Does anyone else ride bicycles?
/ Does anyone else ride bicycles? #61
Runner you need to get one of the front wheel trainers. You could double
your workout.
Good idea! I'll probably go for the upgraded electric version so I can go even faster (like those seated "exercisers" they advertise on TV).
/ Does anyone else ride bicycles? #62
I found this, and my mind is trying to equate the left shifter to a range selector, does that track?
If so, it's coming together in my head. 7 speeds over 3 ranges, making the 21 speeds total.
21 speeds in theory, but in actual practice, you probably can't really use combinations where you are "cross-chained" like smallest rear cog with the largest front ring. It wears out the chain and makes a bunch of noise.
Years ago I put this 29er together. Unfortunately the parts came with white cables. A few weeks later I switched to black cables. Frame was 270 and fork was 165. The carbon fork rode as good as it looked. First ride pick.
/ Does anyone else ride bicycles? #64
How is the carbon fork on rough surfaces? In the Trek Dual Sport line, they got rid of the suspension fork the year after I bought mine (2022) and went with a carbon fork on all models. I'm not convinced it would work as well as the suspension fork in trail situations.
Even the "paved" trails I ride on have broken areas and lots of sharp bumps where the asphalt has buckled that make me appreciate the suspension fork.
I think if I had to replace the Dual Sport, I would go for a regular hardtail mountain bike with suspension fork, like the Marlin, then put narrower handlebars on it like the Dual Sport.
Runner. I'm going back to using a trainer like that. I never had any
tire problems. I roughed up the rollers surface. I just scratched a
grid pattern on it.
I thought the fork had more flex than a aluminum or steel fork. It's
still a rigid fork after all.
/ Does anyone else ride bicycles? #67
grid pattern on it.
Worth a try. This is tire damage to a brand new Continental tire that's never been on the ground.
/ Does anyone else ride bicycles? #68
I have these weird orangey tires on my inside bikes for the trainer. I just have two rear wheels for that bike.
/ Does anyone else ride bicycles? #69
It looks like that bike has standard SRAM twist grip shifters. All the shifters operate basically the same. You just have to tighten the cable to take the slack out. There are high and low limit screws that keep the chain from going off the high or low side of the sprocket set. Once you've done it, it all makes sense. Just go on YouTube and there are all kinds of videos. It's fine to take a bike into a shop and let the professionals work on it but unless the wheels are out of round there isn't anything beyond the average person.
Park Tool has a lot of well made how to videos. They make a lot of the tools that bike shops use.
/ Does anyone else ride bicycles? #70
Unlike tractors, the gear ratios in the ranges overlap. On that set up you should not use the extreme cross chain gears. That's small chainring to small cog, or large chain ring to large cog. I also tend to stay out of the smallest 3 or so cogs when in the small ring.
Like a tractor, the range (front derailleur) shifting is clunkier than the rear derailleur shifting. They take more time and are more likely to throw the chain.
Runner on the trainer I used Continental Ultra Sport 28x700. Never had one go bad.
/ Does anyone else ride bicycles? #72
I'm thinking about buying a cheapo bike to use only on the trainer. I really don't like having my expensive (to me) road bike on there getting all those miles. I could use the Raleigh, but it's an antique and I'd like to preserve it too.
/ Does anyone else ride bicycles? #74
I ride a cheap bike all the time ;-) but I have one I reserve for the rollers, I just pour sweat even with the floor fan.
/ Does anyone else ride bicycles? #75
The one in the pictue is a Continental Super Sport. When it shreds, I've got some budget Amazon tires I'm going to throw on there, just to see what happens. They are called Fincci or something like that. Two tires and two tubes for $30.
/ Does anyone else ride bicycles? #76
If I were looking for a road bike, It would be a Schwinn Continental. Just because I had one in High School
Tubular forks, sew ups, down tube shifters, Lycet seat,
But I live a mile from pavement, flats suck!
I had a Schwinn Continental with a few upgrades. Did a 250 mile trip from Truckee Ca to Mt Lassen and back to Quincy Ca with Scouts when I was 12. Wish I had it now.
/ Does anyone else ride bicycles? #77
I've ridden off and on over the last 57 years. Mostly road, but some off road.
Had a blast riding mountain bikes on the Rubicon trail. Have Jeep'd it, dirt bikes(4 stroke and 2 stroke), hiked, and mountain bike the trial.
I inherited my Uncles road bike some years back. It's like a time capsule from 1968. Motobecane Grand Record, All Campagnolo, Mavic Red Lab sewup rims, Brooks leather racing saddle, Cinelli drop bars, Campy fingertip shifters... He used to rebuild and upgrade bikes. I helped him work on them when I was a kid.
That Motobecane is a great bike to ride.
/ Does anyone else ride bicycles? #78
The first time i had sew-up tires, I rode down a small grassy hillside and one of the tires got filled with thorns, too many to patch. I replaced the tube without having to open the whole tire up. My friend showed me a neat trick, I'll explain if anyone is interested.
/ Does anyone else ride bicycles? #79
I had hand me downs and garage sale bikes until I was around 13/14 when my Uncle bought me a new Peugeot.
I loved that bike and still miss it, it got stolen in front of the school the next year.
I had a banana seat bike in MA, that I tried riding down the hill once, coaster brakes did not help.
Ended up with the bike hung up on a rail and me face down in the road.
I looked over the edge, about 50 feet down and saw a deer skeleton on the rocks.
/ Does anyone else ride bicycles? #80
This should be over in the Jokes but most of them wouldn't get it:
If you had the option to marry one of the most gorgeous curvy blonds in the world , or go mountain biking, what would you choose ?
29 or 27 n-a-half
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
Used 20' Container (A62679)
Used 20' Container...
2017 Hyundai 53' Dry Van (A62613)
2017 Hyundai 53'...
2012 UTILITY VS2RA 53X102 T/A REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
