MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,209
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
That's your wallet when you buy a new tractor.Linked to wrong video. It is fireworks.
Hmmm. I get that noise if I don't have the engine at high enough RPM going forward OR backward.
That fluid looks very green. Is that really green?
Yes it does look green…but when I drained some out into a pan, it looked like new, clean oil.That fluid looks very green. Is that really green?
As for the other noise, I agree with @MossRoad's diagnosis. Personally, I would call Terry before opening hoses in the motor circuit because that oil is predominantly recirculating, and needs to be super clean.
All the best,
Peter
Yea, I think you’re onto it. Except, no load and it happens. Even on flat ground. And again, backing up a slight incline and I did run into a little bit of packed snow, and it stalled. I was in a bind here—going forward and I’d be over into the ravine. I had to keep punching at it and finally got it to move far enough to maneuver again. RPMS usually high and no difference. It would stall (movement) but motor still high rpms and no wheels trying to turn…So, to be clear, I get that noise when the load starts to exceed machine's capability to move in the direction I want to go. So, either engine RPM is too low, grade is too steep, pushing against an immovable object, etc... it's a strain noise.
If you don't get the noise going forward, but you get it in reverse and the engine stalls, it would seem to me that something is blocking or loading down the reverse circuit.
Yes, it only has 2 bolts on my 2001 425. See the 4th picture down in this thread...Mossroad…I know you’re intimately aware of this area) so…are there only 2 socket head bolts holding the pump onto the front frame? Looks that way to me and one of mine appears to have the head broken off…
Thanks for that (I remember that post…very helpful. Just wish I could remember so much good information/pointers more readilyYes, it only has 2 bolts on my 2001 425. See the 4th picture down in this thread...
2001 PT425 Kohler CH25 Oil Leak - Pull The Engine
My 2001 PT425 developed an oil leak. About 1/2 a quart every 20 minutes. Can't seem to locate it, other than a pool of oil under the engine. So time to pull the engine, put it on a stand, clean it up, and run it to locate the leak. Trying to avoid disconnecting hydraulic hoses. Pulled the gas...www.tractorbynet.com
Oh boy…should I get some crying towels ready? Prepare a burial? Ouch!@Modrob my condolences. That sounds like a part failure in the pump that sheared the Lovejoy.
All the best, Peter
Grinding noises are one thing in my book. Grinding noises followed by blowing a seal on a pump housing starts to drift into "Ouch" categories in my book. Grinding noises, blown seal, and clunk, well that's just adding to it. But it might be something simple, you never know.Oh boy…should I get some crying towels ready? Prepare a burial? Ouch!![]()
Very good points Peter.Grinding noises are one thing in my book. Grinding noises followed by blowing a seal on a pump housing starts to drift into "Ouch" categories in my book. Grinding noises, blown seal, and clunk, well that's just adding to it. But it might be something simple, you never know.
The only way to know is to pull it and disassemble it, or take it to someone who could make the call on repairs, and whether it is worth it. Checking with Terry is the best first step.
As you have written this unit was worked hard for a long time, so parts wearing out isn't (shouldn't be) a total surprise. Things wear out in machinery. In my experience, simple machines are often great candidates for repair and continue working, but a great deal hangs on whether parts (pumps/motors) are available for replacement or repair, and the labor costs associated with all of that. My experience is having access to a great hydraulic shop makes a world of difference, just like having access to a great local transmission rebuilder for cars..
One thing that I would assume is that all of the drive hoses, and wheel motors will have debris in them and need flushing to remove any potential debris. For the hoses after checking to see if they are worth saving, I would use some sponge "pigs" to clean them. (And I would use fresh sponges for each hose.) If it were me, I might ask your local hydraulic shop if they can flush the motors for you. I would also drain the hydraulic oil, clean the tank, and put fresh oil back in.
Personally, I would withhold the funerary plans until after the pump is opened.
All the best,
Peter
