Battery Info
/ Battery Info #101
My 2022 Massey Ferguson 4707 tractor has a dead battery. The date of 09/11/2021 is on the battery, so I'm guessing that's how old it is.
I bought a battery for my wife's van last month, and the guy at NAPA said that batteries only last 3 years on modern cars because of all the electronics on them that never turn off. Her battery was 3 1/2 years old. It looks like my battery is just over 3 years old.
Does this make sense to everyone? I used to get five years out of a battery, and sometimes in older vehicles, even longer. 3 years just seems like it's too quick to die and need replacing.
I do not want another Massey Ferguson battery. I'll go to NAPA and see what they have during the week. Before I go there, I'm curious if this label makes any sense to you?
I haven't removed the battery yet. I should do that now, but it's too cold out there, and I'm going to work on my fence first.
Is there something that I should ask for when I go to NAPA to get a better battery?
Use a battery tender when the vehicle is not in use for more than a few days. Noco 800milliamp hours or Battery Tender Jr. You battery will last 5 or more years. I use them on everything and get and average of 7-8 years on most batteries even on automobiles.
/ Battery Info #102
Once a year, each vehicle in my care gets its battery disconnected, and the Optimate-6 desulphating battery charger connected for a 24-hour "battery saver" cycle. I started that routine about 10 years ago, and have not replaced a battery since.
I've got this charger from HF, it has a 'repair' mode. It's actually helped a couple batteries. Then a couple months ago, I connected it to one that has some age, but was doing 'ok' in a forklift. After it 'repaired' that battery, it won't crank anything now. I put the charger back on it for more 'repair' but it just draws lots of amps and has no cranking ability, probably (I suspect) a shorted cell.
/ Battery Info #103
I usually get 5 to 7 years. And that's with today's new vehicles.
/ Battery Info #104
My suggestion is to go to Interstate Battery if you have a shop near you? They only do batteries, and they're good at what they do and sell. Just my .02 cents worth.
/ Battery Info #105
Used to be my last two didn't hold up very well.
/ Battery Info #106
My Kubota L 3901 is 7 years old and sits outside, covered, all year and battery is good still. 2002 F 250 with 7.3 diesel gets maybe 4 years and then both batteries need to be replaced. Just did the truck last month when it got colder here. Trying different batteries each time and have not yet found one that is superior for the truck. Now my boats deep cycle batteries seem to like Interstate so far.
/ Battery Info #107
As I recall, the life of a battery is mostly determined by the discharge/charge cycles it goes through, along with how well you maintain it.
"Age and Usage Patterns​
The age and usage patterns of a lead-acid battery can also impact its lifespan. The lifespan of a lead-acid battery is typically measured in cycles, which refers to one complete charge and discharge cycle.
The number of cycles a battery can endure depends on its quality, usage patterns, and maintenance. According to the search results, the average guaranteed lifespan of a basic lead-acid battery is around 1,500 cycles.
However, poor management, no monitoring, and a lack of both proactive and reactive maintenance can kill a battery in less than 18 months. With proper maintenance, a lead-acid battery can last between 5 to 15 years."
I recently acquired an old battery, never really used, but it sat discharged for a few years, the build date was in 2018! I put it on a battery recondition cycle a few times( says it gets rid of sulfation) and it now is holding a charge. One of these days, I will put it in my van to see if it will perform well or it is just a surface charge.
/ Battery Info #109
Have a friend who remanufacters old batteries.
Every wonder why OEM batteries last 5-6 years and ANY new one usually 3 years?
It's the spec they are made to..
Most new battery's have very thin plates which gives alot of CCA, but horrible longevity. The thin plates sulfate and sluff off sulfated material which falls to the bottom of the battery and eventually kills them. Battery saver modes may initially extend life, but it just sluffs off material the eventually shorts them out.
/ Battery Info #110
A battery maintainer is crucial for the health of a battery that is only used seasonally. Ask anyone with a motorcycle, snowmobile or riding mower how many batteries they went through before they figured that one out. Your tractor battery should have lasted longer than 3 years. AGM battery in something as simple as a tractor is a waste of money in my opinion, My wife's car has 60 fuses, my pickup truck has about 6. Take the extra money you would spend on an AGM battery and buy a good maintainer. I remove the batteries from my seasonally used machines and keep them charged in a place where they won't freeze.
