JD 1530 tach drive
   / JD 1530 tach drive #1
ftyarker
John Deere 1530
I recently purchased a John Deere 1530 diesel and have been going through it. The tach / speed gauge was smashed and the drive cable missing from inside the sheath, so I got new parts. However, when I insert the cable into the mounting hole in the bell housing, it does not engage anything. Is there a serviceable drive gear? I assume based on the location that the cable should be driven by a gear that's driven by the flywheel teeth, am I on the right track?
   / JD 1530 tach drive #2
Welcome to TBN
Don't have an answer.
Was that cable part number AT19905 ??
Welcome to TBN
Essentially, an aftermarket equivalent from Steiner.
   / JD 1530 tach drive #4
Tach drives usually drive off the front of the engine, never heard of any that drive off a flywheel. Call your local JD dealer and ask them, maybe you'll get an answer, maybe not.
   / JD 1530 tach drive #5
Tachometer on JD utility tractors built from '65-'75 are driven from rear of the engine camshaft via a driveshaft. Numbers in footnotes refer to numbers marked on camshaft.
   / JD 1530 tach drive #6
You know better than I do and I believe I stated that. OP stated the flywheel and I've never heard of any tach drive off the flywheel.
Tachometer on JD utility tractors built from '65-'75 are driven from rear of the engine camshaft via a driveshaft. Numbers in footnotes refer to numbers marked on camshaft. View attachment 3285521
Thanks! That's exactly the insight I needed.
   / JD 1530 tach drive #8
I fail to see where you stated I knew better than you.
Tach drive on these model JD utility tractors attaches to flywheel housing therefore I understand why ftyarker thought tachometer was powered by the flywheel.
   / JD 1530 tach drive #10
'cause you have green and I don't..... You ever gonna get that 'New Member' changed????
I haven't given any thought to getting my "New Member classification" changed because it doesn't bother me. I thought after several yrs of being a New Member the moderators of this forum would change my site member classification BUT I GUESS NOT!
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A56438)
2019 BOBCAT T630...
2017 John Deere 5075E (A57148)
2017 John Deere...
LandPride 3pt 6' Box Blade (A57149)
LandPride 3pt 6'...
