part-time-Farmer-NC
- Joined
- Oct 7, 2024
- Messages
- 918
- Tractor
- Kioti DK45Se
One thing that may help you determine the path is using google earth combined with the topo lines/map. Then you may see water flow issues before they show up unexpectedly. You can also use the history feature of google earth to see older logging trails. While they do grow up over time they still give you a good idea of the "path" of least resistance...
We (grandson, BIL and I) built an UTV trail about 8ft wide across my BIL land for hunting/hauling out deer etc. Took us about a month of Saturdays all day to go about 600 ish feet. Following logging trails as much as possible. The land had been selectively harvested about 5-6 yrs prior. Lots of left over limb trash that had mostly rotted away. What ever we needed to cut we simply pushed into the woods not spending time to mulch it. If you don't mind looking at it for a few years it will rot away. This was done during the winter/early spring so bugs, snakes were a minimum. Our main tools were chainsaw's, bush ax and sweat labor. Didn't even use a tractor for any of this part.
AFTER we cut the trails BIL hired a forestry mulcher dude to come in and grind it down to ground level. Its a fairly rocky area (compared to my farming land) but not so much the FM had many issues.
The grapple will be one of your bestest friends around any house and a good tiller for gardens if you plan to do them each year.
Sounds like you have a lot of work ahead but it's doable, one day at a time. If you kinda plan out your goals per day/week it seems to help me stay focused. Easy to lose focus when there are so many individual tasks to accomplish.
He just purchased a kubota to keep down there. His SIL is a bota dealer and is hooking him up with good pricing on equipment/attachments. Mainly path management and grapple to move the rocks around and bush hog to keep the paths from closing in.
Sounds like a fun/high reward project. Good luck on it.
