/ Pilot Control Spring Mod #1
Jay Flay
Member
AGT KU-18e
Hello - new to this forum. I ran this by a longtime member first and he suggested I post to the group. So here you go...
What is everyone's experience with the Pilot Control Spring Mod, if any? Any thoughts, questions or concerns about the mod? The following is what I know about the mod and I do not profess to know it all, so always open to hear from others.
FULL DISCLOSURE: First, I own about 1.5 acres, own an old (but awesome) Case 1840 skid loader, own an AGT KU-18e mini-ex and I also happen to work for a spring manufacturer here in Oregon. I designed a custom spring kit for my mini in April 2025 and decided to offer the kits for sale. For details...
WWW.SPRINGPILOT.COM
WHAT IS THE MOD? If you are not familiar with the mod, the goal of the spring mod is to "help" people settle down jerkiness in the hydraulic controls. I was exposed to the mod on Facebook Groups where guys were buying cheap springs on Amazon, using dykes to cut them down, and sliding the cut spring over the pilot pistons to add "resistance" to the joysticks. From what I can tell, this early cut spring mod was hit-n-miss as far as performance. Some guys felt a difference while others did not. Many of the guys who tried the cut spring mod and did not notice a difference are trying my kits and becoming raving fans.
MY KIT - Bottom line, I wasn't willing to have sharp steel wire flexing in my pilot control assemblies and I wanted maximum "resistance" within the small pocket available. So I went to work. The amount of material, number of coils, wire diameter, tensile stresses, solid height, and end finish all contribute to function, performance and cycle life. Prototyping resulted in my GEN1 and GEN2 kits. NOTE: I did an experiment where I used a digital fish scale to measure push-pull force with and without the kits installed if anyone is interested in that data let me know.
MY OPINION - WHY THE MOD IS SO POPULAR The way I describe the spring mod...when done correctly, the springs safely deliver a more tangible connection of the operator (joysticks) to the machine hydraulic functions. The incremental improvement in joystick feel makes a big difference and enables guys like me to enjoy the process of acclimating myself to my machine controls, find and stay in the sweet spot for controlling hydraulic functions on my machine and more importantly get the required seat time it takes to truly smooth out operation of my machine.
PRIMARY CONCERN SO FAR - The primary concern people have had regarding the mod is scoring/scratching on the surface of the pistons, especially in the "piston stroke" zone (bottom .300") let's call it. I addressed this concern on my GEN2 kit springs using a coiling feature that makes it impossible for the cut wire ends to reach the piston surface.
NOTE: I do not believe the spring mod is a cure. Seat time and technique are the real cure. But after selling almost 1,000 kits in 6 countries, working really hard to find (I cannot find any so far...knock on wood) issues and unhappy customers, and piling up over 100 5-star reviews, I can honestly say the kits make a difference and across the board guys are enjoying their machines. Seat time and productivity are up.
All feedback welcome. Thanks everyone!
James
SOME NUMBERS - I recently attempted to try and quantify the difference my custom pilot control spring kits are making. 5-star reviews are huge, and very important to me, but WHY are owners raving about the kits? So I used a very rough but relatively repeatable data collection process to measure how much pull force is required to pull a joystick close (but not all the way) to full stroke. I measured factory (no kit) first, and then I measured the pilot controls with both my GEN1 and GEN2 kits installed. I collected five (5) measurements for each setup, then I averaged the measurements to arrive at the numbers below. Here is the data...
FACTORY: 13.2 oz (0.83 lb)
GEN1 SpringPilot Kit: 30.4 oz (1.90 lb)
GEN2 SpringPilot Kit: 36.6 oz (2.29 lb)
RIPPA R-10 ECO: NOT COMPATIBLE
The R-10 is sold "with Pilot Controls" marketed as "Bi-Lateral Operations System". What looks spring mod compatible on the outside, is NOT compatible on the inside.
I have been working to try and catalog machine make/model info as different customers order and then install their kits. With over 550 kits in circulation, there has been quite a wide spectrum of machines getting or set to get kits.
