Natural gas?
/ Natural gas? #61
Currently our propane is around $3.88 per gallon.
We knew that whatever new place we bought either we'd own the tank ourselves (if it had propane) or forget it.
That is high. It seems that NG/LPG prices vary a lot from one place to the next.
I had our propane topped off in July, and it was $2 per gallon.
My parents house is heated by NG. We live in a neighboring state and our house (larger, with 3X the gas appliances) has LPG, and they spend more on NG than we do LPG every year.
Part of my cost savings is I buy propane once per year during the summer when price is lower instead of buying during peak demand.
/ Natural gas?
Part of the game it seems the LP company plays.
We could buy into a locked rate when we first moved here 20 years ago, but slowly over the years, the "savings plan" offered by the LP company changed.
When we first moved here, 3 gas AC systems on LP and a 500 gallon tank wouldn't last very long. After I duel fueled the attic system (3rd floor bedrooms and bathrooms) and started to save on the usage, it seemed the plans started to change.
Honestly, hate our current LP company for various reasons, not including the couple of times we ran out of gas because they didn't get here when they were supposed to get here.
/ Natural gas? #63
I didn’t read all the reply’s but I did some research when we put in geothermal 10 years ago. Going by memory geothermal, natural gas and burning wood were the best for monthly cost. That all assumed you were paying for wood, of course it’s a lot of work. Geo costs a lot to put in but there are some tax breaks. It seemed to me at the time natural gas is the best. It’s not available where I live outside of town.
/ Natural gas?
Geo was a huge market with the tax breaks in my area. The issue is businesses living off those tax breaks when the consumer bought them due to those tax breaks/
Some years ago in NC, those tax breaks went way for Geo (generally install costs for the trenches), and the Geo business died.
Geothermal is the way to go if you can afford it, but in what I know locally, the guys who REALLY knew what they are doing with Geo are kind of dying off now.
Depending on the state, a HVAC company could not live on Geothermal alone.
FYI, ANY tax break going into 2026 for any HVAC system is gone per tax credit due to the "Big beautiful bill" or whatever they are calling it.
/ Natural gas? #65
That stinks.
I'm sure it helps that there are several propane dealers in our area, so the competition helps.
I hope you can swap in your own tank one of these days. I go through a couple 30 gallon portable propane tanks per year and wanted to be able to fill my own. My 500gal tank didn't have a "dip tube" (and one couldn't be added), so I bought a second tank (teed in with first one so we can use either). Now I can fill my own "BBQ" tanks and we never use more that 1/4 of our on-hand LPG between annual top off, so that's peace of mind.
/ Natural gas? #66
When we put our Geo in it was about $20k total, as I recall we got a tax break of about $7k. The company that did ours is a local hvac company that has been around a long time. For us it made sense, the payback was less than 5 years. We had propane and several years ago it shot up to over $5 a gallon.
/ Natural gas?
As I previously mentioned, what sucks is if you don't actually own the propane tank when you buy the house.
No other LP company would touch us because we have another LP's company tank.
ONLY the current LP company can remove the existing tank. Yes, you can remove it yourself, but then the price of the tank just went up substantially.
Our worst mistaking buying our old home was not understanding the "rules" of not owning your own LP tank.
/ Natural gas? #68
Few people own their own propane tank. For most people it really doesn't make much sense to buy their own tank.
It shouldn't be a surprise that one company won't fill another company's tank.
I don't really understand the angst around the tank . . . Just call them and ask them to take their tank out if it's a problem.
To your original post -- yes, obviously, install the NG. You don't want to use a heat pump with NG as a backup. More efficient to install the standard high efficiency NG furnace and a central AC system. Add water heating (tankless or not) to the NG load if you can.
/ Natural gas?
As I previously mentioned, the tank is "hidden" by bush and trees intentionally planted around the tank by the previous owner.
Major PITA to remove, and the cost to remove the tank was stupid by the LP company because I can only guess that they don't want to lose you as a customer.
Could outright buy a 500 gallon for less than 1/2 of what it costs to remove it.
The angst around the LP company who owns the tank is that the LP company has you by the gonads... If you call someone else to remove it, generally they won't touch it because you don't own it and if the LP company finds the tank removed, they can charge you anything they want for you to return it or charge you anything they want for it if it's "missing".
/ Natural gas?
The only way to determine the actual efficiency is by comparing the electric rate to NG pricing.
Generally, the price difference using NG to Electric is not worth it due to the price difference of using a heat pump vs a AC unit when using a natural gas furnace (I understand that).
On my end, the price difference is negligible between HP and AC, so thus the reason why I'd go with heat pump even when using natural gas. The added benefit is anything happens to the gas supply, I still have heating with the primary HVAC using the furnace as a blower only.
Now, if you were using LP, at least in my area, it's a no brainer to go dual fuel (gas furnace with heat pump) even if there were a 1.5 K price difference between the outdoor unit and coil between HP and AC.
End of the day, I can always control when the gas furnace is operating for heating due to outdoor temperature. If you're straight AC, you HAVE to use the furnace for heat anything the temp gets below your designated set point for heating.
Even though I live in NC, my heating hours substantially are greater than my cooling hours annually. I like the option of using the heat pump over AC due to my previous comments.
/ Natural gas? #71
We were spoiled with the advantages of having natural gas back in the 'Big City'. Now we're stuck with sutty propane slowly making our walls and ceilings turn oily yellow/brown/black.
/ Natural gas? #72
I never thought we had a soot problem with LP. Is your furnace ok?
When we switched from LP to geo they just came a got the tank, it didn’t cost me a thing. I do still have a smaller LP tank for heating my shop.
