Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #8,161
Have a Kubota L6060 cab tractor and pull a 12 bat wing bush hog that use to mow 15 AC of horse pasture. Have another 15 AC of fields that is poor soil and sloped that use a 66" zero turn to mow 3 times per season. Works ok but rough ride and get covered in dust and cuttings. Plan is to get a fail on the tractor with the cab for the ride and not being totally dusted.
Wanted to run 84" 2100 lb fail but was looking for anyone with experience in using one behind my tractor and how it preforms with fail of this size.
/ Let's talk flail mowers #8,162
That bubbling oil is only a small nuisance when every thing else is considered. And it can be dealt with very easily. Just let the gear housing find it own level and then clean it off. Since your only going to change the oil at service intervals it won't be a big deal.
As far is "would I do it again?", If I knew then what I know now, I could have saved a lot of money and bought the Caroni flail mower the first time. I am buying a set of replacemnet knives this summer just to have on hand for that point in the future when they need to be cahnged but that is quit a ways off.
You will like the way the fields look compared to the windrowing of a Bush Hog type mower.
How does the quality of cut compare to a finish mower? I have a 72" finish mower but I need to cut some rougher stuff as well--not good for the finish mower.
/ Let's talk flail mowers #8,163
I have 2 flail one of which is a fine cut Alamo and also a Woods finish mower, the Woods makes a better looking finished cut than the Alamo even with new knives every time. As long as you are not looking to have a lawn or golf course look then a flail will work for you but realize the flail will not be as smooth/level looking of a cut if used on uneven ground. I hate seeing the unevenness of the flail cut as it goes over the uneven highs and lows of the ground, something you will not see with a finish mower on 4 caster wheels.
I regularly cut pasture for my neighbor using my course cut flail, the ones in front of his house, because the flail does give a nicer looking cut than a bush hog just not quite a finish mower cut.
  • Good Post
Reactions: JWR
/ Let's talk flail mowers #8,164
@KenBike It depends on some details. If its a shifting flail or ditch mower, it will probably move you around a bit. My tractor with ROPS weighs about what yours does with a cab. Empty tires. My ditch mower is only 68" and weighs just under 1000lbs. It will make itself felt. Pulling a straight flail will be eaiser, but 2100 is 3/4 of your 3pt lift. Be careful.
@350c Flails aren't finish mowers. If you are a lawn person, it may be disappointing. Also, be aware that you can basically have 2 types of blades, hammers and knives. Hammers are better for brush, knives are better for grass and mulching. Hammers work great for me, but we don't mess with a lawn. We live very rural.
/ Let's talk flail mowers #8,165
You have more HP than my L4060, but the same frame. My 7.5' Peruzzo Super bull is 1,500lbs & the max I should be lifting. It's probably a hair big to be honest, but I like it.
/ Let's talk flail mowers #8,166
Fallon do you mow with a loader with the bucket attached on the tractor?
Will set the fail up with knives.
/ Let's talk flail mowers #8,167
I never take the loader off. I can't be bothered to take the 5-10 minutes to do it. I've taken other Kubota & JD loaders off but haven't bothered with mine in the 1,000 hours I've put on it. I usually take the bucket or forks off though.
/ Let's talk flail mowers #8,168
Over the weekend I decided to take the flails off my mower and give them a good sharpening. I then became OCD about the balancing and decided to weigh (measured in grams) every flail and toss the weights into a spreadsheet and calculate the most balanced combination I could come up with. For reference, the mower drum has 4 rows of 8 hammers/row, 32 in total. Rows 1+3 are opposing. Rows 2+4 are opposing. The hammers are staggered on the drum for overlap. I focused on getting the opposing sides balanced and keep the difference across all 4 rows minimal. I could definitely get better results if I ground down the 645 and 639 flails as they are the heavy outliers but all in all this was the best outcome I could come up with. Do you guys do anything crazy like this, or do you just grind em down and toss em back on?
/ Let's talk flail mowers #8,169
I don't mess with them until they stop cutting well or throw off the balance.
That level of precision isn't necessary. The first time you come across a big stick or a small rock, your spreadsheet would have to be reworked.
I'm a big spreadsheet guy, but that's tilting at windmills.
/ Let's talk flail mowers #8,170
I can appreciate your efforts balancing the blades etc.
I hit them with a flap disc grinder without removing them annually.
Simply raise the mower to waist height hanging from chain using the forklift. It's a 10 minute job. ;)
/ Let's talk flail mowers #8,171
UGHH!!!!!!!!!!!
Are the flail mower rotor weights used to balance the flail mower rotor
"by itself": and after "the mounting stations were welded to the flail mower
rotor" still welded to the flail mower rotor???
Did you clean the hammers to bare metal with hot water and
Dawn dish soap??
Flail hammer knives, side slicer knives and scoop/duckfoot knives
should not be ground with a high speed dry grinding method as it
destroys the heat treatment/temper that was used to strengthen
the cast hammer knives.
One pass with the low speed wet well grind is plenty to maintain
37 degree edge.
