LS XR 4030H running issues
/ LS XR 4030H running issues #1
lelchuck
Massey Ferguson GC2300
I appear to have what might be two issues with my LS XR4040H tractor. It sat all winter on a battery tender and full of diesel. When I tried to run it the past couple of days , it would initially start up and run for a while. Then it would just quit like it was not getting its fuel. It would restart a couple of times only to immediately quit. After a few such attempts, the key would not even turn the engine over in an attempt to start. Was just dead. I let it sit overnight and the exact same experience this morning. Initially starts and runs for about 20 minutes, then dies with the same issues as cited above.
/ LS XR 4030H running issues #2
any codes? try changing the fuel filter first. check the one you pull (cut open). could be algae contamination in the tank. if algae, drain the tank & fill with clean good diesel then keep a supply of filters to change out as you plug up with any residue.
/ LS XR 4030H running issues #3
Load test the battery. Sound dumb, but I doubt its a fuel issue.
/ LS XR 4030H running issues #6
Bump.....
/ LS XR 4030H running issues #7
This might sound dumb, but have you checked the air filter? Just to make sure nothing made a home in there.
/ LS XR 4030H running issues #8
Not dumb. I had similar issues with a Honda ATV only to find out dirt dobbers had almost
completely clogged the intake. (And it was the last thing I checked)