/ Natural gas? #73
Propane burns just as cleanly as NG. Both produce exactly the same by-products with proper combustion. Your appliances must be out of adjustment or you have a problem with inadequate combustion/ventilation air.
With today’s ODS safeties and pressure switches it’s unusual to see “sooting”. Propane and NG appliances are essentially identical. You shouldn’t see any difference in how they operate.
/ Natural gas? #74
This thread makes me feel like I'm in a bizarro world where nothing makes sense. 🤪 (I'm sure that this is just due to it being contrary to my own experience)
Why is that? I have no idea what it costs to rent a tank, but IMO, renting *anything* should be limited to things you only need for the short term. I do not know anybody that rents their propane tank.
My second tank (a 30 year old "refurb" that looks like new) that I bought seven years ago cost a few hundred dollars. What does it cost to rent?
Why would a company that is in the business of selling propane not want to sell propane to anybody/everybody?
I would understand if they offer a discount rate for those that rent from them as a way to incentivize the long-term cash cow of tank rental, but no sale at all?
Is the no-sale thing a "gentleman's agreement" between the local propane dealers to limit competition? Do renters sign contracts to only buy from the one dealer?
/ Natural gas? #75
Maybe it’s different in your location, but anything electric, especially heating is substantially more expensive to operate than a NG appliance. NG heating is very cheap, electric heat pumps are not cheap to operate.
All heatpumps are not equal!
Geothermal heatpumps are not cheap to buy or install (unless the ground loop or equivalent is already in place) but they are very economical to operate, and make perfect sense for anyone needing heating/AC replacement, and they are planning for the long run.
I am not talking about people who move every few years or so due to work etc.
It can also easily preheat water, if a large "solar" type water tank (80 gallons) is hooked up to it's "hot water generator", and is piped up in series with the regular water heater.
Hour meters on two stage 5 ton geothermal heatpump indicate that it operates on stage 1. 90% of the time, while heating or cooling 3000 sq-ft house.
The HP uses 2.3 kW when running on stage 1.
I would call our climate moderate, hot & bone dry summers, wet & sometimes cold (down to 2 or 3*F) and very windy winters.
/ Natural gas? #76
The 500 gallon tank at the cabin had a buyout clause going back to 1965.
The rental was free with minimum annual purchase so all was ok…
The small local company changed many times and back in the 2000’s the rental became very expensive as the minimum was increased…
I remember the buyout but the current owner said no such thing.
Good thing I had the original documents and executed the $200 buyout with the company kicking all the way.
In 2019 new owners and started billing for rental again so had to pull out the file to prove we owned it…
Are these National companies incompetent or crooks?
/ Natural gas? #77
Yeah; our 75g State Select was put in in '96, and leaked in '22. I'd say I got my money's worth from it.
Only issue I ever had with it was a solenoid which disabled fuel (propane) flow unless the power vent was running would stick occasionally in the last ten years and I couldn't find a replacement... but I didn't try very hard because I found that a light tap on it would make it work for a few more weeks lol
FWIW, next time a quick rinse with carb cleaner and cycling the valve usually works to restore the solenoid to normal. Propane has heavier hydrocarbons in it and in my experience over time they can build up on the inside of pipes and valves.
Yes, it is one of the many games propane companies play. Around here, if you ask the newco will come out with a partially filled tank, and set it up for use while you drain oldco's tank down. When oldco's tank is empty, it is pretty easy to move a propane tank. Newco then drops their tank on the old location.
Oldco has been known to not find the time to get their rental tank back. One member here got tired of the run around and told their company he was moving the tank toward the gate and on to the street if they didn't come by and get it.
I think that there is a liability issue in touching another company's equipment, so it might not entirely be jerking customers around. That said, my current propane company (one of the big national companies buying up the mom&pop propane companies) is quite happy to play endless games with customers, like eliminating local contact numbers, putting the call center overseas, and not empowering the call center representatives to be able to do anything of significance, like crediting an account. Used car salesmen are total amateurs by comparison.
A few years back, the propane company's tank leaked, and their technicians said, no problem the company will pay for the lost propane. Well, they did, eventually, but it took six months of calls, letter writing, two states Attorney Generals getting involved and a utility commission. Then the company tried to retaliate. Fun and games, and one reason I am on a mission to replace all of our propane appliances. I think that the induction stove is fifty times better than the propane stove, the heat pump dryer is both efficient and much gentler on the clothes, the heat pump water heater is on deck, which will leave just the furnace.
Around here, geothermal heat pumps have an ROI of never. I think it results from the high installation costs (labor, etc.), but it is also true that the efficiency of air source heat pumps have gotten much better over the years. Even if I installed the underground pipes myself for free, I can't make it pencil out here over the life of the units, even with the vanishing tax credits. YMMV, as I know that isn't true in other areas, especially if one is lucky, or unlucky, enough to have a high water table.
All the best,
Peter
/ Natural gas? #78
Properly designed heatpump installation will have a rater large air ducting system, which should be part of the equation when considering cost of retrofit, or planning to build new house.
Just saying...
/ Natural gas? #79
Can't go wrong with gas.
Wife had never used a gas stove before - really wanted eletric stove like she was used to. Now, she'd never have another electric one.
/ Natural gas? #80
Tier 1 is $2.46 per Therm
Tier 2 is $2.98 per Therm
Above does not include surcharges or 7.5% Oakland Utility Tax
Gas was reasonable in cost for a long time but at over $3 a Therm the writing is on the wall.
9/10 that's not really the cost of NG, it's the cost of being where you are.
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
New/Unused AGT Industrial SDA-140T Track Loader (A65579)
New/Unused AGT...