/ Battery Info #111
I dont know. Ive had 2 interstates fail on my tractor . The first was 1.5 yo, the last was 11 months. Alternator tested good. Both batteries had shorted cells. I went with AGM this time around. Tractor bouncing probably isnt a good thing on flooded cells.
/ Battery Info #112
The are Battery Tenders and then are the newer battery chargers that have a repair mode. It's the repair mode mode that pulses and knocks off crap on sulfated plates I was referencing in a previous post.
Battery Tenders.......I use them on everything I have in the barn.
/ Battery Info #113
This thread got me thinking of my SO's 2011 MF 1529 tractor. It only has like 180hrs on it, and still has the OEM battery in it. That's quite a run.
Got you beat (so far) , I just changed out the OEM in my 2008 MF 1540 this past summer.
It never once had a trickle charger , or battery tender on it during its long lifespan either.
/ Battery Info #114
On the tractor, i added a 1amp smart charger to keep it topped off. No snow this year, so tractor has been sitting quite a bit. Its hardwired onto battery posts and has quick disconnect outside hood so i dont have to open hood to unhook.
/ Battery Info #115
We were a jobber going back 50+ years and the local rep was fantastic.
Never a warranty claim in those days… about 10 years ago it got bad and we stopped stocking them… several warranty claims from customers and not one honored…
/ Battery Info #116
The only issue with AGM batteries is they NEED - WANT a higher voltage for charge levels to be fully charged. Depending on or where your installing this an AGM might actually be a hindrance and negative over just a regular Lead battery if the alternator charge output is is low voltage wise
On a tractor vibration is a factor as well for life of the battery
/ Battery Info #117
I haven't seen that and I have several AGM's in service. There is a ton of misinformation and contradictory so called "facts" out on batteries that it can be hard to wade through all the bull and hype.
I just treat conventional (flooded lead acid) the same as I do AGM batteries I see the same or maybe a bit better lifetimes on the AGM. But to me the major advantage is that the corrosion on the terminal and cables is mostly completely eliminated, and then the advantage of no gassing off of corrosive and explosive gases. And no liquid spilling while carrying or handling even when slinging them up into awkward places.
Here is an interesting search and it just shows how much conflicting information is out there;
charging voltage lead acid or AGM at DuckDuckGo
/ Battery Info #118
Sounds like the bean counters took over from the engineers.
That has ruined more companies than anything I’ve ever seen.
/ Battery Info #119
Agree. In real world applications the charging characteristic of an AGM, or traditional battery is close enough, especially with varying engine rpm’s to essentially make it irrelevant. In either case your simple alternator is simply going to present a voltage higher than the battery’s. What current flow actually occurs at those voltages will depend on the battery, not the alternator.
The alternator doesn’t know if current is flowing in the battery or through pumps or lightbulbs on your tractor.
Lithium batteries, though, are different enough to warrant consideration
/ Battery Info
The weather was nice today and the ground is dried out, so I decided to install the new battery and get the last of my mowing done.
The new battery is identical in size and configuration. It was a simple swap.
I got in my tractor and everything was dead. I tried again and the dash lights came on, but the started didn't make a sound. I put my volt meter on the battery and it read 11.8
I hooked up the jumper cables to my truck and I was able to get some clicking noises from the starter. I let it run for 15 minutes without any improvement. I let it run for another 15 minutes without any improvement.
I decided to try my backhoe battery instead of my truck. The backhoe battery is less then a year old, 950 CCA. After hooking it up, I got the same results as with my truck. I let it run for half an hour and there wasn't any improvement.
With the jumpers on the new battery in my tractor, I'm at 12.08 volts. Without the jumpers, the battery in the tractor is at 11.8 volts.
This is odd to me since I was expecting 14 volts or better with the jumpers. I've had the new battery on a trickle charger for two weeks, and it's odd that my voltage is so low.
Right now I have an old battery charger on it for the night to charge it better than the trickly charger. It's an older Schumaker charger, and the meter isn't showing anything to indicate that it's charging. I don't know for sure if it's working. I probably need to put my meter on it, but I haven't done that yet.
What am I missing?
(INOP) LAYMOR SM300 RIDE-ON SWEEPER (A65054)
(INOP) LAYMOR...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2013 5x8 Port City S/A Enclosed Cargo Trailer (A66738)
2013 5x8 Port City...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
2023 JOHN DEERE 35P EXCAVATOR (A65056)
2023 JOHN DEERE...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A66736)
2022 Ford F-150...
