What Do You Use For Anti Skid and How Do You Spread & Store it?
/ What Do You Use For Anti Skid and How Do You Spread & Store it? #1
bdhsfz6
Elite Member
Northeastern Pennsylvania
Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
It's been the harshest winter here in over a decade with a lot of ice.
For those who maintain private roads or long driveways, what do you use for anti skid and how do you spread & store it?
/ What Do You Use For Anti Skid and How Do You Spread & Store it? #2
Gravel sand is what I use if the ice is bad enough, if you have room
for a load you should invest in a pair of 20 by 20 high quality tarpaulins
large enough lay on the ground and to cover the load as well.
If you have room to store it indoors and keep it warm all the better
as its easier to load and spread. Otherwise use a kerosene fired space heater
to warm up the sand to load it.
I explained in detail to a fellow board member a while ago how beneficial
a pendulum spreader would be for his very long sloped driveway that
crosses a creek and he has been very happy with the Vicon pendulum
spreader he purchased with the salt sand tube.
The original Vicon pendulum spreaders with the salt/sand delivery tube
are ideal for this work as they reduce overspread and waste to a bare
minimum.
The original Vicon pendulum spreaders are controlled with manual adjustments
to limit the width of spread by limiting the stroke width of the delivery tube
and the flow volume by adjusting the material delivery gate opening.
The agitator is the cam arm in the bottom of the hopper that is on top of the
gear box and as strokes and rotates it breaks up any clumps.
The small Vicon pendulum spreaders are designed to be loaded on the ground
using a shovel or pails.
Using windshield washer fluid to keep the material flowing is also a common
way to do this by pouring a gallon of it in the hopper after you load it with sand
and only before you spread it to keep it free flowing.
/ What Do You Use For Anti Skid and How Do You Spread & Store it? #3
Here in the north east they mix a little rock salt with sand to prevent the sand from freezing and provide a little melting when applied.
I'd say about a bag of salt to a yard of sand. It can stay outside uncovered if necessary but a simple cover just to keep any new snow off or at least separated is simple enough.
/ What Do You Use For Anti Skid and How Do You Spread & Store it? #4
Our town's sand/salt shed is open to residents. That's where I "store" my sand. :) It's a 10% salt, 90% sand mix.
I pick up what I need when I need it and keep a few five gallon pails in both garages. I also keep 4 full buckets in the back of the UTV for traction and sanding the mailbox area.
/ What Do You Use For Anti Skid and How Do You Spread & Store it? #5
I buy a tri-axle of anti-skid from the local quarry every 10 years or so. I keep a tarp on it in the wintertime to keep the snow off it, but have in the past just poured a bucket of homemade brine over it when I needed to to loosen it up and keep it from freezing in the hopper.
/ What Do You Use For Anti Skid and How Do You Spread & Store it? #6
I used sawdust from the woodshop/sawmill for close in stuff. It's not going to do a long road but it works pretty well for the pathways. I find it actually a bit easier to clean up than sand (mostly dries up and blows away - I'm not where that matters) and it's at least as grippy. I had some concern about it slowing down melting, but it's not enough that I've noticed.
Anyone try one of these bucket / spreader combination attachments?
There are several like this on the market.
Looks like it would also solve the loading problem by letting you back into a pile of anti skid and scoop it up like a FEL bucket.
It could also be used on a FEL with a 3pt adapter and 3rd function valve.
It would work as a ballast box during the summer months.
/ What Do You Use For Anti Skid and How Do You Spread & Store it? #8
It's surprising how little sand or salt it takes to work. I'm not sure how that attachment above distributes the material but I'd estimate that it's a wasteful amount for vehicular traffic unless you were traveling 25 mph.
I do see where there's (possibly) 2 shafts down low, but any sand or stone dust that I've seen really needs to "dribble" on to a spinner and it's distributed over a 14' - 16' lane in one pass and I have a feeling that it's a more city sidewalk foot traffic attachment designed for municipalities.
