jyoutz
Super Star Member
Those work great on pavement or hard frozen ground. On softer ground they just make 2 trenches.This is the answer.
They made skate shaped ones, too!
Easy on/off!
Easy on/off!
It does work better with drier snow and you have to angle the blade to kick it to the side. I don’t think there’s any snow removal solution besides a blower that would do anything differently on a below grade level road. It has to be able to kick the accumulated snow to the shoulder.
I have done just that. I would use a larger pipe. Mine is 4" and I wish it 6". Get the thickest wall you can get. After 8 years of use mine is wearing thin wear it contacts the ground. I had a welding shop cut a slot in the pipe and it fits over the cutting edge on the snow plow. 3 steel straps bolt it to the plow and allow me to attach or remove it. I wish there were covers over the ends as it collects stones and dirt when the blade it angled. Works great to clear snow from my gravel driveway and grass areas with out destroying the sod or pushing all the stone off my driveway.
I plow a mile of gravel road in upstate NY. We used to have a hard freeze which lasted all winter. Now we get thaws frequently during the winter. As OP says the road gets soft and rutty and the snow becomes glare ice when it refreezes. We do 2 things to deal with it:
1. Just after road refreezes or whenever it is icy, we go over it with a trailer type of standard york rake. It smooths the ruts, breaks up the ice surface, and brings up a little stone and grit onto the ice surface. it refreezes smooth after that. The grit stops skidding, somewhat like sanding the road. We never had to do that before we had all the thaws. We have not had problems with the york rake digging in.
2. When I run my tractor with a rear blade and trailer wheel, I use an hydraulic top link. To smooth contours the most and avoid having the blade pop up and down, I lower the 3ph lift arm control completely, then apply pressure on the top link till the blade is at the height I want leaving the 3ph arms floating in the down position. This follows the grade a lit better than using the 3ph adjustment to set blade height. It is easier to make slight adjustments using the top link than with the 3ph arms. It is also gradually making the road smoother. You will like your top and tilt hydraulics. Hopefully you have 3 outlets so you can hydraulic swivel also.
Might work for you , but as others have said, working on a road with a thin gravel base is hard when it softens during thaws. The thicker you can make the base, the better. But that is expensive in materials.
I have a buddy that cut a slot in a 10 foot 6 inch piece of 3" galvanized pipe with a "chop saw" for his 10 foot plow. He left 3 inches uncut on each end. He welded tabs and holds it on with 5/16" chain. It works great! We have non-frozen roads in the Fall, and the Spring, here in Maine. Wheels are no help, they just sink in the soft ground.
No blade attachment will cure 'roller coaster' terrain.
Hire in a capable guy with a small dozer to plane off high areas.
What you describe is better termed a trail. Road requires gravel bed to be called as such.
I'd say - if you have the money - go for a landscape plane. It contains the gravel and redistributes it evenly across the surface without carrying a ton of it from one place to another like a box blade can.
Then make wide skates!Those work great on pavement or hard frozen ground. On softer ground they just make 2 trenches.
Not sure why you call this 'hardened' Pipe or its' purpose. Looks like 8" sch 40 to me. Get some 3/8" Chain and 2 grab hooks. Fit hook tightly over the end of pipe and put a bolt thru the Chain through the existing hole and use Jamb Nuts. Cut off excess chain. Ditto both ends. No welding required.
Interesting (and relevant) thread, OP. Hope you keep us updated.
UnFrozen lawn plowed a foot deep snow with pipe welded on plows cutting edge I think it works pretty good.Will do, but mother nature needs to bless us with some snow before I can do any testing.
