ponytug
Super Member
They should only spin in the bolt, but I grease both. (Same friction on both surfaces, and the bolt area is smaller, so it spins there. Make sense?) I have some large diameter washers over the bushing, but I couldn't tell you if that was from the factory, or something I got from McMaster-Carr. I would have to check my stock.I greased the bushings once at installation, but not since then say 19-20 hours before failure. Now wondering if I need to grease them before every use or 6-8 hours?
These bushings are tight inside the hole in the blade and don't spin inside the blade. They do spin around the bolt shaft. Are yours free to spin inside the hole in the blade, too?
Based on a very small set of conditions here, I think that grease intervals is dependent on mowing conditions. Observationally, mowing in cool, wet grass/brush, less grease comes out of the bushing area, and dry, dusty/sandy conditions seem to drive the grease out.
Sounds like fun! Videos? I will hope that nothing sharp gets a tire.Wow. I good day for me is not blowing a blade off hitting a rock!I always find the blade, but the bushing is gone. I'm down to my last few bushings. I'll have to order another piece of DOM tubing to cut some more.
I have to head out to our property in the next few weeks. I haven't been out there with the brush cutter since probably COVID. I went out last weekend to clear the road entrance with a chainsaw so I can get the Suburban and trailer off the highway. Everything is 6' high on my road. It will be an adventure, for sure.
I don't think I have ever lost a blade, except from a bolt that worked loose, and that only happened once. I grease the blades and bushings and then tighten the bolts before heading out. I seem to hear when the bolts loosen a bit, and stop to tighten them while it is still on the hub.
I do sharpen and balance the blades each years because it makes such a difference to the mowing speed/HP and the performance (clean cuts, small pieces) when the blades are sharp. These days most of my mowing is bull/milk thistle or 6-8' mustard, both of which seem to have pretty tough stems, but they are nothing to the scrub oaks that I had to mow initially. PT brush mower for the win.
All the best, Peter
