Homemade wooden snowplow - thoughts?
   / Homemade wooden snowplow - thoughts? #21
I'm open to suggestions or criticisms and thoughts. Just an idea I had running through my head.
For me, during a snowstorm or directly after is when I really want my snow removal equipment to be in top form and fully operational. A plywood plow on a tractor that size is only going to last until you hit an unseen rock, curb, crack or other obstruction, at which point you'll be making a new one. If that's ok, and moving snow is more of a hobby, it'll work for a little while.
   / Homemade wooden snowplow - thoughts? #22
I've had numerous makeshift plows in my life. Currently I use a Case 580 Super N with no snow equipment, just a bucket.
In my youth we had a different climate. 1970/1971 we had enough snow to ride snowmobiles onto the roof of a high elevation 1-1/2 story camp near here. Recent years not so much. I plow fewer driveways now.
Worst plow rig I've had was a Fisher blade mounted instead of the bucket on a farm tractor. It was constantly snagging on something & the tractor tried to climb over the plow.
A snow plow must float on the ground. The push frame must pivot freely & pivot near the ground.
   / Homemade wooden snowplow - thoughts? #23
Grandfather used wooden homemade snowplow on the front of his Alice Chalmers B for many years, seemed to work pretty decent. Not sure exactly how he raised and lowered the plow but it was some kind of homemade lever system.
   / Homemade wooden snowplow - thoughts? #24
Interesting conversations. Makes me glad I live in Texas!
   / Homemade wooden snowplow - thoughts? #25
>I have a Kubota MX6000 cab tractor. Normally I use a 7' rear blade for snow plowing. However, it is a pain to be looking behind you all the time. What do you guys think >of making a wooden front plow?
Not to sound negative, but I can't imagine it would work for any real plowing. I could see it falling apart on the first snow bank you push into. Plowing has tremendous forces involved. Wood just can't handle it. I think what the other guy did with the door was just mount it over his loader bucket. The bucket took all the force, and the door just prevented it from filling with snow. Would be way easier to make a mount for the loader with a real plow that you can buy used.
   / Homemade wooden snowplow - thoughts? #27
Just a cheap truck (electric winch) plow that I found for sale $150. Have to say I love the way it works, manual angle, but no complaints. Tried the blade mounted directly to the loader arms, wasn't happy with the float, this setup however works excellent.
   / Homemade wooden snowplow - thoughts? #28
Plows take a lot of force. I don’t think a wooden plow would survive very long. I attached a 7.5’ plow to a SSQA plate. Has hydraulic blade angle adjustment. Plow hangs from a chain so it floats to follow the driveway nicely. Paid $100 for the plow. Painted it up and it looks and works great.
   / Homemade wooden snowplow - thoughts? #29
Don't waste your time with wood find a metal one
   / Homemade wooden snowplow - thoughts? #30
I have a Kubota MX6000 cab tractor. Normally I use a 7' rear blade for snow plowing. However, it is a pain to be looking behind you all the time. What do you guys think of making a wooden front plow?
Here's what I'm thinking:
1.) Buy a 1/4" SSQA metal plate
2.) Buy a 4x8' sheet of 5/8" flooring plywood ; cut it in half the long way for two sheets of 2' x 8'
3.) Using large thick washers and heavy duty bolts, bolt the doubled-up sheets of plywood to the SSQA plate. Next, screw a couple of 2x4x8 boards to the plywood "plow" just above and below the plate, for some additional rigidity.
4.) Use a couple of pieces of angle iron 8' long - one on the back and one on the top, bolted together through the wood at the bottom, as a cutting edge of sorts and to protect the wood.
5.) Paint everything for a bit of waterproofing effect
Obviously this "plow" might now last for more than a season or two, but the only thing needing to be replaced would be the wood. It seems like minimal effort to have a functioning front plow. A couple of wooden wings on the front would essentially create a snow pusher. The whole setup would be light enough to where the wood would just break before any loader arms got bent or anything like that, but still heavy enough to put the loader in "float" and scrape the snow.
Have you thought about installing in a backup camera that will point at the rear blade? They are cheep and you can wire them to stay on all the time. That way you can monitor the blade by looking at the screen when looking forward.
   / Homemade wooden snowplow - thoughts? #31
I fabricated my FEL plow from steel, on a low budget.
There are lots of plows, and parts out there used.
Unfortunately, now is obviously the worst time to get one cheap.
