trail clearing technique and tools
/ trail clearing technique and tools
I had a local forester recommend allowing as many young ash making as you can, even if the ash borer eventually gets them. This will maybe keep them around enough to potentially find a solution in the near future maybe?
You know there is a vaccine for them correct? I believe you need to use it every three years. Me, I'd not plant ash trees.
/ trail clearing technique and tools #1,582
I started down that road to try to preserve a mature ash at my last house. I only did it one year because I don't like putting chemicals in the ground, especially ones that are toxic to pollinators.
There is no vaccine for ash trees, but there are effective treatments, primarily through trunk injections of systemic insecticides to protect them from the emerald ash borer (EAB). These treatments are often administered by licensed professionals and use active ingredients like emamectin benzoate or imidacloprid, which are injected directly into the tree's vascular system to protect it from the pest
/ trail clearing technique and tools #1,584
I don't remember what it was, but it was something I was supposed to pour around the roots. Not only would it kill insects in the ground but since it would be taken by the limbs and leaves it would kill insects in the canopy too. It just wasn't worth it to me to save that tree. I don't know if the trunk injection has the same problem.
/ trail clearing technique and tools #1,585
I tried that, but with , at the time, a few hundred dying Ash, it was not realistic.
I tried to focus on one that was in great shape, the treatment just delayed the inevitable.
The Borers are still in the area feeding on young trees.
/ trail clearing technique and tools #1,586
Never heard of that. Going to look into that.
Dr Google and Mr. Ai says,
“Yes, trimmer line can have a shelf life, as it may become brittle and less effective over time, especially if not stored properly. To extend its lifespan, it's recommended to keep it away from direct sunlight and moisture, and some users suggest storing it in water to maintain flexibility.”
I learn something every day. For those of you storing your string in water, do you make your water from melting dry ice? ;) :unsure::unsure:
The nylon strings are made form gets micro cracks which the water is suppose to alleviate. YRMV.
/ trail clearing technique and tools #1,588
I stuck some trimmer line in my pants pocket thinking I'd need more clearing some fence line last week and forgot about it until I found it in the clothes washing machine today.
I guess I'll have to test it to see if it makes it last longer.
Putting up trail markers to keep us from striking rocks, logs and stumps at the edge of the trail over the winter. These are reflective at the top, fiberglass rod that's 5/16 thick and 5ft tall. Could have used 6ft tall ones. That's a long 1/2 HSS drill we are using to get to them in.
/ trail clearing technique and tools #1,590
With heavy snow predicted here in the next 24 hours, I'm also marking problem areas to ease plowing. I have a supply of those fiberglass markers, but they are difficult to drive into frozen ground. Nice idea you have using a drill. In my case, I carry a sharpened length of 3/8" rebar and a hammer to drive a hole first. Makes it a snap to insert the marker.
We tried the rod driving system but hit rocks and found some logs to good of shape to do that. Also hit my hand trying to drive some in..... The drill option was 90% safer, quicker and didn't mind making holes in those logs.
/ trail clearing technique and tools #1,593
After lots of snow and many snow storms I got all my trails groomed for the holidays season … lots of dead fall with that heavy sticky snow still suck on trees and that crazy wind…. I had to cut lots of low hanging spruce branches and slashed myself on a mishaps nothing bad but everything was there… tired, single tool / wrong tool for the job, rushing, tired arm, mine not on task, you name it and it was there …stay safe merry Christmas
Sorry Arry don’t want to drift your thread but I thought it was relevant.
/ trail clearing technique and tools #1,594
I finished a 370 yard long trail along my property line, the trail is nicely along the property line. There was lots of snow so I did it all wearing snow shoes thanks go for these, first day I simply walked it twice (back and forth), then I did about 100 yard a day until completion and walked it again each day to pack it down. I will have do re do it all this spring as everything will be cut 2ft tall but at least the hard part is done.
this is exactly on thread.
/ trail clearing technique and tools #1,596
Wow, blazing a trail while wearing snowshoes adds a another level to Good Effort!
/ trail clearing technique and tools #1,597
Yeah, I usually don't like it I but this year there is so much snow their is no other way... I fell a few times and let me tell ya getting up is a effort on it's own lol ... especially when your dogs think its play time.
Anxious to see how high everything is cut at.
While brushing in 3ft deep base, which is not recommended. Quality falls away as does safety and we can get 80% more work done in the fall. We would drive the 4x4 into the pack to knock it down, then back up and do that a few times, then cut shoots and downed branches. In the 2nd photo is a coffee table sized rock.
/ trail clearing technique and tools #1,599
While brushing in 3ft deep base, which is not recommended. Quality falls away as does safety and we can get 80% more work done in the fall. We would drive the 4x4 into the pack to knock it down, then back up and do that a few times, then cut shoots and downed branches. In the 2nd photo is a coffee table sized rock.View attachment 5017838View attachment 5017839View attachment 5017840View attachment 5017841
My favorite!! The cherry tree tangle:(. Has been our biggest problem since the ice storm in Northern Lower MI last March.
We are looking at a used 2017 JD 4044r with 800 hours now at our regional dealership. Has the power beyond option for a BH, a skid steer type attachment mount on the loader. Comes with a bucket and forks. Would need to add the circuit to the loader to power the grapple. (cost 1K to add) and some root grapple.... Has cab.
2020 Cushman Hauler 1200X Gas Utility Cart (A64553)
2020 Cushman...
Case 1044 Combine Head (A65640)
Case 1044 Combine...
Case IH 200 50' Field Cultivator (A66285)
Case IH 200 50'...
JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A64553)
JMR 78in Dual...
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
2005 Airman PDS185S Towable Air Compressor (A64194)
2005 Airman...
