scootr
Super Member
- Joined
- Aug 9, 2022
- Messages
- 8,797
- Location
- Temecula California
- Tractor
- Kubota MX5200 HST, 773 Bobcat, Cat forklift
I posted a thread on this project here > Brush Hog mods The first picture is what I tried to copy. You can see the guy welded the chains on. That's an option but I wanted to be able to replace the chain as needed.So the next question is what sized chain do I use and how do I attach it to the rotating axles? I was thinking of using a quick link to attach it, but my guess is the quick link probably won't last very long with that kind of abuse. Today I will flip over the mower and see how the blades are attached. I would assume the chain links will wear down and will need to be replaced occasionally. Also how close should I make the two rotating sets of rotating links come to each other?
The chain I used was 3/8 hardened #70 attached with grade 8 bolts using lock washers and Loctite. The chain was as long as possible meaning it come as close as possible to the deck sidewall. When mowing PTO speed is important as well as a slow ground speed for the best mulching.
I was fortunate enough to get a very old HD mower free to modify.
Disclaimer; This has been an experimental mowing project inspired by factory chain mowers and you tube videos.
Factory chain mowers or Slashers as they are called are more readily available in countries where PTO rpm is much higher than 540 which may be one reason they are not as popular here. I've enjoyed the build and the results. Your results may vary