But that's all a guess! 🙄
I's a drop spreader that uses a rotating shaft with paddles. The drop rate is adjustable but would require several passes to do a wide path. The drop shaft might be preferable to help chew up material clumps which can jam a disk spreader.
Here's a video:
/ What Do You Use For Anti Skid and How Do You Spread & Store it? #10
I looked at drop spreaders like that this fall, and they were surprisingly expensive. I opted to add a deflector cone to my existing 3 point broadcast spreader.
If I were just doing my driveway, I would be satisfied with a commercial walk behind broadcast spreader.
All that said, if money were no object I would be running a 4-5' drop spreader similar to what the OP is looking at.
I've been using a modified ag broadcast spreader for many years. It works well with ash but I don't burn coal anymore and need something that will handle heavier material.
I also need a way to load it. The hopper on these drop spreaders tilt and let you back into a pile to load. No need to even get out of the cab.
Yeah, they're pricey, but it may be worth the $$ for the convenience.
/ What Do You Use For Anti Skid and How Do You Spread & Store it? #12
Out of curiosity, why did you quit coal?
Another question is what did you last pay a ton for coal in NEPA?
I've been heating with wood (wood gasification boiler with radiant heat) for the past 15 years and am wondering about the time when I find it difficult to make the 6-7 cords a year?
/ What Do You Use For Anti Skid and How Do You Spread & Store it? #13
I looked at the fel mounted hydraulic spreaders that also tilted for loading, and yes, I agree that is a back saving feature!
My climate doesn't really require sanding, as the primary objective is to salt on occasion so packed snow and ice will melt off. The current 3 point spreader handles salt fine. Will sand be a problem ?
I hear you. I heated with wood until I exhausted the supply on my woodlot. Rather than buy cord wood, I switched to coal in 1989 and used it until last year. This year, Anthracite rice coal went up to $379 / ton while fuel oil dropped to $3.03 / gal. The calculated savings was only around $200 using coal, not enough to justify the work required to maintain the coal stove.
I keep the stove ready to go if prices or conditions change. The only down side is, I no longer have ash to spread on my 1.25 mile private road.
/ What Do You Use For Anti Skid and How Do You Spread & Store it? #15
I just came across this on C/L
I don't think that I'd use it often enough to justify the purchase along with the hassle of keeping the salt sand on hand and loading it with a shovel although 1 tub full would be more than enough for an extremely icy season. It's a "UTV" sized spreader.
The ag spreader I have would handle sand but it needs to be shoveled into the hopper. Not a task I'm looking forward to at my age. I store the lighter weight ash in 30 gal cans, which can be dumped into the hopper.
/ What Do You Use For Anti Skid and How Do You Spread & Store it? #17
This makes me wonder if you could find someone else who has coal ash with no use for it?
I don't know what it's like to "gather" and transport thinking it might be as dusty as wood ash or maybe it's like coarse sand that I think I remember from way back when I walked to elementary school. The town used it. (I think)
The Anthracite rice coal we get around here leaves this ash:
It's a mix of fly ash, cinders and a few clinkers. It's lightweight and works very well as anti skid. The fly ash is considered to be toxic if inhaled though, and masks are required when handling. The air filters in the tractor cab take care of it when spreading.
Transporting and storing it are the biggest problems. I'm not sure about trying to "import" it from other sources.
/ What Do You Use For Anti Skid and How Do You Spread & Store it? #19
I am enjoying this thread. I am still using coal ash here in north central PA. I have been watching the coal prices rise every year and have still been burning coal because i need the ash for my long steep driveway as well. Storage is key. I went and took some off a friend and it was frozen solid. I keep my ash in 55 gal barrels. Most are cut in half for easier handling with a plywood laying on top to keep water out. This works for me but if I had a way to store bulk anti skid material I would probably be able to switch from using coal. I believe it is regulations that are driving the price of coal up.
2017 Mercury SeaPro Outboard Boat Motor (A61574)
2017 Mercury...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
2019 WABASH DVLSHPC 53X102 T/A DRY VAN TRAILER (A59912)
2019 WABASH...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
RAINBOW PUMPING UNIT (A63291)
RAINBOW PUMPING...
