Stuck yanmar 165D
/ Stuck yanmar 165D #181
Well, there goes another good thread.
Or maybe not. After all, most tractors do run - yet we still find things to talk about.
He hasn't even tried to use it yet....
I would like to know what the problem was with the replacement clutch and how it was made to work. There are a lot of YM155/165s out there using that clutch.
rScotty
/ Stuck yanmar 165D
Unloading it this morning I noticed it is terribly hard to steer with that loader....set the bucket down, and it steers nice and easy. What can be done for that? As far as the clutch, I returned the one Allstatesag sent and got the correct one from tractorpartstogo. That one was a perfect fit. Tomorrow, going to drain oil again and take off oil pan and put in new gasket....forgot to do that before and it was leaking a little oil this morning after the oil was warm.
/ Stuck yanmar 165D #183
No power steering back then. But my guess yours is hard if not harder to turn being 4wd. Esp. with a good load in the Bucket. I have to be moving pretty much. I bought it for the cool to me factor! And yes it is. :cool:
That tractor will last you for Yrs. is my Guess.
63 ford Old as me!
/ Stuck yanmar 165D #184
The short answer is nothing. Don't ignore that having more weight on the 3pt helps the steering immensely. Also keep the front tires inflated The longer answer is Power Steering - except that Yanmar didn't offer it in that model. The smallest Yanmar with power steering was the next one up in size. And that one had rather "iffy" power steering in the form of a hydraulically assisted drag link... also known as "that leaky Yanmar steering". Some types of home-made add on power steering were tried, but I never saw one I liked. If I had, we would have put it onto ours.
Do not force it, set the bucket down and reposition, learn to use the steering brakes to make small easy steering adjustments, take smaller loads, and just be glad to have a loader at all. And above all, do NOT drive it in 4wd with a load in the bucket.
It's a tiny tractor basically designed to pull things, not work a loader. But in spite of that, we built two houses with our YM165D. So it can be done...just go slow with it.
rScotty
/ Stuck yanmar 165D
Couple thing....I will have to replace the brake shoes. Also, not sure if 4x4 is engaging. Also, loader boom raises perfectly and bucket runs perfect, but lowering boom is slow.....I mean slow, like as in lowering under its own weight. The lever also is sticking, not sure if that has anything to do with it. Yesterday morning when I unloaded, the boom lowered just fine and went down as fast as it went up
/ Stuck yanmar 165D #186
It should raise and lower at the same rate. There's a wire screen in the bottom of the Rt. Hand loader upright. That upright doubles as your FEL oil reservoir. You may want to drain and clean. Look for the fitting at the bottom of the upright where the return line attaches. Make sure screen is clear and return hose not plugged. A good oil for that loader system is JD HyGard winter viscosity forever. Or any 5w30 motor oil for shorter term use.
You can use WD40 or PB blaster on the levers.
To see if 4wd is engaging lower the bucket so that it lifts the front axle off the ground. Engage low gear and 4wd. Drive forward a few feet with the rear tires causing the bucket to slide on the ground. That is so you can watch to see if the front wheels are turning. They should be turning if 4wd is engaged.
If the engagement lever is difficult to get OUT of 4wd don't drive it any distance in 4wd.
enjoy,
rScotty
/ Stuck yanmar 165D #187
Like @rScotty mentioned, get some weight on the back end.
You can get wheel weights or add a drawbar lock and use front weights on the back.
Either brand works.
/ Stuck yanmar 165D #188
/ Stuck yanmar 165D #189
The Old International BH on the Ford in my Prev. reply and Pic. is what I use for counter balance to lighten up the front. Super heavy so much it's easy to do wheel stand on the Yanmar YM2000 with it lifted.
/ Stuck yanmar 165D
What can I do about the loader going down at a snail's pace
/ Stuck yanmar 165D #191
Wheel weights are good for traction and lowering overall center of gravity but won't unweight the front wheels to help with steering or other axle loading concerns.
Ever see a small SCUT with a full bucket, lift and flip forwards. Rear weights are key to stabilize the machine in operation.
/ Stuck yanmar 165D #192
Would the existing steering be robust enough to add an electric power steering from a newer car? From some of the YouTubes I've watched it's quite easy to add.
/ Stuck yanmar 165D #193
Or you can just get an MTD Cub Cadet eSteer assist unit. They are called EPS units. Some are universal enough as kits to add on now.
EPS Replacement Service Kit
Item: 759-05105
* This part replaces: 618-05084, 618-05084A, 918-05084, 918-05084A
/ Stuck yanmar 165D #194
Do you have any quick disconnects on your loader hydraulics. If so, check them out to make sure they are plugged in all the way.
/ Stuck yanmar 165D
When I unloaded the tractor, the loader worked perfectly. I drove the tractor around for about 15 minutes and then the valve handle stuck and started acting up. Got the valve handle unstuck, but now it just moves down slow, as in like an inch in 5 seconds
/ Stuck yanmar 165D #196
Assuming that means you have no quick disconnects. Must be a control valve problem.
/ Stuck yanmar 165D
Going from memory, no quick disconnect
/ Stuck yanmar 165D #198
/ Stuck yanmar 165D
I really don't know anything about hydraulics, can someone help me find a replacement (and one that won't cost me an appendage) hydraulic control for this yanmar? Thanks
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
GEN POWER 40KW GENERATOR (A64278)
GEN POWER 40KW...
SHOPBUILT T/A TRAILER (A64278)
SHOPBUILT T/A...
PAIR OF SPAN-ON RIMS (A64278)
PAIR OF SPAN-ON...
