warrior_garden
- Joined
- Mar 11, 2026
- Messages
- 14
- Tractor
- Kubota L5240 HSTC
New member here, I've read many of the threads discussing 3-point ballast and believe I have a good idea of how much it should weigh, but I'd like recommendations. I'm planning to build my own box using a plywood form. Ideally I would be able to add or remove weight depending on the weight in the FEL, but that isn't in the cards right now.
The tractor is a L5240 HSTC with 854 loader, R4 tires loaded with Rimguard. I'll be using the factory bucket or EA Wicked grapple. The LA854 loader weighs 1,300lbs, the bucket weighs 300lbs. Estimated total weight of everything is around 7k lbs. My primary "concern" is moving logs over fairly hilly terrain.
My plan to construct a very low and wide ballast box, and I'd like to keep the weigh fairly close-in to the rear axle to reduce the chance of swinging weight. I'm shooting for around 1,300 lbs. Thoughts?
