Bucket modified for snow pushing
/ Bucket modified for snow pushing #1
Williy
Elite Member
Texas
Yanmar YT 235C Yannar YRC 60 rotary cutter, Yanmar RT72 rotary tiller B75 Backhoe & bucket & thumb, LS land grader
This guy used a piece of pipe on the edge of his bucket to skim the surface
and not dig up his driveway
willy
/ Bucket modified for snow pushing #2
Pretty cool and it also saves grinding damage to the edge of the bucket.
/ Bucket modified for snow pushing #3
I tried the pipe routine and failed ...... Then I went with a snow edge with no regrets. This year is the fifth season and the wear edge isn't near half worn yet.
/ Bucket modified for snow pushing #5
Are we talking about 2 different goals?
The pipe is to not dig - plow up a gravel driveway.
Sarg's rig appears to be a "soft edge" to not scratch an asphalt, concrete or brick/paver driveway. 👍
I see were someone else has used a PVC pipe
inplace of the metal pipe
These would keep your bucket from digging in
willy
/ Bucket modified for snow pushing #8
I did some wingy things for a bucket and a blower in the past. Worked OK but gave them up after mounting an 8' power angle blade on the L4240.
/ Bucket modified for snow pushing #10
Saw a couple clips on YouTube. No experience with them. They put the blade pretty far out in front.
/ Bucket modified for snow pushing #11
willy
These are cheap Chinese knockoffs of R2 Manufacturing's EdgeTamers; EdgeTamers are great, but I hate to see the damn communists stealing American products and under-cutting them at every turn.
/ Bucket modified for snow pushing #17
The pipe edge works great for gravel driveways, I know a few who have done that. On our asphalt driveway, I just mount a piece of Trex decking to the bucket edge for snow season.
/ Bucket modified for snow pushing #18
I bought the Vevor on clearance, $39. The clamp on bolt was too thin, not hardened, and bent like a cheap folding table. I contacted Vevor, they gave me $20 back. I bought grade 8, 5/8" bolts for $10 shipped, tapped the ski, welded grade 8 nuts to ski, and it is now what it should have been. I only use until gravel driveway freezes up solid. I have EA toothbar on, and use that to dig into snow/ice when it gets built up on driveway.
I forgot what cheap crap Vevor makes. 2nd time for me...
But they do make it right, or at least acceptable.
/ Bucket modified for snow pushing #20
Bought 3 edge tamers for my 72 inch LS front loader bucket about 3 years ago , don’t use them a lot but when I do use them they work great, I highly recommend them. The one bolt mounting system is great, very quick and easy to mount or remove with a 3/4 inch ratchet !
2007 MACK GRANITE KILL TRUCK AND TRAILER (A65643)
2007 MACK GRANITE...
Schaben Pull-Type Sprayer (A66285)
Schaben Pull-Type...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
Columbia Vise (A65640)
SKIDDED PLAIN/WASTE WATER TANK (A65643)
SKIDDED...
(35) Poly Feed Pans (A66408)
(35) Poly Feed...
