Battery Info
/ Battery Info #61
I spent the extra money for an AGM for my Kubota L3130, granted it was not an Optima, and it still died in 3 years, even with a battery tender at that was always connected. Still using the tender, but on an Interstate lead acid battery. Been a year so far without issue. The interstate wasn't exactly cheap either, but cheaper than the AGM.
/ Battery Info #62
"It’s representative of a heavy handed government seizing power from the common man."
That 'heavy handed government' is the one created to manage the democratic republic (under god) which we pledge allegiance to because our founders and fore fathers were most familiar with the alternative options running the gamut from anarchy to monarchy, autocracy, despotism, dictatorship and hoped letting ''the people" decide offered the best hope for mankind.
Our founding principles are relatively easy to understand, if not so easy to implement fully. Alas, if we do not select men (and women) of principle, we may find ourselves with a "heavy handed government" absent any recourse at the polls.
And, by the way, it was only a movie. Although the depiction of the ignorant, bigoted Southern Sheriff appeared very realistic to those of us who'd watched the Civil Rights efforts down South and, I can only surmise, to those who suffered such bigots since our kind first set foot on "this land."
/ Battery Info #63
My 2022 Massey Ferguson 4707 tractor has a dead battery. The date of 09/11/2021 is on the battery, so I'm guessing that's how old it is.
I bought a battery for my wife's van last month, and the guy at NAPA said that batteries only last 3 years on modern cars because of all the electronics on them that never turn off. Her battery was 3 1/2 years old. It looks like my battery is just over 3 years old.
Does this make sense to everyone? I used to get five years out of a battery, and sometimes in older vehicles, even longer. 3 years just seems like it's too quick to die and need replacing.
I do not want another Massey Ferguson battery. I'll go to NAPA and see what they have during the week. Before I go there, I'm curious if this label makes any sense to you?
I haven't removed the battery yet. I should do that now, but it's too cold out there, and I'm going to work on my fence first.
Is there something that I should ask for when I go to NAPA to get a better battery?
/ Battery Info #64
I was told East Penn makes different grades of batteries (like good, better, best, etc) and the Napas were the lower end. Deka was better/best
That im not sure about. All my generator batteries are Deka branded. I get them in lots from manufacturers supplyhouse. I have run accross Napa branded batteries in servicing the generators, and ive been impressed by how long they last. I dont see any difference than the deka branded ones. The batteries that give me the most problems……Walmart.
/ Battery Info #65
I agree on the purchase of label rights and home depot. I purchased a John Deere edge trimmer from them. It didnt work. I took it back and they told me to take it to local JD dealer. That dealer told me to return it to HD, Because HD sells mexico independent manufactured JD equipment that simply has a licensing deal with JD. They are not made by JD. I had to get into a shouting match with home depot manager to get my money back. I learned the hard way.
/ Battery Info #66
I've had several NAPA batteries fail prematurely and the warrantee is crap. I've had good luck with Interstate and is mostly what I buy now . Fairly widely available hear in Eastern Mass. As was mentioned the group number is important as it gives the post orientation as well as the size. I use Optima spiral wound in my plow truck because the electrical load is so high that conventional batteries can't keep up in a storm and I would have to stop and let the battery recover with every thing turned off. The yellow optima doesn't flinch and lasts well.
Alec
/ Battery Info #67
Ariens snow blowers from HD are unrepairable also!
/ Battery Info #68
Hi,
You have a common problem and a really good question.. There is no reason that a sealed lead acid battery cannot last somwhere in the range of 5-8 years. There are a few factors that effect the life time aside from what the NAPA guy mentioned and I'll get to that in a sec.
Temperature plays a large roll in the life of a battery and the higher the long term ambient temperature the greater the derating. So, not that it is easy to do but it's beneficial to keep your machines out of the hot sun when you can.
Ideally you never want to fully charge a battery to 100% of its capacity never mind over charging it and that is the next cause of trouble. Without getting into the details batteries are often over charged to get the maximum energy storage density but this is a tradeoff on life time. We don't have a choice on the peak charge voltage where it is a function of the charger in the machine but it is something to consider. Many chargers push their charge termination into the lower 16V range and this is probably ok when it is equally shared across all of the cells but that usually is not the case especially as a battery begins to age. However if you keep your battery on a charger/tender be aware of the charge termination voltage. You want to maintain the battery's capability so keep the termination voltage to ~13Vmax
So what is "age". Age isn't just the number of calendar years/days that you have had the battery in service but actually the number of charge/discharge cycles a battery has gone through. Theroetically every battery has a limited number of charge/discharge cycles which is part of the reason why it is beneficial to not fully charge or discharge a battery. By limiting the energy transfered the effective number of cycles can be increased. And, this leads to the NAPA guys comment.
What he said is partially true because the 100% on time systems increase the depth of charge. But, under these conditions the accessories and systems sip on power as compared to a starter kicking in. The battery doesn't mind a step load as much as it does small amounts of energy being syphoned off over a period of time. A trickle discharge can easily take a battery outside of it's specfied operating range and when it does the internal chemistry begins to change in a negative way. This is a subject in itself but what I will say this is also when the trouble starts and aging accelerates.
