CigTopGun38
Member
- Joined
- Jan 19, 2025
- Messages
- 37
- Tractor
- JD770
Thanks for the tips. Will adjust the mower deck height.You was premature on changing the hydraulic fluid imo but it won’t hurt anything.
As mentioned tighten the lower hose clamps & top off the coolant level.
When mowing in dry & windy conditions : keep a check on your temp gauge.
IF you’re getting grass clippings blown back on you (my chute is removed) your radiator is getting clippings & dust sucked into it.
I have to dump my radiator screen when temp gets too hi Before the horn sounds.
Make sure BLADES (not deck) measure dead level off concrete floor mowing at about 3.5”
Any lower & you’ll be complaining of scalping.
The deck knob #’s don’t always match blade measurement off concrete floor.
Adjust front deck wheels 1” off the concrete too.
Keep rear tires aired up pretty firm & you’ll absolutely love the Diesel 72 inch.
To clarify. I didn’t swap hydro fluid. Just the filters. And replaced whatever I lost. It’s cheap insurance for me.
The mower had some grass in the radiator when I picked it up. I’ve since cleaned it. Wasn’t a ton.
I’ll scope out the hoses to make sure they aren’t leaking. I spoke to previous owner. He said he never topped it off from new. Said it never over heated. And always had low coolant in the reservoir.
