Making gas cans great again
/ Making gas cans great again #181
My vent hole needed to be an odd size that I didn't have a drill for so I drilled undersize and used a hand reamer to get exact fit. Worked better.
/ Making gas cans great again #182
I discovered that Buc-ee's sells 5 gallon "liquid" containers (since they can't market them as gas jugs) with traditional nozzels and vents on them. So I bought one of those. It's nice, but I wish it wasn't so tall. I can't fit it in my pickup with the bed cover closed.
/ Making gas cans great again #183
I vent my plastic cans with a schrader valve like you you use for air etc. Drill the hole a little smaller and screw it into the can with a little silicon. Remove the valve core and put the cap on it. No leaks. Remove the cap when you need to vent. My main problem is misplacing the cap so I keep extras on hand.
I fitted schrader valves to a couple of 5 gal fuel jugs. Both broke off in less than a month. The rubber "groove" broke at the base. I did not expect that, I guess I'm hard on them.
So I wittled a couple of wooden plugs, and tye the pegs to the jug handle with string so they don't get lost.
With temperature change, I have had the wooden plugs loosen, but it's easy enough to check them before handling the jug.
/ Making gas cans great again #184
This made me recall using a potato for a stopper on kerosene or coal oil cans when I was a kid. Seems the metal screw-on cap got lost soon after purchasing a can.
2018 International LT Automatic Day Cab (A62613)
2018 International...
2018 GENIE GS-2632 ELECTRIC SCISSOR LIFT (A62129)
2018 GENIE GS-2632...
1999 Ford F-150 4x4 Pickup Truck (A61568)
1999 Ford F-150...
Excavator Tooth Bucket (A62177)
Excavator Tooth...
2018 John Deere 470G Hydraulic Excavator (A61567)
2018 John Deere...
2 1/2 ft x 2 1/2 ft Metal Cage (A61166)
2 1/2 ft x 2 1/2...
