Can a stove draft TOO well?
/ Can a stove draft TOO well? #1
HawkinsHollow
SE TN
Branson 3015R
I just reinstalled our Englander 17-VL, just in time for the cold snap to get here. 9' of Duravent DVL double wall inside and 4 feet of Duravent Class A chimney leaving the vaulted ceiling living space. I fear the stove might draft too well with the new double wall flue pipes, is that possible? Even with the damper choked all the way down on lowest setting the stove is getting too hot. I think it is partially due to fuel load. Yesterday I burned all day and was able to keep it under control, nice slow burn with the secondaries just slightly kicking off. But I think that it might be because I did not stuff it full of wood. Last night when I packed it full for the night it took off like a freight train. Even choked down on the lowest setting it was on the verge of overfiring.
I put a new door gasket on it and it has a really nice tight feel when the door is closed so I don't think it is that. Anything else I should look at? After the stove cools off I am going to poke around under where the damper does it's thing to make sure it is sliding back and forth like it should. I know the damper is doing something because there is a noticeable difference between wide open and "closed down". Also might order a damper for the pipe leaving the stove as well. It is not a very nice feeling having a stove that you can't slow down if you wanted to.
/ Can a stove draft TOO well? #2
I guess it is possible to draw too well, but unless your damper is too small for your pipe, to me it is more of an inlet air/fueling item. If loading the stove up gives you issues, I would see whether you can restrict the primary air inlet(s) more, but leaving enough secondary air that you are getting good combustion, plus, of course, putting less fuel in, or in larger pieces.
FWIW: For overnight burns, I try to use larger diameter chunks to get slower burning, and less of a loading flare, although I do think every stove and installation has its own foibles.
All the best,
Peter
/ Can a stove draft TOO well? #3
I know when I installed my stove quite a few years ago I couldn't figure out why it looked like it was burning too much with the draft on the stove completely closed. The heat it put out would drive you out. Problem was it was supposed to be completely closed and couldn't be as there was a drilled 3/8" hole that was intentionally designed to be open when it was to the full closed position. I guess the reasoning was that you couldn't smolder the fire? Fixed that problem by making a new slide without the hole, now when I close the damper it all but kills the fire.
/ Can a stove draft TOO well? #4
The new EPA stoves do not shut down all the way to keep from having a smoldering fire. They want air flow to keep the exhaust clean.
I know on my stove at the cabin, I had to cut out a stop on the draft control to allow the draft slider to close tighter. It was keeping it a good 1/3 of the way always open.
You're going to have to trace your draft slider and see if there is a stop. If there is, take it out.
All the best,
Peter
I definitely try to do larger pieces of overnight burns, last nights had a few medium pieces in there. I can tell it is getting too much air when on it's lowest setting though. I tend to think it is an inlet air issue as well. After tonight it is supposed to warm up again so I am going to take the damper apparatus apart and see if something happened to it. Tonight as an experiment I am going to put a blast gate like you would have in a dust collection system on the inlet and see if I can restrict the airflow coming into the stove with that and see if it makes a difference. I also just bought an inline flue damper to add to the system.
/ Can a stove draft TOO well? #6
Careful. As the stove smoulder cools the slide will try to open but the thermostat coil may be unable to apply enuf force against vacuum. .. Then finally it jerks open a bit. That smoulder smoke is mildly explosive.
The are 2 main differences about the new setup that could cause these changes. I installed an OAK (outside air) and I installed double wall flue pipe. THe OAK is not plumbed into the stove yet, but it is loosely covered and only 8 inches from the stoves intake. But it is not like my house was ultra tight before the addition, it was built in 55. BUT the new air being introduced right at the inlet could play a role.
There is no thermostat coil on this stove. All manual.
/ Can a stove draft TOO well? #9
Do you have both a flu damper and air intake damper on that unit? Are you choking both down if so? Our unit uses a 14 inch ID flu. It drafts almost instantly with any heat. Even with a a 44-in fire box we have no issues controlling how hot it gets when using a combination of both air intake and flu dampers. If it only has an air intake damper, no flu damper it sounds like the unit is not restricting air flow enough
It does not yet have an inline flue damper. I just ordered one to install.
