Hydraulic Pump Upgrade (Deplorable Diesel)
   / Hydraulic Pump Upgrade (Deplorable Diesel) #61
Pity NH didn't do the same thing when LS switched to the LS Mtron engine. Same flows from what I see.
Same flows? little confused, when I looked at tractordata.com, you can find the NH Boomer 4060 has a main hydraulic pump that flows 12gpm using a tuned up (more HP same engine as LS XR4046) Shibarua N844 and power steering pump that supplies 5.5gpm. The LS XR4046 has a main hydraulic pump that flows almost (manual says 7.6 GPM) LISTED 8gpm and a 4gpm power steering pump. I then looked at both pumps and the bolt pattern PLUS the shaft were the same (10T splined shaft). The only differences is where the hard lines (input and output) for the pump are, on the 8gpm the input (suction) is just a threaded hole so the hard line won't work, will have to be removed and using some adaptors change it over to a hydraulic rubber hose supply line. Then for the output (pressure) side, I think the pump is LARGER and it puts the output farther back (I could be wrong on this) and it won't match up to the hard line and then this might also need to have some adapters and converted to a high pressure hydraulic rubber hose. This is all in theory, I don't have the pump yet and Im pretty sure the hard lines can be removed and adapters such as BSPP etc. used on the other ends.
   / Hydraulic Pump Upgrade (Deplorable Diesel) #62
you misunderstood ... when LS switched to to LS Mtron engine 31xx/41xx series the NH equivalents use the same pump specs supplied by LS.
   / Hydraulic Pump Upgrade (Deplorable Diesel) #63
Ok I got what you are saying now, was confused a little haha. Have a good one.
   / Hydraulic Pump Upgrade (Deplorable Diesel) #64
Alexpops,
Thanks for the reply!
   / Hydraulic Pump Upgrade (Deplorable Diesel) #65
Now if someone reprograms your ECM to eke out the extra HP, then the comment about robbing HP and overloading engine wouldn't apply. You'd still need to compare the loader specs though.
   / Hydraulic Pump Upgrade (Deplorable Diesel) #66
The increased flow will require a very minimal additional hp. The only time it would effect hp would be when using the full volume at full pressure. Normal operation would have very minimal effect on the engine output.
   / Hydraulic Pump Upgrade (Deplorable Diesel) #67
51Allis, did you ever get around to trying this swap?
   / Hydraulic Pump Upgrade (Deplorable Diesel) #68
To determine horsepower for a hydraulic pump, multiply gpm x psi and divide by 1714.
   / Hydraulic Pump Upgrade (Deplorable Diesel) #69
Not yet, sorry for the delay in response. Since I use my tractor daily, its hard for me to get this done, I have yet to buy the pump, its about $650 for a new pump, the the adaptors and custom made hoses etc. I think the whole project would cost me about $1000. But for that $1000.....you would get a loader that would work super fast. Its on my "to do" list.
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
John Deere 6110M (A53317)
John Deere 6110M...
1999 GMC C7500 S/A Dump Truck (A59230)
1999 GMC C7500 S/A...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
