Lightning strike, well pump box failed
/ Lightning strike, well pump box failed #81
Do not install filters before your tank.
Install the largest tank you can.
The 26 gallon tank will give you 8 or so gallons of draw down.
X-Trol tanks are not what they used to be. I see far too many go back under warrenty.
Don't buy from a box store.
We install hundreds of Flexcon tanks every year.
My check valve is 195 feet down the well on the top of my pump. The csv is 4 feet from the top of that line, below the pitless adapter. The line from wellhead to house is almost 300 feet. Just before the line enters the house there is a t and 50 foot line to a yard hydrant. And about 80 feet from the wellhead there is a T and 150 foot line to a hydrant. I intend to put a T in that line and run 300 feet to barn, then t off that and cascade another thousand or so feet from there to put hydrants in different locations so I can open up some additional areas for goats and maybe a couple cows
/ Lightning strike, well pump box failed #83
Maybe I missed it, which CSV do you have installed?
/ Lightning strike, well pump box failed #84
David, so you will have all that pipe which is controlled by a pressure switch in the house which creates a large storage capacity (think of the pipe as a part of your storage capacity) in the pipe and allowing the water to flow both ways from the outside pipe into the house.
Then potential line pressure loss for a few hundred feet is not too bad, but for 800-1000 feet the pressure loss may be substantial.
We have about 500' of 1" main line irrigation, and a backflow preventer valve in the house, and the pressure is about 15 PSI lower at the furthest point. But in your case, your house may be the highest point and if you have 100' of elevation change to the lowest point from the house the pressure will increase for example.
Normally "external or outside water" if its fed from the house supply has a back flow preventer and this prevents the external water from flowing back into the house but allows the pressure in the house to feed the external lines. The whole system is pressurized from the house, but can't flow back in - so when there is demand externally the pressure drops and the pump turns on.
For what you are doing and planning with a large network of piping, I think you might get your well guy or someone experienced in the area running water lines on farms or irrigation. Trust me, leaks happen, and things break, and you need to be able to isolate the different zones and so on..
Do the storage tank now, but get some pro advise for your situation before extending your water network.
/ Lightning strike, well pump box failed #85
Great points and I would think about continuous poly pipe for the long runs. Lower flow resistance, and fewer joints to fail.
Personally, I prefer segregated home / animal / ranch systems. That's partly for isolation reasons, and partly not to hear the house pump coming on at a random time because animals are drinking.
All the best,
Peter
/ Lightning strike, well pump box failed #86
David, I see a pump house near your well as the best long term solution, with one or two proper large storage pump tanks, then segregate your external and internal water lines.
"About 80 feet from the wellhead there is a T and 150 foot line to a hydrant. I intend to put a T in that line and run 300 feet to barn, then t off that and cascade another thousand feet" This is where you could do the pump house with tanks and controls.
Yes this means digging up your water line, and adding an insulated structure to house tanks, switch and controls. That's why i suggest getting a local "pro" to advise to do it once and get it right.
I have a csv 125. The plastic one. The kit I bought was
1x PK125 PSIDE-KICK Pressure Tank Kit - 4.5 gallon / 60 psi / CSV125-1n
/ Lightning strike, well pump box failed #88
At my Mom's place 15 miles away it's very rocky soil. There are two 1" black plastic lines going 1/4 mile from meters to each house installed 30 years ago. Starting 10 years ago those lines started having leaks. A plumber said that's because over time water going through creates enough movement to wear the pipe. He said the solution is it should have been a larger pipe with 1" pipe inside. Worse case as he said the 1" could be pulled through the larger pipe.
Instead of all that I had him connect her back onto the well that was put in 80+ years ago, only 40ft deep but works fine, of course new pump, tank, switch, etc.
When I supplied horse stable with water a few years ago I ran two 2" pipes, one for electric, other 1" plastic water pipe.
/ Lightning strike, well pump box failed #89
The remote pump house is a great idea, but seems kinda extreme.
