SSQA - is there a standard/conventional width?
/ SSQA - is there a standard/conventional width? #21
He said it was a cheap Ebay item..
Sounds like the adapter might be some kind of low-end, off shore adapter, kinda slapped together?
Not accusing you of being cheap.
Oh in this instance yes I am cheap. The plow is a resurrected 7' rear blade I got for cheap as it was. However, I discussed with the dealer on plow options but with the hydraulics and what they had available it was going to be many thousands of dollars more to get one set up. We were already in to many thousands of dollars (about $11k) in front end equipment and hydraulics so I went the other way and adapted what we already had.
Interesting note - the SSQA to 3pt adapter from Ebay was in the lower $200's if I recall. I was browsing Everything Attachments and they want over $1000 for one. Crazy.
/ SSQA - is there a standard/conventional width? #23
Yeah, but that’s what it costs for quality American or Canadian attachments.
Here was mine. Converts Euro/Global to SSQA.
I don’t mind paying a price for quality, but USA/CD made stuff is now commonly 3 times the price of crap.
The last SSQA I had was my snowplow, I have sold that one.
/ SSQA - is there a standard/conventional width? #24
I was swapping front end equipment this afternoon so I did some measuring. Aside from being still pretty cold (temp in the teens) we had a nice day here.
First up is my fork set.
This measures about 45-1/8". This is a Land Pride fork set.
Next is the bucket.
This measures about 45-1/16".
Next is the grapple. This one I had trouble getting the tape to cooperare for the measurement.
This comes out to about 45-1/2".
Next is the loader arms on the tractor that mate to the SSQA receivers on the implements.
This measures about 44-5/8". See more detail below regarding this number and the associated clearance.
Next is the SSQA to 3pt adapter we have.
This measures right about 44-1/2".
When I try to hook up to this adapter this is the result:
Left side -
Right side -
So for now what I do is squeeze the loader with a large bar clamp:
That gives me just enough "squeeze" to clear the adapter and connect:
Needless to say, the clamp method on the loader like this is a pain in the butt. But it works.
When the weather warms Ill cut the sides of the adapter pate and lay more metal over that to open up another 1/4" on each side (1/2" total).
My gut tells me much less than 3/8" clearance total would make mating the loader arms unnecessarily difficult.
I bought the same exact adapter from Ebay and have had no problems connecting it. I'm going to measure mine and compare, I measured the adapter plate today 44 3/8 but no problems. Very happy with the quality.
/ SSQA - is there a standard/conventional width? #25
I got the adapter from eBay and it works fine. People might think I am foolish for buying CCC (Cheap Chinese Crap), I think they are foolish for spending four times more for American steel.
/ SSQA - is there a standard/conventional width? #26
Then call me a fool, but I can’t deal with stuff made that cheaply. I also am doing more commercial usage than the average TBN’er
My Ebay CCC adapter was actually about $500. It was an Euro to SSQA adapter though and they cost more than the OP’s adapter.
American made was $1,150. So it was a little more than double the price.
I had to learn that lesson the hard way.
The US made fit perfect, the handles didn’t have sharp edges to cut your hands, and the springs actually held the handles in the up position when releasing.
Well worth it, IMO.
China sucks lol
Buy once, cry once, etc.
Those are my excuses. YMMV.
/ SSQA - is there a standard/conventional width? #27
Well worth it, IMO.
China sucks lol
Well, we are comparing apples to coconuts:
The adapter for SSQA to 3 PH does not have handles (a minor issue anyway as sharp edges are solved with 20 minutes of grinder work or a file) or springs (that could be upgraded for $50 or less). I don't expect the same build quality on something that is 1/2 the price of the "good stuff". But I am not a contractor.
I cannot justify spending the premium, so I either do without or buy the CCC. And I cannot take a tax write off on most of the stuff I buy. I have to play with my own money.
I bought a CCC SSQA plate for a custom attachment I designed for lifting bulk bads of wood. I paid $110 for it delivered. When I took it to the shop the owner of the shop criticized some of the welds but was honest enough to admit it was a steal. He said he could not have bought the steel at that price. He beefed up the welds at minimal cost and I have lifted over 2000 pounds with it multiple times without problems.
/ SSQA - is there a standard/conventional width? #28
Yeah, not everything is to specs.
Seriously just grind a quarter inch off the edges and you're good to go. I had to do a similar thing to my brand new hyd bucket. It sucks doing it to a new item but it is what it is on farm equipment./
On my '21 LS Mt235 when connecting to my new el-cheapo forks it fits fine at the top but the plunger locks are just barely touching the edge of the holes and the brand spanking new LandPride (Kubota) 4in1 hyd bucket I bought I had to grind at least 1/4 inch from the bottom of the holes of the bottom lock pin plate as the plunger locks wouldn't fit. It's like the slots in the plate are too shallow on the bucket.
/ SSQA - is there a standard/conventional width? #29
Exactly! The first thing a personn should do on their new tractor is modify it - weld hooks on the bucket and forks, weld a hitch receiver, make a took box mount, chainsaw mount, etc. Why not? It's for work. I've also seen trucks that look like they've never carried anything in the back either because it might scratch the bed.
/ SSQA - is there a standard/conventional width? #30
You can see the extra steel on the “ear” on the side of the SSQA plate. There’s plenty of steel that can be ground off without compromising anything.
The clamp he’s using is hilarious. We would have ground off the plate, or bought a properly fitting adapter after about the first minute of that nonsense.
/ SSQA - is there a standard/conventional width? #31
I don't understand the OP's concerns about grinding a bit of useless steel away while apparently thinking that blade setup is OK. I don't see any trip mechanism and it appears the only "float" that can happen is with the weight of the loader frame on the blade.
/ SSQA - is there a standard/conventional width? #32
Likes been mentioned if you look at the edge of the loader plate you can see it's tapered so it has no weight bearing on it at all on the edge so there's no issue with grinding it down a 1/4 inch on each outer edge on each side. Imagine what's going to happen when it get's to 80+ degrees as the metal will expand that much further so you would have had to do it in the summer anyways if it was a tight fit in the winter.
I fully understand the OP and not wanting to grind and bang on a new expensive machine but he has to understand it also is not a car with nice fit and finish.
Once the loader is out of the jig, how many times has it been hit, dropped, banged, oops slightly hit it going in the crate, oops dropped it getting it out of the crate. So yeah things happen. Just use common sense and all is good.
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A64556)
2009 Chevrolet...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
2006 International 4400 Horton Emergency Truck (A64556)
2006 International...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2025 DELCO T/A 24FT GOOSENECK TILT DECK TRAILER (A67148)
2025 DELCO T/A...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
