Need advice-Too much HP?
/ Need advice-Too much HP? #21
I believe that was the OP's concern, i.e. what's gonna break if the mower encounters resistance, such as a rock or ground contact.
The shear pin, but only if someone didn't do something stupid, like replace the OEM pin with a grade 8 bolt.
/ Need advice-Too much HP? #22
Got a soft spot in my heart for the older Ford 8000's we got ours in 1968 brand spanking new, full rack of front weight and a large stack of rear wheel weights along with a 5 bottom 18" moldboard plows with the hydraulic side hill hitch (2 point) semi-mounted.
And she's still on the farm and even gets used a bit.
View attachment 4382585View attachment 4382586
I'm a little late to the dance Lou, but that's a really nice old Ford 8000 . . . (y)
/ Need advice-Too much HP? #23
Mom's old brush hog had a round shaft, round sleeve, and a single bolt through it between the PTO input and gearbox. I'm not sure if it was intended as a sheer or not. However, over the years the two parts were rusted together and no longer capable of breaking loose.
/ Need advice-Too much HP? #24
…over the years the two parts were rusted together and no longer capable of breaking loose.
You’re supposed to remove the bolt to lube and exercise the two halves each year, as part of your routine maintenance.
/ Need advice-Too much HP? #25
That's the way my 6' King Cutter is made. I use grade 2 or plain ½" bolts, which cost #1 each, plus a 35 cent nylok nut; great shear pins.
2024 Kubota RTVX1140 (A64127)
2024 Kubota...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