Joints are definately a point of failure. 90's and couplings underground should be avoided. Use only SS or brass fittings, not plastic or steel.
All the lines coming to a central point, into the house or pump house gives you the most control, you'll be able to valves individual lines.
Check valves are a wear item, don't bury them.
I don't think I've ever seen poly pipe wear out water flow.
Rocks are not your friend.
Poly pipe is pretty readily available in 300' coils, 500'ers a little harder to find, and I've custom ordered 1,500'ers before.
/ Lightning strike, well pump box failed #90
Sorry you are having problems. If the CSV is not keeping the pump from cycling when using less than 2 GPM, we will gladly replace it. But if you have a lot of usages of less than 2 GPM, a 20 gallon size tank that holds 5 gallons of water will help. Water Worker is an Amtrol tank. Flexcon is a copy of an Amtrol, which they copy everybody's stuff, including my in well tank design. Don't care for a company who just copies and undercuts instead of innovating something for themselves. Any diaphragm tank will last much longer when used with a Cycle Stop Valve as the CSV keeps the diaphragm from going up and down so much. The Cycle Stop Valves is also long lasting and dependable. But the CSV is the key to the entire system, so when it isn't working properly, anything else you try is just futile.
/ Lightning strike, well pump box failed #91
Personally, I would ditch the cycle stop, but that has been thrashed extensively elsewhere, and I don't want to get into it here.
If you don't have the space, I'd go with the 26 gallon tank.
All the best,
Peter
But then you did get into it here. Ditching the Cycle Stop Valve would be removing the most important part of the pump system. ANYWHERE the CSV has been "thrashed extensively" they fail to give any empirical evidence of the problem. They say back pressure is bad for a pump, but they never show an example of a problem caused. They say a CSV will destroy pumps, yet after 33 years there has never shown a single example of a failed pump. They say a CSV waste energy, but they can't make that happen. I have been waiting 33 years for the other shoe to drop, for someone to actually find a fault with the CSV system. It has never happened, and I don't think it ever will. After all this time I think I can safely say the Cycle Stop Valve is the most elegant solution for pump system problems that exist to date. So please, show me a failed pump, a high electric bill, or some kind of evidence before you continue to "thrash" the Cycle Stop Valve unjustifiably. But I have found that controversy stirs interest, as all the "thrashing" gets intelligent people to call and ask questions.
A 26 gallon size pressure tank only holds about 6 gallons of water. Even a couple of the largest tanks they make will not stop the cycling like a Cycle Stop Valve does. When there is a lot of usage or leaks of less than 2 GPM we recommend a larger tank with the CSV. But a 20 gallon tank with the CSV will handle leaks and low flow rates and any larger tank is not needed.
/ Lightning strike, well pump box failed #92
I agree with Steve that water flow has never worn out poly pipe. And also agree rocks are not your friend. Most pipe problems I see are caused by water hammer from the pump starting and stopping. Using a Cycle Stop Valve will greatly limit the pump cycling and also give a mechanical soft stop, which decreases stress on the pipe system as much as it does the pressure tank and everything else.
Also, someone made a comment about higher pressure being hard on the pump and it is not. Turning the pressure up decreases the flow rate and lowers the amp draw, making the pump/motor run cooler. If you want higher pressure in the house, turn it up. It isn't going to hurt the pump.
/ Lightning strike, well pump box failed #93
Higher pressure will make the pump draw lower amps, seems contrary, but it's true.
If you raise the pressure on the switch, the air charge in the tank should also be increased.
Mr. Valveman, what happens if you take a 50 psi CSV and set the pressure to 70 psi? If I think it thru, that should be ok. But you shouldn't run a 60 psi CSV at 50 psi?
/ Lightning strike, well pump box failed #94
Agree with you Steve, and how do you adjust the CSV setting when the CSV is inside the well casing - pull the pump?