   / Homemade wooden snowplow - thoughts? #32
Pay once, cry once. Get a steel blade and be done with it. It only costs twice as much to do it the correct way the first time
   / Homemade wooden snowplow - thoughts? #33
your asking for trouble … to make it sturdy enough plus your fabrication time plus future damage = not worth it regardless the way you look at it
   / Homemade wooden snowplow - thoughts? #34
I have not seen any used snow blades with SSQA for cheap money at all.
I actually have a 9' Fisher hydraulic angle plow that I could weld a SSQA plate to, but I think that's a bit too heavy for my tractor and risking bending the arms, despite the plow having a trip edge. One sheet of 5/8 Advantech is $53 and the SSQA plate is about $120 shipped. The angle iron might run me $75 for the two pieces, plus a few bolts and washers. I don't think I could have a functioning plow for less than $250.
I suggest cutting down the unused Fisher and putting it on an adapter plate. Remove the blade from the mounting frame, cut down the length and height to suit, and attach to plate.
   / Homemade wooden snowplow - thoughts? #35
What I do with my MX6000 works great and it’s a cheap option. I installed some edge tamers to my loader bucket and then turn my rear blade 180 degrees so it won’t pick up the road gravel. With the bucket pushing the bulk of the snow and my 8’ rear blade angled to clean the road it works great.
I have been using those edge tamers for 6 years now on my FEL for rural snow removal. We live in Wisconsin and get quite a bit of snow, and my Mahindra Max-24 surprisingly handles this well.
   / Homemade wooden snowplow - thoughts? #36
I made one, 4 years ago. It was easier to install/remove, as it sat insde my bucket. Like this guy here:
Mine is beefier than his cuz I used 2x8, I made it to follow the curve of my buckets sides. It doesn't break because i got 2 supporting upright pieces inside the bucket spreading the pressure and cutting the moment of force produced by snow weight. I covered it with old sheet metal for protection. It slides on a bedframe angle iron that i replace every other year depending on wear. The sides are 2x6 lagged and reinforced with angle iron and rods. It works awesome with the snot we been getting these last couple years instead of snow. The blower is useless in the wet stuff,
My 2 cents. Good luck
   / Homemade wooden snowplow - thoughts? #37
I made a sidewalk snow remover out of wood and it works pretty well for some scrap laying around. It's purpose was sidewalks only.
   / Homemade wooden snowplow - thoughts? #38
2x4's and angle iron will work for light snow or until you have frozen banks, and then you'll catch a corner of the plow and break it off...
You are running your rear blade pulling forwards? I do that unless I've got 8-10"+ of snow then I reverse it and plow backwards.
If you want to try the free plow with wood method, find a 10-12" diameter hard maple or white oak log and use that as your cutting edge support, then you might twist your loader up first before it breaks!
   / Homemade wooden snowplow - thoughts? #39
Years ago my uncle took a water tank and cut it in half to make a V snow plow. Mounted it on a Case 730, and found it was very hard to push thru deep snow because it had to push the snow to the sides. If you look at most road plows you find they lift the snow so it dosn't have to push all the snow to the side but lifts it over the snow at the side of the plow.
   / Homemade wooden snowplow - thoughts? #40
This is the setup I made for my Massey. I found a used ATV/UTV blade and hitch online and bought it, not cheap but a real nice blade. 60" Aluminum, could angle, with a large thick rubber edge.
I made a mount that would fit in my bucket, this is the second one, the first was too flimsy. The upright fit up under the lip to prevent the mount from riding up.
The chains were to hold it in place when dumping the bucket, because snow would fill it up. Also I could use the bucket for scraping and this way the plow would just lift up out of the way.
The blade floats up on those upright bars, and the rubber prevents damage to grass.
I would plow with the bucket a foot or so off the ground and let the blade float. I could tilt the bucket to assist cutting.
I could not back drag with this because the blade is meant to lay down when reversing. This was built for an ATV/UTV with no lift.
I could push snow well into the ditch, or stack it high, because it stuck out so far in the front of the bucket.
It worked well for a couple winters and then I found a nice Kubota snowblower that I modified slightly to fit the Massey.
If you want to make a plow out of wood use treated 2x8 or 2x10 lumber, not plywoood, and make sure to allow it to give rather than break.
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
Mower King Brush Cutter (A53317)
Mower King Brush...
20704 (A55853)
20704 (A55853)
2007 Nissan Frontier SE Crew Cab Pickup Truck (A59230)
2007 Nissan...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
200704 (A60430)
200704 (A60430)