21R (AGT)
DM12X / DM12RXc / DM12c Plus (AGT)
H12RX (AGT)
H15 / H15R (AGT)
LS15R (AGT)
MX12Rx / MX15Rx (AGT)
NGT18K / NGT20K (AGT)
QK18K (AGT)
QNT30 / QNT50-R (AGT)
XZ20r (AGT)
ET15H-6 (BTTL)
ST28H-6 (BTTL)
CR16 / CW16 (Cartiwell)
KRW232 (CFG)
EM15 (DIGGIT)
DM200 (DigMaster)
FF15 / FF18 / FF18R (FF Ind)
EB12 (Graecus)
ZH24d-2 (GroundHog)
HX17-Az (HD Hyundai)
HT20 (HighTop)
IRE20 / IRE25 (Iron Rhino Equip)
ZX22d (Kymron)
VA15P (Miva)
R18 / R18 PRO (Rippa)
R15 / R15 PRO (Rippa)
R13 (Rippa)
JKW12 (SDJK)
SH20 (Seahawk)
SE18 (Shandong)
KN18 (Shandong)
724G (Tigercat)
TE10 (Titan)
TPM16 / TPM18k (TPM Ind)
XX (Typhon)
XViii (Typhon)
VC15 / VC15-P (Vicsec)
VC20 (Vicsec)
YT10 (YouTop)
/ Pilot Control Spring Mod #5
I installed your spring kit and didn't like it so I removed them. I found the controls with the springs installed to be too stiff and increased the jerkyness. I can operate the machine much smoother with no springs.
Great feedback @George_B! Thank you for reaching out. Do you mind sharing the machine you have and are you an experienced operator? This helps me understand more about fit for my kits. I have worked very hard to find You and there haven't been many I can find that dont like the kits. If you are willing to try my GEN1 kit I will send it to you to try. It is 20% "softer" than my GEN2 kit. No pressure...but willing to ship it to you if you would like to test drive that kit. Thanks again!
James
/ Pilot Control Spring Mod #7
Hi James,
I have an AGT DM12X-C with 60 hrs. I am experienced with it as well as Bobcats. There's no doubt you have worked hard and provide a quality product that fit my machine perfect, it's just I found them too stiff for my liking. I'd be willing to try your GEN1 kit since it's softer, it might be a "just right" feel.
Thanks,
George
Thank you @George_B !! More great detail and I understand completely. There will always be a somewhat subjective side to "feel" in the controls of these machines. Your GEN1 kit will be on its way to you early tomorrow morning. I look forward to your feedback on that kit as well.
Hi James,
Thanks,
George
The GEN1 kit is on its way to you today. You should have tracking in your inbox now. Thanks!
*** PATENT PENDING ***
I worked with a customer in Louisiana who installed a kit into his Tigercat 724G Feller Buncher. His "steering control was soft and a bit snappy". After his install he fed back to me recently..."Fit like a glove and a much more comfortable resistance on the sticks than factory." I am curious if anyone else in this forum, with name-brand equipment, sees a need for this type of drop-in mod for joystick controls. Is there a hidden niche demand somewhere in the world of heavy equipment (aftermarket)?
/ Pilot Control Spring Mod #12
Jayflay the link does not work…
/ Pilot Control Spring Mod #14
I wonder if increasing the length of the levers would help. The shorter the levers, the more a linear displacement of the end of the lever will open the valve. Double the length of the lever, and you halve the response for a given displacement.
I think you may be right. I have seen people with direct-activating forward control machines post great results by swapping out their factory levers with longer ones. I am not aware of any instances where this would apply to remote-activating joystick pilot controls.
/ Pilot Control Spring Mod #16
OK, James, I installed the springs into my friend's Diggit EM15, and we both like the improved feel. Adding more resistance to the the joystick motions is a plus. Worth trying, IMO.
Here are some pix. The install is very easy, but there are issues with how this joystick is made. The inner boot has is too thick to fit in its upper groove, so it was loose. You can see damage where the installer tried to force it in. The outer boot really needs a plate to secure it, and keep the mounting bolts tight. There aren't even washers there.
The spools should be greased, and the inner U-joint needs some thick oil. That was done here (photo).
/ Pilot Control Spring Mod #17
Here is another pilot control that needs help: an AGT Industrial KRW232 skidsteer. This joystick is slightly different than the above, with only one boot, and a different way of retaining it.
You can see the rubber lips and the plate that secures the boot, but it was loose. Greasing the spools is a must, IMO, plus keeping dirt out. We will put the GEN1 springs in there.
This skidsteer suffers from the same problem the 1T excavators have: they are so light that they are VERY jerky. This KRW232 is borderline unusable on pavement due to high traction and powerful hydraulics (V-twin gas engine).
I have a Typhon Terrror XVII on order and this spring kit interests me. How would I decide between Gen 1 or Gen 2?
Hello @MattB4 - I have a few very happy Typhon customers. Both are excellent kits. GEN2 is hot right now. It delivers 20% more resistance (stiffness) and includes my piston protection feature. It is my personal favorite and is selling 100:1 right now. Let me know other questions, if any.
@MattB4 Did I just see your order a minute ago? I will have tracking sent over shortly. I believe the Typhons my customers installed into so far are the XViii and the XX. Yours could be the first XVii. Very excited to hear your feedback after install. Thanks!
