/ Harbor Freight Tools that don't suck #15,841
Harbor Freight also sells some pretty darn good tools which give the high end brands a run for their money … but they do cost more than their entry level/disposable tools
Yep, especially their generators which often come from the same factory as the "name" brands.
/ Harbor Freight Tools that don't suck #15,842
I buy my welders at HF, just bought 3 about 2 months ago and put the extended warranty on all of them. My employees use them and so do I.
All IGBT machines, which is what everyone else is using today.
/ Harbor Freight Tools that don't suck #15,843
I never buy the crap tools, Only Icon or Pitts Pro stuff. Never would buy any drills there. I only purchase Chicago Latrobe or Cleveland Twist.
/ Harbor Freight Tools that don't suck #15,844
Anyone have any experience with the Hercules ultra impact wrench? Been working at removing my Gravely mower blades that a Gorilla installed. Got 2 of 3 out using the Bauer electric plug in impact wrench, lots of heat and hammering required. 3rd one isn’t budging. Just wondering if the Ultra would be a decent upgrade from the Bauer plug and play.
/ Harbor Freight Tools that don't suck #15,845
A half inch breaker bar should romove it easy enough.
/ Harbor Freight Tools that don't suck #15,847
When I have a tough nut to loosen, I always use my Thor 1/2" air impact. It makes well over 1300 pounds feet of unfastening torque. I'd never use any electric impact, they just don't cut the cheese IMO. I use the Thor when replacing wear steels on snow plows as well. If it won't bust the A325 Dome head plow bolts, it will twist the shank off.
/ Harbor Freight Tools that don't suck #15,848
I have been very impressed with the quality and performance of my HF Hercules grease gun.
/ Harbor Freight Tools that don't suck #15,849
Tried with a breaker bar and 4 foot cheater. No go.
Holey-cow, that's interesting. With a 4' cheater bar, something should have loosened or broke.
The nearest Harbor Freight store is too far away from me to be of any help, so I will wait to hear your results.
good luck
/ Harbor Freight Tools that don't suck #15,851
Try some heat followed by PB Blaster.
Yeah, that’s been done. I’m old and fat, so my energy level isn’t what it use to be, so will have another whack at it a little later. May try a 6 foot cheater bar. Hard to handle when on the bottom of a mower though.
/ Harbor Freight Tools that don't suck #15,852
If a cheater bar won't move it, I'd try putting it under stress by reefing on it and having a helper give it a few blasts from an air hammer with a pulley driver against the socket. If you don't have help available, preload the cheater with a jack.
/ Harbor Freight Tools that don't suck #15,853
The new Bauer corded shows to have 1050 pounds of breaking force,
the high torque Bauer 20Volt only shows 1000 pounds,
the Hercules Hi Torque 20 Volt list 1200 pounds,
but this one 1/2 in. Ultra Torque Impact Wrench delivers up to 1500 pounds,
and this 3/4 in. Ultra Torque Impact Wrench delivers up to 1650 ft.
The torque multiplier tools also work very well, I have broken several bolts with one like this;
/ Harbor Freight Tools that don't suck #15,854
Can you SAFELY rig up a hoist to get the mower deck vertical? Then you can put all your weight on it.
/ Harbor Freight Tools that don't suck #15,855
I might be able to pick the front end up with my tractor.
/ Harbor Freight Tools that don't suck #15,856
May have to try that Torque multiplier.
Have my eye on one of the Ultra Torque. I don’t have any 3/4 inch sockets anymore (since we sold the dairy farm), but maybe need to get that 3/4 just to have and add sockets as I need them. Can always get a reducer to run 1/2 stuff but that tends to eat into the capability some.
I don’t have a large enough air compressor to run the Thor hammer that 5030 recommended.
/ Harbor Freight Tools that don't suck #15,857
Not something I have or want anyway. I have an ARO air greaser with a 100 foot grease hose and it rests on a 150 pound open head grease drum. I do carry lever guns in all my pto driven implements but when I service and grease them, it's in front of the shop so I use the air greaser and no lock-n-lube coupler either, just an adjustable jaw genuine Alemite coupler. All my lever gins have clear polycarbonate barrels and I bulk fill them from the air greaser. I like the clear barrels because I can see how much grease is in there and refill them before it is depleted. Just not a fan of battery powered grease guns and I did buy one of the Bauer ones, but returned it not used. Just didn't impress me. They are bulky, only take grease tubes and are messy to fill. My ARO air greaser has none of those detractions. I've only taken back 2 HF tools in my entire lifetime of buying HF merchandise. The 12 volt Bauer grease gun and the HF dual analog battery tester and the only reason I returned it was it's 12 volt only and I required a 6 volt one. My mistake and as always, HF refunded my money, cheerfully and no questions asked. Next buy on the agenda is the HF 2 stage vacuum pump. I keep borrowing a buddy's pump when I do ac evacuations. Time I get my own. I own everything else (all HF btw). Their ac gages and manifold works very well and so does their can tap fitting.... and I'm going to extend my warranty on the 3 welders I bought earlier this year to 4 years. I'm really impressed with the Vulcan Pro-Tig 205, especially after I added the CK Worldwide water cooled Series 17 TIG torch with flex head and the Everlast water cooler. Compared to the Lincoln Square Wave TIG welder I sold with it's Lincoln water cooler and Lincoln torch, the Pro-Tig not only produces a better weld but it's easier to control and the foot pedal on the Vulcan is light years better than the Lincoln as well and amazingly, the Vulcan was 1/3rd the original price I paid for the Lincoln. I did keep my Lincoln Ranger 8, engine drive and HF setup for field work however.
