WI-citizen
I'm very nervous that will be the style of machine I end of purchasing without the convenience of going indoors. I'll have to park it outside with a lovely tarp and bungy cords around the mast when not in use. lol
Not that specific model, but there are kinda half way between machines; that can lift like 48", if that will stack what you need. I do think they are more money than you want to spend.I've looked at these also, but it won't lift high enough to stack indoors. I'm still stuck between the forklift vs skidsteer with a seven foot garage door.
I haven't looked into the standup options yet. I do prefer LP instead of electric though.Not that specific model, but there are kinda half way between machines; that can lift like 48", if that will stack what you need. I do think they are more money than you want to spend.
This one only does 2200# though, and I can't imagine trying to use it on anything other than concrete or maybe asphalt.
This one from Northern Tool seems like it would fit the bill, bit for the price, I'd get a Nissian/Toyota propane lift.
I found this on Ebay, used too.View attachment 2105535View attachment 2105536View attachment 2105537View attachment 2105538
Check out the specs for a Massey Ferguson 2500 forklift: Massey Ferguson 2500 Forklift: In-Depth Technical SpecificationsI'm very nervous that will be the style of machine I end of purchasing without the convenience of going indoors. I'll have to park it outside with a lovely tarp and bungy cords around the mast when not in use. lol
That's the thing with auctions. You must determine your limit before you arrive, and not get caught up in the bidding. I've seen old welders sell for more than a new one at farm auctions.If it tilts that far that would be great!
The 1994 DEERE 482C will probably go over $10k.
I've been on both ends of that.That's the thing with auctions. You must determine your limit before you arrive, and not get caught up in the bidding. I've seen old welders sell for more than a new one at farm auctions.
Tilting it will probably buy you a few months until you forget, and rip the door header down...Check out the specs for a Massey Ferguson 2500 forklift: Massey Ferguson 2500 Forklift: In-Depth Technical Specifications
Its height is 96"/7'. By tilting the mast back/forward as far as it will go it should go under a 7' header. Is your concrete floor poured to withstand the weight?
Then there is the auction websites if you're into auctions: Pardon Our Interruption
Can you rent one for a month to see if it does the job ? Around here you can rent by the day.
Usually need it now when it's needed. I have no calendar or renting would be an option.Can you rent one for a month to see if it does the job ? Around here you can rent by the day.
I've looked at these but I would need a much larger tractor than a JD 1025R. Also, it wouldn't fit through a seven foot door. If I already owned a big enough tractor I would have owned this attachment a long time ago.Attachments
This is a low-cost used three-point hitch forklift that I picked up. It was a long drive and the guy said if I'd make the drive I could have it for $350 and I also paid $150 for a very heavy hydraulic top link bar. The seller had used it in a seed business for unloading semis and putting the pallets in a barn.
Our tractor in the picture is a 265 Massey Ferguson with weighted wheels on the rear.
At the time we purchased it, I think the manufacturer is located in Iowa I think was still in business and the unit around about $2,000. I best I remember.
These kind of solutions are inherently dangerous without question. That photo was to show Max height but I would not want to move anything other than on concrete. Just enough to get clear of the truck bed then let it go back down to the foot or so off the ground.I've looked at these but I would need a much larger tractor than a JD 1025R. Also, it wouldn't fit through a seven foot door. If I already owned a big enough tractor I would have owned this attachment a long time ago.
I have 18 feet clearance under my eaves and have 16 foot high pallet racks I use for storing implements etc. Side shift is a must have in my books as well as an auto tranny when sticking 2,000lbs pallets of stuff on a rack shelf 16 feet off the ground.Have a lot of hours on a forklift, but not quite as many as you, although my weeks were usually 50-60 hours long. I also never had much use for the side shifter, because once you "learn" how to do it without side shift, using a side shifter is just another lever that you don't need. If you never learned to do without side shift, it makes it impossible to work without one.
Another "old school versus new era" ways of doing things.
David from jax
A pallet of sacked concrete is ~#3300 pounds where I live. All I know is a 3400lb rated lift forklift wouldn't lift it off the bed of a pickup so, I had to hand unload a big portion of it.Right, 5000 pound lift capacity. It may be more than you need but a pallet of cement or block is more than 3k pounds. Anyway it's worked good for me. It's a name I can always get parts for ( we did brakes and axle seals last year). It fits in the container or barn. There are as others have mentioned lots of options out there.
Something like this rough terrain Massey Ferguson?
About 40 years ago I had a rough terrain forklift with a Dodge slant-6 engine. It was a good machine for outdoor work.
