especially in a metal sided/roofed building.
Condensation between the metal/osb and the foam was the biggest complaint. Next was sound transmission through the foam. I guess it's nowhere near as quiet as fiberglass or rockwool.
I gapped my spray foam off the metal roof by installing 1" blue foam board on the purlins, before having the rafter bays filled with spray foam. The backside of the steel is still ventilated from soffit to ridge, above that foam board.Many of the contractors I have talked to gave spray foam a thumbs down, especially in a metal sided/roofed building.
Cougar Shield is what the builders used on my metal roof. I was told it was better than the roof steel with the felt layer on the backside for condensation control.I gapped my spray foam off the metal roof by installing 1" blue foam board on the purlins, before having the rafter bays filled with spray foam. The backside of the steel is still ventilated from soffit to ridge, above that foam board.
Most spray foam contractors just spray right on the underside of the roof, and claim there's no issue with condensation, as there's no air infiltration from which moisture can possibly condense. That's actually solid logic.
The only reason I bothered with the foam board was thoughts of someday having to replace the metal roof, and nightmares over finding replacement with the same exact corrugations to fit the foam that's now been molded to the underside of the old roof.
I can't comment on noise transmission, as I never had this particular building insulated any other way, for a true comparison.
Wouldn't that have to be applied before the roof? I was working under a 20 year old roof in a 240 year old building, built from parts reclaimed from some even-older building. I was just thrilled when I found two actually-parallel rafters, let alone any consistency in spacing, etc.My builder used regular house wrap as a shield between the exterior metal and spray foam.
I'd like to sub out the drywall, but have not gotten any quotes yet, so will decide that based upon cost.Are you going to do everything yourself to finish it?
You got that right bro!If you hire out the drywall, be sure to take video or pictures of every wall so you can see where your outlets and switches are. Seems like there is always at least one box that gets covered up by the guys hanging it.
It seems like they would notice the hump in the wall...If you hire out the drywall, be sure to take video or pictures of every wall so you can see where your outlets and switches are. Seems like there is always at least one box that gets covered up by the guys hanging it.
You would think. But it's not super noticeable when they miss one.It seems like they would notice the hump in the wall...
