YM 2610
/ YM 2610 #1
widowmaker19
Yanmar 2610
I’m very new to old tractors and have been servicing my ym2610, was able to get tractor running and now my 3 point hitch is in raise position and unable to lower down, I changed hydraulic fluid and still not able to lower down. Any suggestions on what to do ?
/ YM 2610 #2
Is the stop valve open between your legs? Round handle. Try moving pin handle valve on side of control valve under the seat different position.
/ YM 2610
Yes I have it turned open as far as it will go
/ YM 2610
Yea tried that didn’t move anything
/ YM 2610 #5
Does the tractor have anything on the 3pt. They are gravity drop. If nothing for weight you might stand on lift arms. If tractor has been sitting it might be stiff.
/ YM 2610
Yea had a sprayer on it took it off then tried putting weight on arms. Maybe I need tap it with a sledgehammer?
/ YM 2610 #8
play with the tiny lever under the seat.
/ YM 2610 #11
About the only thing it could be is the Hyd. Valve. That's what controls the flow. HV-451 for the Ym2610. Same 3Pt. as my Ym2000. The pin is what controls the lift from the handle. Pull the handle back and push the pin In and lift it.
3Pt. handle down pressure on the pin is released letting it drop the Arms. The Adj. on the side of the valve is rate of lifting and lowering the 3Pt. arms. Vertical is Neutral and pretty much where the Adj, stays. Move it forwards and the drop rate increases. Set it back slows the drop rate, The handle is the 3Pt. height Adj. or how high you want the attachment to stay. You can disassemble it and clean it they have been known to get dirty and stick. No safety cover over the set pin.
/ YM 2610 #13
I posted how it works and that is a Adj. Drop rate!. Good luck
/ YM 2610 #14
Could be that the piston is stuck. It's not a big job to take off the top of the 3pt cylinder and look. That's probably the best way.
If you "tap" it, make sure it has weight on the arms, that the drop valve under the seat is all the way open, and that the 3pt position control valve to the right is pushed all the way forward.
/ YM 2610 #15
Chk. the spring and the linkage. It should keep it next to the control valve pin. Mine had major play in it and the linkage. under the guard Esp. rusted and stuck In?
/ YM 2610
Is it supposed to have a gap like that? I had the leaver that’s attached to hydraulic turn forward.
/ YM 2610 #17
No. and what I thought. Your lift arms should be all the way down now. The bottom pushes the pin in not the top. Pull the lift handle backwards, then the bottom of the Linkage Arm pushes the pin in to lift it. My Pic.#11 you can see that. My handle is all the down which is lower the 3Pt.lift arms. And my linkage is just touching the Valve. where I set the spring. I keep it snug to the control when pulled all the way back. Helps hold it in place when lifted. It will make sence when you watch what happens with the control handle. I would pull the lines to the control valve and make sure the 3 point lift arms fall Not Jammed and stuck up! I'm highly doubtful of that. Not like it can't happen!!
I had the pin come all the way out of the control valve. Make sure that didn't happen and that is what is actually stuck. Had to align it and go back in.
/ YM 2610 #18
Man I’ve been trying to figure out what that thing controls. What position does it need to be in? Mine is currently in up position same as the picture
The UP position is good. You can use the rise/lower lever to move the 3-point. When the position is down, the system is locked right there, the 3-point arms will not move up nor down. Basically frozen there.
I've played around with the feature with the rear blade grading the gravel driveway. It works alright. Yet, I found something better, using a truck shock as the top-link.
Having the shock greatly controls the bounce and jarring the tractor would take and your teeth don't rattle anymore.
/ YM 2610 #19
View attachment 3506120Is it supposed to have a gap like that? I had the leaver that’s attached to hydraulic turn forward.
I'm not sure. I've not taken the cover off to really look closely at it.
Now, your small lever there is pointing to the back, when it should be facing forwards about 20-dregees raise.
/ YM 2610
Now, you small lever there is pointing to the back, when it should be facing forwards about 20-dregees raise.
Yea sir at the time we were just messing with it like you said to do. Going to try careyo63 recommendations this weekend when I install ignition switch
2017 Bobcat T770 Compact Track Loader (A63689)
2017 Bobcat T770...
MIXING BUCKET (A62613)
2 Row Cultivator (A64047)
2 Row Cultivator...
New/Unused Landhonor No Till Seed Drill (A65583)
New/Unused...
2013 PETERBILT 365 (A65643)
2013 PETERBILT 365...
2026 Electric Tricycle (A64194)
2026 Electric...
