The Life of a Custom Mowing contractor
/ The Life of a Custom Mowing contractor
Just had a 5 year field mowing customer ask me for a price to cut long low limbs off of about 20 huge pine trees, cut a bunch of angry brush, run it all through the chipper, and use the chips to make a thin layer of bedding under the pine trees on their 15 acre farm.
Here’s the 2 areas of trees I’m talking about
All low limbs cut up to 10’ off ground, all saplings and brush cut to the ground and all chips saved as bedding under the trees. There’s some other small areas of weed wacking and clearing, too but this is about 80% of the work.
There’s several years of debris, stickers, trash, saplings, etc to clean out of both beds. Pretty decent size mess. I figure me an my helper will need 3 days to do it all.
I already know I probably won’t get the job.
Why?
1. Old couple out of touch with prices.
2. “Neighborhood high school kids” used to do all their odd jobs & yard work for $5-$10 bucks/hr.
/ The Life of a Custom Mowing contractor #1,942
Do you put a "Quote good for 60 days" clause in your bids?
As Plan B, could you plow with a tractor until you found the right truck if you get the HOA contract, even though not desirable?
I only do 21 days
Yes. Might even do that until the end of plowing season, then buy plow truck summer of 2026 when they’re cheaper.
Of course all predicated on me getting the contract…..still waiting on the answer.
However, if I do get it and use tractor, they may decide not to bring me back. Bunch of old people who get angered easily by equipment noise.
/ The Life of a Custom Mowing contractor #1,944
I've heard people bitching about the noise of the plow blade scraping on the road, then they repeat if it's not plowed summer clean.
/ The Life of a Custom Mowing contractor #1,945
Haydude, out of curiosity, why did you pick 21 days. Personally, I hate waiting for replies, so I would make it 7 days maximum.
HOA’s usually take longer to reply since it may involve calling board members to a meeting.
I used to do 30 days, backed up to 21. Might do 15 for homeowners.
/ The Life of a Custom Mowing contractor #1,947
I only do 21 days
Cinch the deal - tell them you'll fix the "Keep Pennsylvania Beautiful" sign for no extra charge!
/ The Life of a Custom Mowing contractor #1,948
Why?
Hope they carry an umbrella policy in case one of the youngsters get hurt.
/ The Life of a Custom Mowing contractor #1,949
HD, does that HOA include doing the driveways? An HOA here had the roads and drives snow plowed by a contractor that use back blades on drives and blowers on the front of the tractors. Backed in dropped both and started out the drive. When out far enough, they picked both up and then backed in and cleaned bladed snow with the blower. Not sure what they used on the roads. Only maybe a mile or two of roads though. Not sure of how many employees the contractor used on this HOA. Jon
No, just main roads.
Looks like my snowplowing bid for a big HOA finished 2nd lowest and they took the lowest bid. (n)
Been real busy getting final loads of hay trucked out of fields. My daughter left me this note this morning.
I took this photo while loading up the trailer (on the right).
Off in the distance across the river, East Penn Railroad is heading southwest on the RR tracks.
Tough to see with the woods. Can you see it?
Back to the stack to get 2 more
Now at the hay yard getting unloaded. Their loaders are huge and dwarf the bales, easily unloading a truck in minutes.
You can see the mountain of loose hay in the background waiting to go into processing.
Either somebody likes my hay bales…..or maybe they like me? lol
/ The Life of a Custom Mowing contractor #1,953
That's a whole lot of loose hay! How does it get processed and used?
It’s kind of difficult to explain, but I am part of the beginning of the process. All incoming bales are unloaded and immediately have the strings or net wrap removed. Large square Bales are broken up by a big front end loader and pushed up onto a huge pile. Round bales are sawed in half with a giant saw blade mounted on a skid loader.
The loose hay is then mixed with straw. Then that blend is put into 1000’ long rows where lime, chicken litter, straw, topsoil and water are put on the tops of the rows. The long rows break down into a rich black fluffy bedding soil that looks sort of like peat moss.
It is then trucked to mushroom farmers who use the special soil to grow mushrooms.
Using the 20’ 10K trailer to haul 3 of my shorter bales behind the tractor.
I’m still using a set of portable old school auxilliary flashers.
I can’t seem to find a 7 pin tractor to 7 pin truck adapter with more than 12” of cord, so I can plug my trailer into the tractor plug.
/ The Life of a Custom Mowing contractor #1,957
Using the 20’ 10K trailer to haul 3 bales behind the tractor.
Probably have to build that yourself to get the length.
And yet every other conceivable combination of plugs exist with long cords between them.
/ The Life of a Custom Mowing contractor #1,959
A couple of the farms tractors actually had a EU pin out. They didn't work right with all the implements.
/ The Life of a Custom Mowing contractor #1,960
If you can buy the right short adapter, splicing in longer wiring to your desired length is pretty easy to do. You know, while you are sitting around with nothing to do - LOL!
Pallet of truck parts (A60736)
Pallet of truck...
2005 FRAC TANK 500BBL WHEELED (A60736)
2005 FRAC TANK...
JMR 4X8 Basket for skid steer or pallet fork (A61567)
JMR 4X8 Basket for...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A60352)
2018 Sundowner...
