Not to Brag, but...
   / Not to Brag, but... #81
I have a quick hitch, and the tractor has a hydraulic tilt and top hitch. I have modified all 8 attachments to suit the quick hitch, so it only takes a minute to hook up to the tractor, then it's just the ones with PTO and hydraulic to connect.
   / Not to Brag, but... #84
Maybe the crackhead had a repurpose for it...
   / Not to Brag, but... #85
My brother but a couple of lamps out on their yard with a sign FREE. They watched as a car pulled up, they walked up to the lamps, took out the light bulbs and left. His wife said "I guess they didn't think much of our lamps". 😛
Somebody stole my quick hitch. Now it takes me 10 minutes just to try and talk myself out of trying to hook it up.
I hear you, LOL!!! 😂 😂 😂 😂 😂 😂 😂 😂 😂😂😂
   / Not to Brag, but... #87
Funny I have a Lane Shark which is a shredder that mounts on the FEL and has multiple positions. It runs off the tractor hydraulics. Has a hydro motor. I'm not a seasoned implement changer and did not know that if you disconnect your stuff when there is line pressure at the couplings, when you go to re-connect, the pressure will not allow you to get the coupling to seat.
At the job site I'm looking it up on my phone. Fortunately I was by myself or it may have been a bit embarassing.
The answer I got was to crack the suspect line fitting with a wrench to release the pressure. That's after actuating all the controls so everything was settled.
I had a large adjustable wrench but found it easier to simply wack the end of the coupling with the handle of the wrench. This wrench had plastic coating so it can't damage the coupling.
The male has an exposed pin. Tapping it briskly a few times released the pressure.
Hooked up easily then. The key is to have the pressure off before disconnecting.
   / Not to Brag, but... #88
This almost always works, but can be varying degrees of messy, and in cases where pressure is very high or coupling large, can get more difficult.
They make couplings with a screw plunger in them, designed to relieve this pressure, but I made my own for the cost of an eye bolt + NPT plug + spare coupling. Drill and tap the center of the NPT plug with the thread size of your eye bolt (3/8-16 NC works nicely), and then screw the whole assembly together. Works great!
I used to keep mine hanging on the shed wall, where I change most implements, but lately it's been traveling in the toolbox on the tractor.
   / Not to Brag, but... #89
Hooked up easily then. The key is to have the pressure off before disconnecting.View attachment 3740183View attachment 3740186
I looked at one of those for my JD 5075E, but was told it would tax my Hydraulics, and I needed to get the one that a Hydraulic motor mounted to my pto to run it. Great for Ponds and Firebreaks! I also learned that lesson about the lines with my Grapple. When that happens to me, I crack the T's and it connects right up.
   / Not to Brag, but... #90
I usually have trouble lining up the lower link arms to get them attached. The rest is easy. I sometimes have to pull the mower to move it a slight bit to get the pin into the hole. My mower is a 72" Deere, and I can see some day I won't be able to move it enough when I get really old. Maybe a large pry bar will help. I have gotten much better at lining it up the first time, but the tractor tends to move very slightly when I stop it on unlevel ground to get off and put the pins in. That is where I have issues. When I fist used my old tractor and had to hook up the mower it took me forever. Now I tend to leave the mower attached unless I need the scraper blade for something. Then I leave it attached until I need the mower again. I'm sure I have beat 10 minutes. Sometimes it all just lines up. When I first hooked a mower up years ago 10 minutes would have had me smiling and happy.
2018 Kawasaki Brute Force 300 ATV (A55853)
2018 Kawasaki...
2020 MACK P164T (A58214)
2020 MACK P164T...
2013 Chevrolet Express 3500 Passenger Van (A55973)
2013 Chevrolet...
2019 John Deere 1025R 24HP 4x4 Loader Utility Tractor (A55973)
2019 John Deere...
Kubota L4701 (A53317)
2013 Ford F-550 Ambulance (A56858)
2013 Ford F-550...
