Suggestions on where to get used parts
/ Suggestions on where to get used parts #1
coloradotrout
Gold Member
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
I need a PTO shaft for a deere 4100 cut. It sheared off just inside the case. I haven't opened the case up, so not sure if I just need a shaft and seal, or maybe more.
/ Suggestions on where to get used parts #2
/ Suggestions on where to get used parts #3
The JD parts manuals are available online.
The rear pto shaft was M807623 but has been replaced by LVU800637.
It is used on 4100, 4110, 4115 with hst transmissions.
I like to use tractorhouse to see what salvage yards
Why did it break is the first question I would be asking. If it is the tractor with 600 hours in your other thread that would suggest it was not wear and tear.. If it was due to an accident or abuse I would replace the bearings as well. No matter what I would replace the seals.
/ Suggestions on where to get used parts #4
I'm not sure I've seen a sheered PTO output, although the one on my Massey Harris is bent and will need to be dealt with sometime.
Perhaps too short of a PTO shaft and either an side force from turning, or raising and lowering the implement?
Thanks for all the input. I was abusing it. Had a 4ft rotary attached and beating on big (mostly rotted) tree stumps. I don't know exactly when it snapped. 2600 hours.
Shaft, seal for certain, maybe bearings as you are suggesting. Once I pull it out, we'll see.
Thanks! I have the parts link. Thanks for confirming I had the right numbers!
/ Suggestions on where to get used parts #7
Your one of the few that take ownership of their actions.
All States Ag Parts lists one online.
Lol. Well, sometime we do stupid things. With our tools and with ourselves. I finally bought a 4' rotary cutter when I started to destroy my finish mower by trying to use it to cut small trees. Dumb. Damaged the spindle, and I'm still paying the price for that! My machinist relative has kept me going. But a 4' cutter is not going to whittle down a 12" stump when it's not rotted.
All States ended up not having one, but another, via tractorhouse, appears to.
I tore it down. Looks like just the shaft was damaged. I'll replace the bearings, washers, clip. $80 in new parts. Gears look ok.
/ Suggestions on where to get used parts #9
Slip clutches are a pain when not needed, but there are the occasional moments when one wishes that one had one.
Yeah, I'm thinking at least a shear pin. But stupid is hard to defend against ;-).
/ Suggestions on where to get used parts #11
Im looking for a hood for a ls j2023h any help on where to buy one much appreciated.
/ Suggestions on where to get used parts #13
It is also nice when we realize that what we were doing to a piece of machinery when it failed was above it's capabilities.
We (as in me!) have been known to push the edges of good sense when I am involved in a job and I just need "a little bit more". When it breaks, I regret it, but that is life!
David from jax
Got the used pto shaft for $400. Delivered in a few days. Waiting on Deere to ship the bearings, etc.
The used part did not fit. The overall length is the same, but the new part fits 5mm more inside the gear box. There's 5mm more spline for the gear. That extra 5mm will not fit inside the gearbox. The snap ring determines where the gear sits. I'll try again with tractorhouse for a 4100 HST.
/ Suggestions on where to get used parts #16
My system for finding used or difficult parts is to get the part number and put it directly into google. That usually works; I buy parts from all over the EU.
Bearings and seals always come from a bearing supplier.
As an amatuer machinist, I make a lot of things myself.
I contacted each of the tractorhouse companies that had used 4100s. 3 replied. I got the pto shaft for 350, about 1/2 the price of new. I would suggest comparing detailed measurements as one was the same overall length but not machined the same. The inside portion of the shaft was too long. Interesting where mine broke. Seems a gear or something else should have broken first. One of the bearings didn't turn smoothly. I don't know if that was the case before or after the shaft broke. I replaced it and the one adjoining on the other shaft. I was going to replace the other pto shaft bearing but felt the original was better than new. New had plastic to retain the ball bearings.
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A62129)
2019 CATERPILLAR...
24220 (A56859)
24220 (A56859)
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A60352)
2013 Chevrolet...
2019 KENWORTH T880(INOPERABLE) (A60736)
2019 KENWORTH...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
Used Landpride GR1525 Stump Grinder
Used Landpride...