Even my good friend and mentor who is nuclear certified TIG (he taught me the in's and out's of alloy TIG welding) told me the Vulcan Pro TIG is heads above his Miller Dynasty. I also bought 2 Titanium plasma cutters. I use the 65 amp (that comes with the hard interface plug (and I kept the interface cable from the Hyper Therm I sold, to interface with my Shop Saber plasma table and I also bought the 50 amp Titanium plasma for use in handheld operation and it sits on the HF Vulcan welding cart along with the Pro-Tig and the water cooler. Very nice powder coated roll around cabinet with plenty of storage space and lockable doors plus the bottle capacity is 2 bottles. I run 2 125 cubic foot bottles, one straight inert shielding gas for the TIG and one O2 bottle for the plasma. I made out like a bandit on the whole deal. I sold the Hyper Therm plus the Square Wave Lincoln and threw in a full 125 cubic foot bottle of inert gas for the TIG, bought everything at HF, 2 plasma cutters, the TIG machine, the CK water cooled torch and the Everlast water cooler and the Vulcan roll around cabinet plus extra consumables for the plasma and a complete set of Pyrex and porcelain cups, collets and diffusers for the CK torch and 3 gallons of anti freeze solution for the TIG cooler and still put over 1500 in the bank. Glad Lincoln rests on it's trade name but the Vulcan is a much better and easier machine to use, plus it's 100% digital and actually remembers the previous settings. It's easy to use and has a real nice HF start as well with no points to wear out, all 100% solid state IGBT driven. Same with the plasma cutters. I really liked the Hyper Therm but the consumables just got too expensive and I go through a lot of consumables, especially with the plasma table even with the THC control.
I really looked hard at plasma tables as well and settled on the Shop Saber. it wasn't a cheap date but it came with everything required but the plasma cutter and it came completely assembled. It even has a wireless Blue Tooth remote so I can run it from anywhere in the shop. Not really for the hobbyist as the price was pretty steep, but it's a well built industrial grade table.
So, I'm a Harbor Freight junkie but only the high end HF tools, not the one use throw away stuff.
I have a HF credit card and when I buy big ticket stuff (I bought the welder and the plasma cutters and the cabinet in one shot), The HF card not only gave me purchase points but a deferred no interest payment over 36 months which I paid off early anyway. That and my ITC membership has saved me a ton of money. The 65 amp plasma I paid retail HF price for but the 50 amp was on the ITC flyer at 250 bucks off and I have an exemption certificate on file with HF so I don't pay sales tax either. HF has come a long way from cheap throw away one use tools and stinky tarp straps. Now, they are competing with tool truck quality tools at a much better price point and I have a pretty good selection of Snap-On and MAC tools as well and I'll put the HF tolls up against them any time.
I will say their impact rated sockets are indestructible. I've put them to the test many times removing wear steel scrapers on snow plows with my Thor 1/2" impact wrench that makes over 1350 foot pounds of breakaway torque and I've never had one fail. I've broken Snap-On and Mac sockets, split them right down the sides but not the HF impact rated sockets. Even used them on my IR 1" drive air impact that makes over 2000 foot pounds (with an HF 1/2 square to 1" adapter) and neither the sockets nor the adapter have failed. I rarely use the IR impact because it's so heavy. Really made for mounting and dismounting 10 hole Budd style wheels.
/ Harbor Freight Tools that don't suck #15,858
That can be an issue. The Thor requires around 25 CFM at 90 psi with large diameter air hose and large diameter free flow fittings to achieve it's rated output. If I'm busting corroded plow bolts or removing and replacing the blades on my shredders, even my 10 horse Quincy has a hard time keeping up and it has a 150 gallon receiver. The Thor really eats the compressed air up, kind of like my plasma table running production parts. Most times with the plasma table I'll kick in the screw compressor as well but the 10 horse Quincy plus the Sullaire really spins the electric meter.
One thing I never do is run my compressed air system at 175 psi. I have everything dialed back to 135 psi which is more than enough to run any air tools or the table at.
The only thing 175 psi does is carbon up the reed valves in the Quincy faster (the are cleanable but require taking apart the compressor head) and 175 psi heats the compressed air more and produces more condensate. Most air tools, if you read the fine print, are rated at 90 psi for maximum efficiency. The screw compressor has it's own built in air dryer and I run the output of the Quincy first through a timed purge valve on the bottom of the receiver and the output air through an IR refrigerated air dryer but I will still get condensate collecting in the shop pipework so each drop has a ball valve and drop hose to eliminate as much of it as I can plus the plasma cutters both have Motorguard cannister filters with replaceable elements on them. Entrained moisture in the air supply for a plasma cutter is death on consumables and the internal valving in the units.
Glad I did 99% of the shop and equipment before I retired 20 years ago. At today's inflated prices, I could never even think about doing what I did and it was expensive even then. Probably why I own 4 motorcycles I never ride anymore as well. I should sell them but I don't for sentimental reasons.
/ Harbor Freight Tools that don't suck #15,859
What kind of "heat" did you use? I've never seen a stuck nut that wouldn't succumb to an oxy/accel torch heating it to bright red...
/ Harbor Freight Tools that don't suck #15,860
If u don’t have a BIG oxy torch.. they have them in a hand held YELLOW BOTTLE..
NOT THE BLUE BOTTLE..
ATTENTION! PLEASE READ (A60463)
ATTENTION! PLEASE...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
2019 Merlo TF42.7 (A60462)
2019 Merlo TF42.7...
500BBL WHEELED...
2015 Chevrolet Tahoe SUV (A61569)
2015 Chevrolet...
Giyi RB66 Quick Attach 66" Rock Bucket (A60463)
Giyi RB66 Quick...