Did you manage to keep the knife edge at 37 degrees?????
Flail shredders with side slicer, scoop or cast hammer knives come with
flail mower rotors in 2 designs either horizontal mounting in 2, 3 or 4 rows
or hammer knife mounting in a spiral knife mounting method surrounding
the flail mower rotor.
/ Let's talk flail mowers #8,172
My flails come into contact with rocks, fence posts (both wood and metal). I've never sharpened just inspected occasionally.
/ Let's talk flail mowers #8,173
Only reason for removing them is I made the mistake of clearing some brush in the woods and made contact with some big rocks sticking out of the ground that I couldn't see and some flails got pretty beat up. None broken luckily but the edges were bad enough that it would knock down grass instead of cutting it.
@leonz, it's a Betstco flail mower so whatever the Chinese do to balance these things are probably not that accurate anyways. I would like to think the rotor would be balanced after the mounting points are welded on. No way of knowing though. It's not like you get a balancing sheet with these things. But, I do know the hammers on my mower are marketed at 27oz and not a single one is anywhere close to 27oz. Chinese products in a nutshell. Hammers were cleaned with soap and water prior to sharpening and weighing. Used a flap disc and grinder to sharpen. I'm not OCD enough to measure an exact angle, just following the factory edge by hand.
I'll be putting the flails on tomorrow and I'll let everyone know if any issues come about with the balancing so others know what not to do if it doesn't work out. Lol
/ Let's talk flail mowers #8,174
An update on the "balancing" after sharpening.
No issues found. Mower operates smooth and cuts far better than it did when new. I'll probably continue to use the method I did if I need to sharpen them again. Hopefully not anytime soon. No more using it as brush mower.
/ Let's talk flail mowers #8,175
Just order a LandPride FM2584 with duckfoot blades for use behind my L6060 for mowing my horse pasture. Use a BushHog 1812 batwing and it works good by leaves clamps and does not shred the clippings well. Normally mow to 6 " but every spring in Ohio it gets away and end up cutting it down a few inches at a time.
Have pathways that also want to use the fail vs the zero turns so double duty.
Lots of good mowers out on the market but selected it becuse made in the USA and good dealer support locally to my home.
/ Let's talk flail mowers #8,176
FYI 917 (aka the Bush Hog FH174 or FH188 also) the skid shoes that go on either side are no longer available.
Here is a drawing of them.
They come from the factory with 5/16” plow bolts. However I couldn’t get any, so I used a 3/8” flat head cap screw/bolt.
I used 1.5”x.25 strap steel 36” long to make them.
Bush Hog said they made the 917 for Ford.
/ Let's talk flail mowers #8,177
I have a question about best practices of mowing with an offset ditch flail mower. I just had an issue with my Peruzzo Elk 1800 (72in) develop a bent PTO shaft. Enough that I couldn't pull it out once disconnected from the tractor. It has been getting stickier each time I connect it but thought I just needed to be better at greasing it. I don't know how it got that way. Never hit any trees and mostly mowing field grass for about 2-3 hours at a time. I do mow with the mower extended all the way since it tends to "walk" out if I have it directly behind the tractor. Should I not mow fields with it extended and only extend to do the ditches and pond area? Manual doesn't say anything about restrictions or best practices on mowing.
/ Let's talk flail mowers #8,178
The most common reason for a bent pto shaft is a shaft too long,
2nd would be hitting something with it.
My ditch bank mower is often used fully extended and also fully upright.
I have gotten some severe u-joint hammering at times.
I have seriously considered a cv joint on the mower end.
  • Good Post
Reactions: JWR
/ Let's talk flail mowers #8,179
Agree. Probably BriManley had too long a pto shaft ... the rest of that explanation is that when the sliding/telescoping pto shaft is too long you raise the attachment with a very strong 3pt hitch and when the "too long shaft" bottoms out (unable to telescope further) the 3pt keeps putting more force on the lift and bends the shaft.
/ Let's talk flail mowers #8,180
..... I do mow with the mower extended all the way since it tends to "walk" out if I have it directly behind the tractor. Should I not mow fields with it extended and only extend to do the ditches and pond area? Manual doesn't say anything about restrictions or best practices on mowing.
As others have stated, PTO shaft was too long (no good way to fix that except to replace with
proper length shaft). Good luck.
I almost always mow pasture with the mower fully extended. Shouldn't cause any issues.
Besides it's easier to see in the mirror and helps prevent tractor neck....
2013 FREIGHTLINER CASCADIA(INOPERABLE) (A67714)
2013 FREIGHTLINER...
2019 Peterbilt 520 T/A EZ-Pack 40Yd Front Loader Garbage Truck (A66736)
2019 Peterbilt 520...
2006 FORD E-350 CARGO VAN (A66091)
2006 FORD E-350...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
2015 Grasshopper 725D 72in Zero Turn Commercial Mower (A68183)
2015 Grasshopper...
2018 BRADLEY MACHINE MINI VAC TRAILER (A67714)
2018 BRADLEY...