I think you are correct, I think the inlet air damper is not restrictive enough. But in the
previous install I never had a problem closing the inlet damper and choking the fire way down. Not sure what changed, but I will figure it out AND install the flue damper and be good to go I hope.
The other thing I noticed is it burnt that load up WAY too fast. I have a nice ash round and 2 large chunks of cherry and they were GONE in about 2 hours. That is unacceptable! I mean this stove has never been an all night burner but still, 2 hours is pitiful! Need better air control to get longer overnight burns.
/ Can a stove draft TOO well? #11
What changed on the reinstall? Single wall to double wall? Same distance?
Single wall to double wall and an outside air kit (that isn't plumbed into the stove yet but is covered loosely and 8 inches from stove inlet ). Maybe the stove got jostled around moving to and from storage and jostled something loose in the damper mechanism.
/ Can a stove draft TOO well? #13
I definitely try to do larger pieces of overnight burns, last nights had a few medium pieces in there. I can tell it is getting too much air when on its lowest setting though. I tend to think it is an inlet air issue as well. After tonight it is supposed to warm up again so I am going to take the damper apparatus apart and see if something happened to it. Tonight as an experiment I am going to put a blast gate like you would have in a dust collection system on the inlet and see if I can restrict the airflow coming into the stove with that and see if it makes a difference. I also just bought an inline flue damper to add to the system.
Our stove specifically states to NOT use an inline flue damper. So be sure to check that out before you proceed.
Anytime I've had a close to runaway fire it was related to the air control not closing all the way. (mine only has one control, so pretty simple to troubleshoot)
When that happened, I opened the door all the way and that killed the jet air effect instantly and it acted like a fireplace until I closed the door again. Of course, you should have a screen to put in front of it like a fireplace, too, if you do that.
/ Can a stove draft TOO well? #14
I don't think your single wall to double wall would make it suck that much more air. As long as the inside diameter of the pipe is the same, it should act almost the same. The main purpose for double wall is safety and decreased clearance to combustibles. It will increase your draft, but I can't find any real world measurements as to how much.
Check that linkage.
To be honest, I think my stove states that in the manual too. I wonder why.
Check that linkage.
I agree. I have a hard time believing that the double wall increased the draft that much, same with the OAK.
/ Can a stove draft TOO well? #17
We don't have outside air because our house is so drafty. 🙃 I can sit on the floor in front of the stove and feel a cold draft on my back.
/ Can a stove draft TOO well? #18
The change alone from single wall to double wall should have increased draft. Your flu gases are going to stay hotter longer and higher up the flu increasing the amount of draft. With the increased draft your going to burn more and faster unless that air combustion air damper is doing it's job. I'm a little confused on the current combustion air supply. Is it currently pulling from inside the home? I would look strongly at your air intake damper. Sounds like you already verified your door seals are good.
In my opinion that is a great reason to get one. With a drafty house you don't NEED one, but would it benefit the overall situation? It just might. I probably don't need one in my house either. But I figured I would put one in to see if I liked it better. Also our house now has 4 more exhaust fans and a beefier stove hood, I'd be kicking myself if I needed it and didn't put it in. Because once this stove is installed putting one in would have been way more difficult. I can discontinue and delete it rather easily if I do not find it is beneficial.
/ Can a stove draft TOO well? #20
Your pulling outside air into the fireplace instead of your heated inside air. I would think that alone would be a benefit.
2014 CATERPILLAR 259D SKID STEER (A65053)
2014 CATERPILLAR...
2023 WACKER NEUSON G70 TOWABLE GENERATOR (A63276)
2023 WACKER NEUSON...
2016 Freightliner 108SD 26Yd. Side Loader Garbage Truck (A64194)
2016 Freightliner...
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A67148)
2019 RAM 5500 4X4...
2005 little wonder high output blower (A64557)
2005 little wonder...
Swict 84in Bucket Skid Steer Attachment (A64553)
Swict 84in Bucket...
