JD 1530 tach drive
/ JD 1530 tach drive #1
ftyarker
John Deere 1530
I recently purchased a John Deere 1530 diesel and have been going through it. The tach / speed gauge was smashed and the drive cable missing from inside the sheath, so I got new parts. However, when I insert the cable into the mounting hole in the bell housing, it does not engage anything. Is there a serviceable drive gear? I assume based on the location that the cable should be driven by a gear that's driven by the flywheel teeth, am I on the right track?
/ JD 1530 tach drive #2
Welcome to TBN
Don't have an answer.
Was that cable part number AT19905 ??
/ JD 1530 tach drive #4
Tach drives usually drive off the front of the engine, never heard of any that drive off a flywheel. Call your local JD dealer and ask them, maybe you'll get an answer, maybe not.
/ JD 1530 tach drive #5
Tachometer on JD utility tractors built from '65-'75 are driven from rear of the engine camshaft via a driveshaft. Numbers in footnotes refer to numbers marked on camshaft.
/ JD 1530 tach drive #6
You know better than I do and I believe I stated that. OP stated the flywheel and I've never heard of any tach drive off the flywheel.
Tachometer on JD utility tractors built from '65-'75 are driven from rear of the engine camshaft via a driveshaft. Numbers in footnotes refer to numbers marked on camshaft. View attachment 3285521
Thanks! That's exactly the insight I needed.
/ JD 1530 tach drive #8
I fail to see where you stated I knew better than you.
Tach drive on these model JD utility tractors attaches to flywheel housing therefore I understand why ftyarker thought tachometer was powered by the flywheel.
/ JD 1530 tach drive #10
'cause you have green and I don't..... You ever gonna get that 'New Member' changed????
I haven't given any thought to getting my "New Member classification" changed because it doesn't bother me. I thought after several yrs of being a New Member the moderators of this forum would change my site member classification BUT I GUESS NOT!
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2012 International WorkStar 7500 Gallbreath T/A Rolloff Truck (A64194)
2012 International...
2020 CATERPILLAR 289D3 SKID STEER (A65053)
2020 CATERPILLAR...
2022 EZ-GO ELITE...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2011 GENIE Z-45/25 TELESCOPIC BOOM LIFT (A65053)
2011 GENIE Z-45/25...