/ Lightning strike, well pump box failed #95
I don't think they are field adjustable. If I was going to use them, I think it would be in the well, not in the house. I worry about the excessive back pressure they put on the trench line.
I don't think the CSV is bad. And replacing the Cyclestop valve would require pulling my pump, since it's hanging in line. I'm putting in the extra tank and I'll see if that helps. I'm ordering my tank now. I need a T to connect it, but obviously I don't need a second T kit with pressuer switche, etc. Should I just put in a stainless or brass T with drain vavle and a couple cut offf valves on each side , in case I need them later? Also , my current pressure valve is rated at 80 psi. should I replace that with 100 psi valve or just turn the sustem back down to about 60 psi once I get the other tank installed?
Can I sisimpy plumb the new tank inline after the the T kit and pressure switch that I already have, or does it need to go in front of the pressure switch?
/ Lightning strike, well pump box failed #97
If everyone understood this natural characteristic of a centrifugal pump, my job would be so much easier. But I would also have a bazillion competitors, because everyone would understand the CSV is better than a VFD. It is a double edged sword for me. In one way it makes CSV's hard to sell because it takes so much explanation. However, because the Simple CSV has such a complicated explanation, I don't have much competition. :)
Anytime the system pressure is below the setting of the CSV, the CSV is just wide open like a piece of pipe. If you open enough faucets to bring the system pressure down to 50 PSI when using a 60 PSI CSV setting, you are at 50 PSI because that is all the pump can do at that flow rate. Doesn't hurt the CSV. The CSV only functions when the flow rate being used is less than the pump can supply. When only one or a few faucets are open, the pressure increases to 60 PSI and the 60 PSI CSV would go to work reducing the pumps flow to match the amount being used and maintaining 60 PSI constant.
/ Lightning strike, well pump box failed #98
When you have the PK1A kit with the pressure switch attached close to the 4.5 gallon pressure tank, another pressure tank can simply be teed into the water line anywhere after the CSV kit. The extra tank can be a foot after the PK1A kit or all the way on the other side of the house. When using a larger tank with a CSV, you simply adjust the pressure switch to get a 1-2 minute run time. With a 26 gallon size tank and a CSV maintaining 65 PSI or so as yours seems to be doing, the pressure switch setting will be something close to 55/75.
/ Lightning strike, well pump box failed #99
As valveman said you can install the tank in the line before or after the current pressure switch, I would think it's easier to put the new tank on the floor and the black line from the well into that then back into your current line so its in series with the existing tank, Then the whole house filter after the pressure switch.
For the tank tee on the new tank just put a drain valve and plug the other ports, and your pressure relief valve should be ok at 80 PSI but it's not a bad idea to have a backup - so get a 100 PSI relief just in case you need to replace it eventually.
/ Lightning strike, well pump box failed #100
The CSV's that fit inside the well casing are not adjustable. They come in 40, 50, or 60 PSI. As I explained to Woodchuckdad, the adjustment is all in the pressure switch. If you want a longer run time to fill the tank, turn the pressure switch up. If you want higher pressure when using water, you will need to use a CSV with a higher pressure setting. With the CSV in the well that would mean pulling it up about 10' and replacing a 50 PSI valve with a 60 PSI one. The CSV1A will not fit in the well, but can be adjusted from 15 PSI to 150 PSI as needed. But even the CSV1A can be ordered pre-adjusted to whatever pressure you want when using water, and then again, run time would be adjusted by the pressure switch.
2022 Ford F-150 Pickup Truck (A61568)
2022 Ford F-150...
2009 Ford Crown Victoria Sedan (A61569)
2009 Ford Crown...
2014 GMC Terrain AWD SUV (A61569)
2014 GMC Terrain...
240 Massey Ferguson Tractor (A61166)
240 Massey...
80in Hydraulic Dual Cylinder Root Grapple Bucket Skid Steer Attachment (A61567)
80in Hydraulic...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
