The Life of a Custom Mowing contractor
/ The Life of a Custom Mowing contractor
Been real busy getting final loads of hay trucked out of fields. My daughter left me this note this morning.
I took this photo while loading up the trailer (on the right).
Off in the distance across the river, East Penn Railroad is heading southwest on the RR tracks.
Tough to see with the woods. Can you see it?
Back to the stack to get 2 more
Now at the hay yard getting unloaded. Their loaders are huge and dwarf the bales, easily unloading a truck in minutes.
You can see the mountain of loose hay in the background waiting to go into processing.
Either somebody likes my hay bales…..or maybe they like me? lol
/ The Life of a Custom Mowing contractor #1,953
That's a whole lot of loose hay! How does it get processed and used?
It’s kind of difficult to explain, but I am part of the beginning of the process. All incoming bales are unloaded and immediately have the strings or net wrap removed. Large square Bales are broken up by a big front end loader and pushed up onto a huge pile. Round bales are sawed in half with a giant saw blade mounted on a skid loader.
The loose hay is then mixed with straw. Then that blend is put into 1000’ long rows where lime, chicken litter, straw, topsoil and water are put on the tops of the rows. The long rows break down into a rich black fluffy bedding soil that looks sort of like peat moss.
It is then trucked to mushroom farmers who use the special soil to grow mushrooms.
Using the 20’ 10K trailer to haul 3 of my shorter bales behind the tractor.
I’m still using a set of portable old school auxilliary flashers.
I can’t seem to find a 7 pin tractor to 7 pin truck adapter with more than 12” of cord, so I can plug my trailer into the tractor plug.
/ The Life of a Custom Mowing contractor #1,957
Using the 20’ 10K trailer to haul 3 bales behind the tractor.
Probably have to build that yourself to get the length.
And yet every other conceivable combination of plugs exist with long cords between them.
/ The Life of a Custom Mowing contractor #1,959
A couple of the farms tractors actually had a EU pin out. They didn't work right with all the implements.
/ The Life of a Custom Mowing contractor #1,960
If you can buy the right short adapter, splicing in longer wiring to your desired length is pretty easy to do. You know, while you are sitting around with nothing to do - LOL!
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
Pallet fork attachment for mini skid steer (A61567)
Pallet fork...
3PT 5' Leveler (A60463)
3PT 5' Leveler...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
