Quick attach loader conversion
/ Quick attach loader conversion #1
PHIL850
MASS and Northeast kingdom of VT
JD 850
Iam looking to add a quick attach conversion to my model 75 loader on my Deere 850 tractor.
Was wondering if anyone has done this and what I might want to watch out for. Was considering purchasing
A weld on unit from one of the Chinese manufacturers or are these junk? A Pin on unit made specifically for my loader is just way to expensive.. your thoughts?
/ Quick attach loader conversion #2
I've bought brackets for my 420 loader, to attach a few things, from these guys. Good stuff, made in USA (I think). I didn't search for your specific loader though...
/ Quick attach loader conversion #3
I found a kit from J.D. with it's own part number for this conversion. Works great on my 80 loader, even the level indicator. I bought a new bucket, forks, a hay spear, tree puller, a grapple, and extra plates from Amazon to make a snow plow mount and a front loader mounted hydraulic PHD that only uses 1 loader arm.
I only had to narrow the curl cylinder collars by a mm to make it work. A grinding wheel and 5 minutes was all it took.
By far, forks are the most used, even for trenching ! I'm not even sure where my new bucket is right now !
/ Quick attach loader conversion #4
Do you have the JD quick attach on yours and want to convert to skid steer quick attach? If so they make plates for that. If not you’ll have to get a pin on plate.
/ Quick attach loader conversion #5
I've converted half a dozen or so different loader to SSQA, including one big (75 HP) John Deere. Don't recall the model. Do you have links to the parts you're talking about?
No, Iam looking to setup a quick attach on my model 75 loader that works with skidsteer standard. It is presently a pin on loader
/ Quick attach loader conversion #7
Do you have good steel fabricating tools and skills?
I​
So far stuff on Temu is what I have looked at
I’ve built a few things in my time. Last thing was a log splitter.i have a stick welder and the usual assorted hand tools
/ Quick attach loader conversion #11
I think they make a pin on to get you SSQA for your loader. You just need to get the right spacing.
/ Quick attach loader conversion #12
Check out H.W. Long. They make the adaptor plates for all sorts of conversions. CHanges my Great Bend loader from pin on to SSQD and changed the 4in1 bucket that was pin on to SSQD.. Mostly use forks and grapple now, very seldom hook up the bucket, but having the SSQD really makes a difference.
/ Quick attach loader conversion #13
You are looking for a skid steer quick attach (SSQA) conversion, and yes, the weld-on kits from overseas are way cheaper.
/ Quick attach loader conversion #15
I converted my Kubota in August of 2023 and have been quite happy with it. I bought the adapters from Amazon, and what I bought was overbuilt, but reasonably priced. I will say, though, that the tractor side needed a little modification, in that the levers did not pull up to 90 degrees (straight up, so I had to cut out a notch at the top so they could swing to where they would stay up while changing implements. I also cut out the center of the adapter plate on the bucket side, to save weight. Cut the original brackets off my WR Long 4N1 bucket and welded them onto the tractor-side adapter, then welded the SSQA plate onto the bucket. Looks almost factory.
Links below.
Tractor side: Amazon.com Unfortunately, not available at this time from Amazon.
Bucket side, .5" thick plate (probably could have gotten a .375" plate instead, with a 40hp tractor): Amazon.com: 1/2" Skid Steer Mount Plate Quick Tach Attachment Loader Plate Compatible with Bobcat Kubota, with One Year Warranty : Patio, Lawn & Garden
Chris
/ Quick attach loader conversion #16
I'm thinking SSQA and mount it to the 3pt.. Also. Old ford they Bolted a Hay spear to the Bucket. I had other Welding repairs To take care so I filled them in. I have skid forks from a fork lift and I believe I see a easy QA. setup for them. With a Rear Receiving Hitch it is getting interesting! No PS. And it sure easier with Weight to offset the FEL.. I use and leave a old Int. BH. that's super heavy just for that reason. 4' and a few inches smaller than the rear tire Displacement. Don't have to worry about catching BH. on anything. I seen one with the Receiving Hitch QA. and Forks possibly? Easily add more weight for Ballast. That just may happen INKY. either. Amazon.com
/ Quick attach loader conversion #17
Yeah, I was (am) going to do that to my JD-770 (one of these days) and I looked all around also. I was going to go with I believe W.R.Long as you can download a form and fill out the dimensions of your loader/pin setup and send them in and they would make you one. Can't remember the specifics. As far as the bucket the 'Tube had a few guys that showed how to DIY it. I do want to save the bucket on the JD as it is really robust and I still do use it a lot.
I do have my LS now and it certainly is nice having the QA and the wife does like the auto tranny but she feels more comfortable using the smaller JD. Having the QA on the JD would help out as I could have the wife move some stuff for me with the forks so I don't have to stop farting around playing with the LS, I mean stop working on my project.
I was leaning towards the full bracket between the arms so it would (in theory) have some twisting prevention strength when using it to shove stuff sideways or offset heavy on one side like, dirt, gravel, rocks, etc.
We do have a couple of welding shops around me so if I don't feel confident with my welding then I can take it to them to have it done, I can't think it would cost too much and having a little more peace of mind helps.
/ Quick attach loader conversion #18
Junk pile! Still have a Bottom 3pt. and a hitch receiver. The forks are still on the dead forklift. Now just figure out a top link attachment. Shouldn't be all that much to it. How cheap to!!
Great Thread :cool:
SCAG TIGER MOWER (A64557)
SCAG TIGER MOWER...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
Massey Ferguson 461 Tractor (A65579)
Massey Ferguson...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
