Not to Brag, but...
/ Not to Brag, but... #81
I have a quick hitch, and the tractor has a hydraulic tilt and top hitch. I have modified all 8 attachments to suit the quick hitch, so it only takes a minute to hook up to the tractor, then it's just the ones with PTO and hydraulic to connect.
/ Not to Brag, but... #85
My brother but a couple of lamps out on their yard with a sign FREE. They watched as a car pulled up, they walked up to the lamps, took out the light bulbs and left. His wife said "I guess they didn't think much of our lamps". 😛
Somebody stole my quick hitch. Now it takes me 10 minutes just to try and talk myself out of trying to hook it up.
I hear you, LOL!!! 😂 😂 😂 😂 😂 😂 😂 😂 😂😂😂
/ Not to Brag, but... #87
Funny I have a Lane Shark which is a shredder that mounts on the FEL and has multiple positions. It runs off the tractor hydraulics. Has a hydro motor. I'm not a seasoned implement changer and did not know that if you disconnect your stuff when there is line pressure at the couplings, when you go to re-connect, the pressure will not allow you to get the coupling to seat.
At the job site I'm looking it up on my phone. Fortunately I was by myself or it may have been a bit embarassing.
The answer I got was to crack the suspect line fitting with a wrench to release the pressure. That's after actuating all the controls so everything was settled.
I had a large adjustable wrench but found it easier to simply wack the end of the coupling with the handle of the wrench. This wrench had plastic coating so it can't damage the coupling.
The male has an exposed pin. Tapping it briskly a few times released the pressure.
Hooked up easily then. The key is to have the pressure off before disconnecting.
/ Not to Brag, but... #88
This almost always works, but can be varying degrees of messy, and in cases where pressure is very high or coupling large, can get more difficult.
They make couplings with a screw plunger in them, designed to relieve this pressure, but I made my own for the cost of an eye bolt + NPT plug + spare coupling. Drill and tap the center of the NPT plug with the thread size of your eye bolt (3/8-16 NC works nicely), and then screw the whole assembly together. Works great!
I used to keep mine hanging on the shed wall, where I change most implements, but lately it's been traveling in the toolbox on the tractor.
/ Not to Brag, but... #89
Hooked up easily then. The key is to have the pressure off before disconnecting.View attachment 3740183View attachment 3740186
I looked at one of those for my JD 5075E, but was told it would tax my Hydraulics, and I needed to get the one that a Hydraulic motor mounted to my pto to run it. Great for Ponds and Firebreaks! I also learned that lesson about the lines with my Grapple. When that happens to me, I crack the T's and it connects right up.
/ Not to Brag, but... #90
I usually have trouble lining up the lower link arms to get them attached. The rest is easy. I sometimes have to pull the mower to move it a slight bit to get the pin into the hole. My mower is a 72" Deere, and I can see some day I won't be able to move it enough when I get really old. Maybe a large pry bar will help. I have gotten much better at lining it up the first time, but the tractor tends to move very slightly when I stop it on unlevel ground to get off and put the pins in. That is where I have issues. When I fist used my old tractor and had to hook up the mower it took me forever. Now I tend to leave the mower attached unless I need the scraper blade for something. Then I leave it attached until I need the mower again. I'm sure I have beat 10 minutes. Sometimes it all just lines up. When I first hooked a mower up years ago 10 minutes would have had me smiling and happy.
/ Not to Brag, but... #91
I have been using my Laneshark alot. Using it right now. Hours at a time. No issues.
Who told you it would tax the hydraulics?
/ Not to Brag, but... #92
@walnutman The JD dealer who was selling it. He said I could run hedge trimmers off my third function, but not a land shark. What is the flow rate on it? I could probably run it off my skid steer since it looks like it would fit.
/ Not to Brag, but... #93
One thing that came to mind when I read the first post in this thread, was hornets, ground-dwelling or otherwise. Given the time of year the brush hog would see the most use, I always half-expected to be attacked by hornets as I was connecting the thing.
It never happened, but maybe that made me move quicker? :D
I ran over a hornet nest one time and had to leave my tractor and run. They swarmed it. I left it running for a while and had to go back out and move it after the sun went down. They do calm down after dark.
/ Not to Brag, but... #94
I just got off the tractor snd shot everything with a temp gun. Hottest spot was the top of the Landshark motor at 170.
180 is normal for hydraulic systems. I'm sure the oil goes over 180 but not much.
I think my flow rate is 10gpm. You cannot use this on a skidsteer. It's designed for a tractor not a skidsteer. That's why it works.
JD dealerships? They would rather you only used it to go to church on Sundays.
/ Not to Brag, but... #95
I see a lot of people writing about having to manually move the mower around to get the 3-point links onto the pins. But if your mower is too heavy to just shove around, it's pretty easy to move it using your top link.
Even before I had all the iMatch quick hitch and hydraulic top link crap, I would just manage heavier implements by connecting the old turnbuckle top link first, and then using that to move the implement toward one lower link, and then the other.
Archemedes had the right idea, maybe because he was old. :ROFLMAO:
Everyone around here has a "I mowed over a ground hornet nest" story, they're too common here. I have a friend who's young son actually fell into one, one leg all the way up to the groin got stuck in the nest... he ended up in the ICU, and now has life-long sensitivity to stings and other irritants.
/ Not to Brag, but... #96
Yeah, I have some stories too, but I also had a buddy that was stuck down in a well cavity that was sent to ICU, and now carries an EPI pen everywhere he goes...Funny, well not funny, ironically, I have a huge yellow jacket nest that is going to be eradicated tonight or tomorrow. Luckily, I hit it with my enclosed cab 5075E
/ Not to Brag, but... #97
Got my bush mower hooked up in record time. Like 10 minutes total.
That's a record for me.
I DESPISE hooking up my RCR1260 60” “bush hog”. Have Quik Hitch. My cutter has the telescoping drive shaft, and the push button on the female part that slides onto the tractor’s PTO male shaft. And it’s getting even harder. I’m 70 now, and have had several surgeries, but can still do a few hours of hard work, and carry a 50lb bag. Pretty good grip per my Dr. — MY PROBLEM is that it’s extremely difficult pressing the x!!x&”!x button in and trying to line up and push the x!&xx!!x hog’s coupler onto the tractor’s splined shaft,,,, as if it’s tolerances are too close. (Yep, it’s greased). Occasionally it slides right on smoothly, like butter. WTH ? But it’s usually a sweating, cussing horrible frustrating 15 minute session. It’s so bad that for the last 2 years I’ve been paying a guy $200 to mow my 2 acre field w his big 25 hp zero turn.
/ Not to Brag, but... #98
I have a Kubota L4600 and a Land Pride 6' bushhog. It used to take me 10-20 minutes to put it on and at least 10 to get it off. This involved an entire swearword Thesaurus plus a sledgehammer and a couple 2x4s.
The process is exacerbated by the fact the the garage I had built was 1.5' shorter in each dimension than I ordered, so the tractor has to back in at a 45 degree angle, which makes lining up a ***** (since the garage is fully Tetrised with other stuff and turning takes some planning).
The hitch arms are only just able to go wider than the pins on the BH - no slack at all. So I removed the pins from the bushhog and welded a couple of steel arms to the deck (and some reinforcements) and now the arms go BETWEEN 2 sets of holes and I slide a pin in once they are aligned. Now I can hook it up in as little as 5 minutes. And disconnecting only takes 2!
Sprained my shoulder patting myself on the back.
/ Not to Brag, but... #99
Sounds like you could use the PTO link;);)
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
2014 Toyota Tundra Crew Cab Pickup Truck (A64194)
2014 Toyota Tundra...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