In addition to accessories all batteries have their own internal impedance, not to be confused with source impedance. The internal parallel impedance is like a built in resistor that bleeds away charge and you can't do much about it. Add this to the parasitic accessory loading and a battery can be damaged in just a few days without you ever noticing it. From that point the damage slowly grows and this is measureable with a battery tester as the source impedance/resistance. An increasing source impedance is a leading cause to early starter failure. As the source impedance increases so does the sudden drop in Vb when a load is appled. Add this V loss to those in the cables etc. and by the time it is measured at the starter V is can be much lower than it should be.
Starters are "power" type loads where the volage and current are balanced across the inductance in the coils. When the volage falls the current rises to maintain the balance needed to turn the engine over. As current rises there is excess heat in the coils which can be high enough to damage the wire insulation or even the wire iteslf and the started fails. So, although a little off the topic of batteries something to think about especially if you have replaced a starter recently.
So, at this point my 5 cent tour of batteries has ended. There is so much more to them but I hope this helps some and doesn't trigger more questions than it answered. In a nutshell there are a few take aways..
Try not to discharge a battery too deeply (an engine that starts hard or won't start etc.). Start the engine every couple of days for maybe 5 minutes, it doent's take long to give the battery a little juice. Or maybe just hang a slow charger on it for a few minutes. Avoid fast chargers and don't leave the charger on the battery once it's charged even when they say it's ok to do it. Unless you have a really good quality charger many do not have the accuracy and will over charge anyway.
Use a trickle charger when a battery is idle for more than a couple of days with no load to compensate for the internal impedance. Trickle chargers have output capacities of 10s of mA not amps. If the battery is installed in something disconnect one of the battery leads ( Tractor/lawn mower etc.).
Keep a solar window charger in the car and plug it in when the car is parked for more than a day or two. This will provide enough energy to support those parasitic accessories without drawing down the battery. Don't forget to face it toward the day's mid morning sun.
Don't park in the hot sun after driving and crack the hood if you can to improve cooling in the engine compartment. Batteries usually sit high where the heat is the greatest when the fan isn't running. Some cars the electric keep the fans running until it cools down.
I consistanly get long life from all of the batteries in the several machines I have. But, I have messed up a couple of times by letting a few slowly over discharge only to have them fail early. Another tip.. Get a blue tooth battery monitor that uses an app on your phone.. It is a good way to keep tabs on a car/tractor battery.
/ Battery Info #69
Alec
I was denied warranty on my last set of NAPAs and that closed the door on them with me. The made 12 volts and tried to tell me that was enough to start a 9L diesel engine.
I told them they were full of excrement. Done.
/ Battery Info #70
Not sure this is the place to discuss, but have you ever comprehended the level of duplicity, arrogance, and waste of the multi-layered, oppressive government we now have is?
Bureaucracy? Waste? Deficits? Criminal behavio
“The people” can only vote for the candidates presented to them, and BTW, you know as well as I this took 100 years to happen.
Agree, but when 99% of them are backing huge wasteful gov’t, what is one to do?
Rambo was filmed in the fictional town of Hope, Washington.
That was actually a “northern” sheriff, so there’s that.
/ Battery Info #71
If they want to play the game, then take them home. short them to 1v. then bring them back. games work both ways
/ Battery Info #72
They keep them overnight on their charger, then test them next day for that very reason.
They always seem to have just enough charge to pass the warranty test.
/ Battery Info #73
/ Battery Info #74
Batteries have a memory. You may be able to bring it back to life by recharging it, but to get the memory of full charge, fit the charger to a good, near-new battery, then jumper cable your old battery to it so both batteries are charging. Leave it overnight, then try it.
/ Battery Info #75
I always buy the highest amp rated battery I can get in the size I need. The battery in my farm tractor is over 8 years old and came from Sams club. The batteries in my Ford diesel pickup are 6 years old and still appear to be strong. They came from Walmart. I have had good success with their batteries. I have used them for20 years.
/ Battery Info #78
My pickup (diesel F250) has 2 batteries and it typically sits for 2 weeks or more at a time. The batteries are dead when I try to start it, so I've gone to parking it next to an electrical outlet and plug it into a trickle charger when I'm not using it. For my vehicles that are to far away from an outlet, I pull the battery and bring it inside and put on a trickle charger. Everything works so much better since I started doing this.
/ Battery Info
The battery arrived Thursday morning. From the time it was ordered, to Walmart sending it out, and Fed Ex keeping me updated every day where it was at, I have to say it was a pretty good experience buying the battery from Walmart. I've never done that before.
Since getting here, the box is sitting on my garage floor. I hope to install it today, but it's raining right now and really too muddy to do anything once it's installed. I might wait another week.
/ Battery Info #80
Did you pay a core charge?
2022 GREAT DANE CCC-3314-21053 53X102 T/A DRY VAN TRAILER (A59912)
2022 GREAT DANE...
2003 International 4300 National Crane 326A 7 Ton Straight Boom Crane Truck (A61573)
2003 International...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2018 TAKEUCHI TB240 EXCAVATOR (A64279)
2018 TAKEUCHI...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
2020 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A61573)
2020 Peterbilt 579...
